Question about BEL 880 Radar Detector
Sound won't work on bel 870 - BEL 880 Radar Detector
The belt keeps slipping off so the drum won't turn
replace the bel, is worn, put a new one. Of course before try to adjust the tension of belt, for moving a little the motor.
God bless you
Sep 22, 2012 | Vacuums
Clutch for johndeere 870
That is normal for a live pto. If your tractor has a two stage clutch you should be able to stop the PTO with clutch all the way in (as in push the pedal all the way down). It should be transmission independant, meaning it will work even though the transmission is not turning AND if you are running something that has a lot of inertia, it won't push you around by driving the rear wheels even though you have the clutch in.
Aug 25, 2012 | John Deere 760 790 850 870 Flail Spreader...
My 1967 bel air has a 250 l6 and won't start, it tries but just won't kick over, what should I look for first?
need 3 things to run
1. fuel
2. air
3. spark
loose any and it wont run, pull a plug wire off and crank it over.
does it spark? if yes good if no do same test with coil wire
disconnect fuel line stick hose in a bottle turn over, pump fuel? yes? good, no either filter clogged or pump bad
Jul 14, 2011 | Chevrolet Chevy Cars & Trucks
What type of oil does my 2002 yamaha ttr 125 take
10w-40 should work just fine. I prefer a full synthetic, like Amsoil or Bel Ray. Avoid "energy conserving" oils. They contain additives the clutch won't tolerate. API rating SL/CF,SJ,SH,SG are all acceptable. Happy biking!
Jun 13, 2011 | 2002 Yamaha TT-R 125
DRIVER FOR PRINTER NEC870 x WIN7 x64
You could try use the Windows XP SuperScript 870 driver or you could install the HP LaserJet III printer driver. It should work with your printer, but may have limited functionality.
Feb 08, 2010 | NEC SuperScript 870 Laser Printer
Bel STi Short or Loose Connection
This most likely is due to a blown internal speaker which has shorted across its voice coil rather than becoming an open circuit. Bel/Escort now uses special "high temp" speakers which resolve any failing speaker issues due to higher temperatures. I assume that your STi is out of warranty. Yet, it will be worth it ($80) to have the speaker replaced and to have your STi flashed with the latest firmware which also gives the STi a true audio ramp-up rather than just the original slow or fast audio beeps to indicate the strength of the detected radar. The new firmware also includes slight performance enhancements, and includes better filtering for Autoscan mode. This latter enhanced Autoscan filtering makes the STi noticeably quieter while driving around town.
Apr 03, 2009 | STI Driver Radar Detector
No sound, voice or beeps
Good Day Joe,
Sounds to me like the internal speaker went, this is actually common on radar detectors. Although 9yrs is a lot longer than most will last. If you are handy with a soldering gun you can replace the internal speaker with a new one and get it working again. However be sure to take the unit apart before getting a new speaker so you can match up the size as it varies.
Good Luck and I hope thi shelps
Jul 04, 2008 | BEL 950 Radar Detector
Does the bel 980 need to be upgraded ??
BEL no longer offer upgrade or repair for the BEL 980 detector
May 27, 2008 | BEL 980 Radar Detector
No sound from the bel 880 radar detector
I have the same detector and my sound just went out, I called the number on the label on the bottom. They where very friendly and told me that it was more than likely the little speaker, they sell them for $8, if you are handy with a soldering iron its a simple task.
Nov 19, 2007 | BEL 880 Radar Detector
Bel 880 sound
Call bel, the number is on the label on the bottom, I am having the same problem with mine, he was very helpful and said it was probably the speaker which they sell for $8. If your handy with a soldering iron its simple repair. Or they offer a trade up service, giving you like $80 towards a new unit.
Nov 13, 2007 | BEL 880 Radar Detector
BEL 880 Radar Detector Logo
267 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
John Nolan
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
