Question about HP DesignJet 450c InkJet Printer
Just got a used 450c. Problem: Plot didn't finish.
Just got a used 450c. About 3/4 of the plot came out fine but then plotting stopped and now its just sitting there with the ready light flashing. Any suggestions?
  • ryne_brutus Feb 03, 2010
    no the ready light is flashing. not steady.  so not a cartridge error.  any other thoughts?
  • HP Master
  • 19,396 Answers
Hi.
A steady light is cartridge error, any other problem will give you a flashing light.
Please follow the instructions here, they also apply to Designjet 450C:HP Inkjet Supplies - Print Cartridge Errors
Let me know in case that does not clear the error.
Regards.
Posted on Feb 02, 2010
  • Ginko
    Ginko Feb 03, 2010
    Hi, sorry, the link above (HP Inkjet Supplies - Print Cartridge Errors) covers the blinking light, mine was a typing mistake, I wanted to say the opposite, I read your clear question.
    You can follow the troubleshooting above to check if it is cartridge error.
    Additionally check for:
    Data error while printing.
    Turn off the printer. Unplug cable. Empty printer cue on computer. This is the easiest thing to check. I bet you have done this already. Ensure you have unplugged cable and done this.
    Check for jammed paper, if there is nothing else, then there may be a fault. In that case the printer must be tested
    1 Data error.
When i press graph on my ti-84 it only shows me the plot points and not the line?
At first, 2nd then stat plot. Then select plot option which you want to use. Press enter for On option and after that check plot type
Apr 04, 2013 | Texas Instruments TI-84 Plus Calculator
How to use the basc funtion on the ti-83 is there a way that i can find out how to find the right way or a map to get to the box plot or make a historgram
Use the STAT utility to enter your data in a list. (STAT>EDIT. If you have repeated elements you can use L2 as a frequency list. Once you finish entering the data press [2nd][QUIT]
In the main calculator screen, press [2nd][Y=¨to enter the STAT PLOTS.
Press 4:PlotsOff to decativate all plots, then activate say Plot1.
1. Press 1:Plot1. Use arrow to highlight ON and press ENTER.
2. Use the DownArrow to move cursor to the line Type:
3. Select the plot type. (On this line only the right or left
arrows will allow you to select a type.)
Select the type and press ENTER.
4. Use DownArrow to move cursor to the XList line.
5. If the default (L1) suits your needs, press ENTER.
If not chage the list label to the correct one.
6. Do the same with the YList label.
7. Selectr the MARK style and press ENTER
6. Press GRAPH to have your plot
Sep 04, 2011 | Texas Instruments TI-83 Plus Calculator
I was plotting graphs of quadratic functions and all of a sudden i had error message: INVALID DIM. What do I do?
If you were graphing equations in the y= screen, chances are that you have Plot 1 or one of the other plots on. You can tell if this is the case if you have a black box over plot 1, plot 2 or plot 3 in the y= screen. To turn of the plot with the black box over it, arrow up and over if needed to highlight this black box. Press enter and you will turn the plots off and should be able to graph.
Another solution is is press the 2nd key, then the + key, then the 7 key, then the 1 key & the 2 key. This clears the RAM and resets the calculator to the original factory defaults.
Remember.....2nd....+....7.....1....2
Hope this helps/
Jun 19, 2011 | Texas Instruments TI-84 Plus Silver...
Max file size 450c can plot ?
You should have no trouble with the unit as additional buffering will be done in your PC if necessary. These units are a one pass rather than a whole page at a time.
Feb 18, 2010 | HP DesignJet 450c InkJet Printer
Having trouble with my TI-83 plus
Some old junk is in memory. Reset the memory to defaults and everything will be fine. It is a good practice to clear memory before a new calculation.
To reset memory
Press [2nd][MEM][7:Reset][1:All ram][2:Reset] [EMTER] . Clear screen and enter the functions you want to graph.
Hope it helps.
Sep 27, 2009 | Texas Instruments TI-83 Plus Calculator
How to draw histogram graph
When you finish entering you data, Press F2:Plot setup. Highlight
one plot number , say plot1, then press F1:define to define the type of plot you want plot1 to be. In the new window
Plot type : select histogram
x : enter the header of the column where you put data c1, c2 ?
Hist. Bucket width : enter the width of each band
Use frequency and categories:Yes
Frequencies : enter the name of colum where frequencies are.
Categories : column of categories (if any)
Include Categories: enter the categories that you want to use.
Press ENTER to save.
Configure the Window, then [Diamond][GRAPH].
A sound lnowledge of the theory behind the histogram is needed.
Hope it helps.
press Enter to save
Sep 24, 2009 | Texas Instruments TI-89 Calculator
When i try to graph a scatter plot on my ti-83 plus it says ERR:INVALID DIM or it gives me a blank graph, how do i graph it?
Your stat plots are on, and may not be filled out/ correctly filled out.
go to [Y=] and go up to the stat plots ([Plot 1], [Plot 2], [Plot 3] ) and turn off the ones that are "ON" ( highlighed black w/ white text.) and press [ENTER] on the ones that are on and the problem is no more.
May 12, 2009 | Texas Instruments TI-83 Plus Silver...
Incomplete plot from .pdf file - Hp DesignJet 1050C Plus
Was the plot originally done on a size D or E plotter.. A .pdf is generally not a good way to send a plot that has to be done to scale.. Can they re-send the plot in a hpgl format, or a format that you can use in another program, liks ACAD, and then print it through that program? This would provide you with some control, that a pdf document will not allow.
This is just a stab in the dark for me, but I am familiar with plotters in general, just not the many formats to print from..
Nov 19, 2008 | HP DesignJet 1050c plus InkJet Printer
Designjet 450C
In my 8 years of servicing plotters I haven't seen published specs as far as the paper thickness goes.But from experience and seeing my customers produce problems free plots, you don't want to plot on anything past 30 lb media. 99% of plots are done in the 18-24lbs range. Media Types: Paper (plain, vellum, coated, glossy) Film (vellum, coated, glossy, clear, matte), Translucent Bond for Black output only
Hope this helps
Mar 02, 2008 | HP DesignJet 450c InkJet Printer
1050c
check your rip settings in the plotters control panel, as well as checking to make sure you are using the correct driver, if those are correct then you may have a faulty network card.
Good Luck!
Jan 18, 2008 | HP DesignJet 1050c InkJet Printer
HP DesignJet 450c InkJet Printer Logo
76 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
