Question about Alpine 3DA-W880
What vehicle will this fit in? I have an older gm
  • 518 Answers
You can fit any stereo in any vehicle as long as the correct volage is used, which is 12 volts
Posted on Feb 08, 2010
Wires to starter motor on 6v53 GM Has neg and Pos wheres the other heavy lead connect that goes to (looks like a solinoid which has small pipes leading away from it)
6 volt 1953 no problem here post a picture and i will take one look and tell you ,but from spain trying to work out what this vehicle has fitted and how i couldnt tell you ,as never seen one here in spain.But as iam so ancient i have worked on older vehicles so one i can whats what i can advise
May 30, 2015 | Cars & Trucks
Change oil sending unit 04 tahoe
It is located on rear of engine back by the distributor use to be. see attached pic
Mar 15, 2015 | 2004 Chevrolet Tahoe
How easy is it to replace a leaking brake line under the driver's side door on a 1995 oldsmobile cutlass ciera?
In most cases on these older GM vehicles it is much easier to replace the lines from the master cylinder all the way to the rear wheels. You should be able to find brake lines that are preferred and have the correct fitting for what you need to do. Compression fittings are a definite No No!
some things to check ahead of time.
1. Do all the bleeder screws open? If not you may be replacing wheel cylinders and calipers.
2. Are the brake hoses cracked? If they are might as well replace them at the same time.
3. Are the pads and shoes in good shape. If they are getting thin might as week replace them as well.
Just about every GM that I get in the shop with rusted brake lines to the rear end up with a $800 +/- bill. 3 hours labor, 20+ feet of line, proportioning valves (later models), fittings, wheel cylinders. And a bleed and flush.
The lines don't have to look pretty they just have to work!
good luck and let us know how it goes.
Sep 19, 2014 | Cars & Trucks
How easy is it to replace a leaking driver's brake line on a 1995 cutlass ciera?
Some things to check ahead of time
4. Do all the brake lines you need to replace come loose from the hoses, cylinders, master cylinder, proportioning valve, etc.
Odometer not working on 1997 suburban
Hello BDG, The answer is no. If the VSS fails on your 97 Chevy, you will lose both speedometer and odometer functions. If your speedo is still working and your odometer is not, you have a broke odometer. This is a common failure with a lot of the older vehicles that were fitted with the mechanical odometer registers. Feel free to contact Kincer's Service for a repair salution.
GM Instrument Cluster Speedometer Repair Service
Mar 26, 2014 | 1997 Chevrolet K1500
Front fan/aircon not working in delica spacegear . Rear working fine.
Common fault here they wear out ,now what i do as they are so expensive is to fit a fan from a citreon xsara picasso ,the older model without all the built in resistance block and with a bit of jiggle and fettling i make it fit .Yes iam a cowboy but the customer was happy it worked and saved a lot of money ,ok its not the correct part and on full speed its noisy but shes happy with it ,this vehicle has a few of my touches like a catalyic converter from a old cheroke jeep ,bit of welding on the rear seats ,header bottle from a VW i think it was ,parts are so expensive and dealer only for a mitsubishi unlike a ford or a GM product
Nov 02, 2013 | Mitsubishi Eclipse Cars & Trucks
Installing 85 Iroc 305 into 57 Chevy; need wiring diagram to create EFI harness from car harness
Check out faxonautoliterature.com. They have an assortment of literature that should be able to get you up and running. There are original GM dealer service manuals for both vehicles which would have complete wiring diagrams. They list a separate wiring diagram book for the Camero. They have 2 different books on swapping newer GM engines into older GM vehicles. I've used them before and had excellent service. Hope this helps.
Sep 06, 2010 | 1985 Chevrolet Camaro
Hooking up audio
Unfortunately, even if you get the wiring sorted out, the Ford radio chassis does not fit in a GM - the mounting is entirely different. The wiring harnesses and colors are also entirely different. Maybe best to find a GM radio - most of the GM radios should fit and plug right in.
Apr 18, 2009 | Car Audio & Video
Car Audio & Video Logo
32 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
