Question about Brother MFC-640CW All-In-One InkJet Printer
I want to use my wireless brother printer/fax but don't know what to push to make it send. It is a mfc-640cw
  • 286 Answers
SOURCE: receiving faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Posted on Dec 29, 2007
Mix-it-up
  • 832 Answers
SOURCE: mfc-640cw
Yes. There is some paper left in the very edge (mostly left hand side). Have a good look there by opening the scanner top.
Posted on Feb 28, 2008
the kowalski
  • 86 Answers
SOURCE: error 46 in brother mfc-440cn
Machine Error 46 ("Unable to Clean") indicates that the wasteink is full. Basicly it gives you two options - have it replaced (a semi-complicated performance which requires buying a spare part and change it yourself) or have it sent to service. If you do not have any warranty on the machine, the more suitable would probably be to just replace the machine instead, since it's relatively cheap compared to both service costs and having the wasteink replaced, but you instead get a full new warranty on your new machine.
Unfortunately, there's nothing you yourself can do to remove this error, without actually changing an item inside the machine.
Posted on Jun 04, 2009
MUKHTAR
  • 2017 Answers
SOURCE: I have a brother MFC-7430 all-in-one - Fax won't work
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Hope this helps. Please rate my response.
Thanks.
Posted on Mar 16, 2010
JEFerrer
  • 87 Answers
SOURCE: my brother mfc-490cw I can't send or recieve faxes.
According to the User's Manual for the Brother MFC-490CW:
  • Poor Line Connection indicates an issue with your telephone line (Page 136). If you are sharing the fax line with any splitters or computers, try connecting the MFC-490CW directly to the phone jack and send a fax. If you are still getting a Poor Line Connection error message, call the telephone company and have a repair technician check your telephone line.
  • Out of Memory error message means the machine's memory is full (Page 138).
    Try pressing Stop/Exit and wait until all current operations finish and try again.
    Try clearing the data in memory. To gain extra memory space. turn off Memory Receive (See Page 48).
    Try printing the faxes that are in memory (See Page 49).
  • System Busy error message wasn't in the manual, but I suspect it means there's a current operation in progress and the machine needs time to finish before moving on to another job. Just wait for the current job to finish, then try again.
Posted on May 05, 2010
Cannot get a wireless signal show on Brother
Try to change the Channel in your router , try changing it to Channel 10 , normally that works to sync with printers.
Mar 13, 2010 | Brother MFC-640CW All-In-One InkJet...
Lost manual for Brother MFC-640CW
Go to the following link which has user manuals, quick start manuals for your multi-function center.
http://www.brother-usa.com/SiteSearch.aspx?sk=MFC-640CW
I hope that this information was helpful and will get you on the right track to solve your problem.
Brian
Jan 24, 2010 | Brother MFC-640CW All-In-One InkJet...
Brother mfc640cw
If you are having difficulty sending a fax overseas due to possible
interference on the phone line, we recommend that you turn on the
Overseas Mode. After you send a fax using this feature, the feature
will turn itself off.
1 If it is not illuminated in green, press (Fax).
2 Load your document.
3 Press Menu/Set, 2, 2, 7.
4 Press ▲ or ▼ to select On (or Off).
Press Menu/Set.
Your manual gives this information also on page 3-13
Good Luck
Dec 15, 2009 | Brother MFC-640CW All-In-One InkJet...
I don't know how to connect fax machine
Fax machines will not work reliably on high speed DSL phone lines.
Mar 03, 2009 | Brother MFC-640CW All-In-One InkJet...
How to use the fax?
hi maenes
have a look here on this model Brother MFC-640CW All-In-One Printer
you can get the pdf file form here to download the instructions
riz.
Dec 15, 2008 | Brother MFC-640CW All-In-One InkJet...
Receiving fax
plz have a look around here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc640cw_all
There are so many diffrent possibilities why you cant fax or receive fax.
Apr 11, 2008 | Brother MFC-640CW All-In-One InkJet...
Brother MFC-640CW All-In-One InkJet Printer Logo
15 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
