Question about Acer AL1916W 19" LCD Monitor
My monitor is flashing all the time...what to do...
  • 11,361 Answers
If the screen is lit up and goes black, you may have bad power supply due to bad caps, look inside and report back what you see so we can guide you further, see examples here: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 03, 2010
Need to set date and time ozeri bp2m monitor
  1. Press and hold Time button until Hour/Min. flashes
  2. Press Time again; Mon. flashes
  3. Press Scan (down) or Memo (up) until the current month is displayed
  4. Press Time; next field flashes
  5. Press Scan (down) or Memo (up) until the current value is displayed
  6. Repeat steps 4 and 5 until all fields are set to appropriate values
  7. Press Time again; date and time are saved
May 09, 2013 | Ozeri Portable Cardiotech Premium Series...
Samsung 931bw screen flashes on and off
unscrew the back cover of the monitor then remove to access the power supply board, look for a leak or blown up electrolytic capacitor. just replace with the same rating and value a panasonic brand of capacitor much better with low esr.
Jun 28, 2012 | Computers & Internet
My HPL1530 monitor flashes from time time the menu of the monitor. Even when my CPU is off it still continues to flash the menu. Now my monitor is blank already and display is gone. Any help is much...
Sounds like you might have a faulty circuit board either where your buttons are or in the screen itself. I would check with the manufacturer for a recall or for other support information.
Dec 13, 2010 | HP L1530 (Carbonite, Silver) 15" LCD...
I can't turn the monitor on. The light continuosly flashes
I would go ahead and get a new monitor. It sounds to me as if the button is broken were it connects on the inside
Feb 23, 2010 | Acer Value Line AL1717B Monitor
My computer monitor will not stay on.
The problem may with the Ram inside your computer
Jul 07, 2009 | Dell E153FP 15" LCD Monitor
Monitor flashing at startup
When the monitor is flashing, is the flashing coming from the middle and going up and done to fill the screen. If so, probably capacitors in the monitors power supply are leaking and need replacing.
Mar 27, 2009 | ViewSonic VG900b 19" LCD Monitor
Airbag flashes 10 times misses a flash then repeats
Try clearing the codes & see if it returns. I do not see a code fault 10. Starts at 12.
Section 01-20B: Restraints, Passive — Supplemental Air Bag System 1995 Town Car, Crown Victoria, Grand Marquis Workshop Manual DIAGNOSIS AND TESTING Diagnostic Trouble Code Clearing Procedure to Clear Diagnostic Trouble Codes from Diagnostic Monitor Non-Volatile Random Access Memory.
Normal Operation
The air bag diagnostic monitor (14B056) continually checks the air bag system for readiness. When a fault condition is detected, the DTC associated with that fault is stored in the air bag diagnostic monitor's Non-Volatile Random Access Memory (NVRAM). After writing the DTC to NVRAM, the air bag diagnostic monitor signals the fault by flashing the appropriate diagnostic trouble code on the air bag indicator. The diagnostic trouble code written to NVRAM is permanently stored in the air bag diagnostic monitor until cleared by the diagnostic trouble code clearing procedure.
  • Upon each cycle of the ignition switch (11572) , the air bag diagnostic monitor checks for diagnostic trouble codes written in NVRAM. If any diagnostic trouble codes exist in NVRAM, the air bag diagnostic monitor will then check to see if these fault conditions are still present.
  • If the conditions of the diagnostic trouble code in NVRAM are still present, then the air bag diagnostic monitor will use the air bag indicator to flash out the diagnostic trouble code number that was written in memory.
  • If the conditions of the diagnostic trouble code are not still present (indicating an intermittent or serviced fault), the air bag diagnostic monitor will use the air bag indicator to flash out a DTC which is the sum of the diagnostic trouble code in NVRAM plus 40.
Example: Due to corrosion, high resistance develops on the driver side air bag circuit. The air bag diagnostic monitor stores a diagnostic trouble code 32 in NVRAM. Upon each cycle of the ignition switch , the air bag diagnostic monitor checks the resistance of the driver air bag circuit.
  • If the resistance is still high, the air bag diagnostic monitor causes the air bag indicator to flash out a DTC 32.
  • If the resistance falls within the normal range due to service or an intermittent condition, the air bag diagnostic monitor causes DTC 72 to be flashed on the air bag indicator.
Once a fault has been serviced, the associated diagnostic trouble code may be cleared from NVRAM. Only diagnostic trouble codes that the air bag diagnostic monitor sees as repaired or intermittent may be cleared (diagnostic trouble codes 52 and above). In no circumstances can hard fault conditions (diagnostic trouble codes 45 and below) be cleared.
  1. Follow the diagnostic procedures as outlined to service the fault condition flashing on the air bag indicator.
  1. Cycle the ignition switch to OFF and then to RUN.
  1. Observe air bag indicator prove-out (six ± two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
  1. Locate the Diagnostic "Trouble Code Clear" Connector located underneath the glove compartment (06010) containing Circuits 631 (T/R) and 57 (BK).
  1. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously.
  1. Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
  1. Release short on Circuit 631 (TAN/RED STRIPE) to Circuit 57 (BLACK). This short must be released within 25 seconds after the diagnostic monitor tone sounds. Diagnostic trouble code is now cleared from NVRAM. Next highest priority diagnostic trouble code stored in NVRAM (if one exists) will begin flashing.
Feb 09, 2009 | 1995 Lincoln Town Car
MONITOR FLASHING
blown capacitors on the power board can be soldered off and new ones put on for about 5 dollars and soem time.
Sep 09, 2008 | Star Logic 17" LCD Monitor
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
108 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
