Question about HP 640 Inkjet Fax Machine
Machine will receive and print faxes, print the test sheet, but will not make a copy. It reads that it is copying but just sends out a black copy
    President:
  • 3,085 Answers
Your scanner is defective. It is not worth fixing. Sorry If you send out a fax it will be black also.
Posted on Feb 03, 2010
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
When I send a fax the receivers copy is black.
Make a copy with the machine. If it comes out black as well your scanner has gone bad. In other words when you insert an original to be "scanned" so it can be faxed or copied, it is being read as all black. Usually this occurs because the row of led's that light up the original go bad. Now I have seen in some cases, if you unplug the machine for a bit then power back up the problem goes away so try that. Test by making a copy. If this does not work then your are looking at a scanner assembly replacement or just get a new machine.
Good Luck and Thank You for using Fixya.
Aug 25, 2010 | Brother IntelliFAX 4100 Laser Fax
Can receive a fax but when sending a fax it sends a black sheet
YOUR SCANNER LED LAMP IS DEFECTIVE. IF ITS NOT UNDER WARRANTY YOU SHOULD JUST PURCHASE ANOTHER FAX
Aug 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
How can we tell if our fax machine is working
basically if the fax is well kept, its dialing properties will remain ok. what you need to check is the quality of print out. to test the quality of print out just try to copy a sample document. if your fax is a thermal type, change the paper first before proceeding with copying. if your fax has a menu and help button try pressing the menu first before help for the fax to print a helplist.
Mar 28, 2009 | Office Equipment & Supplies
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Nov 21, 2008 | Canon NP 7130 Black and White Copier
Poor Quality
If you can copy ok you have effectively ruled out your machine as you have used both the scanning and printing mechanism of the machine.
It will probably be the fax on the other end as if it sends a poor quality page that's all your machine can receive, a poor line can also cause problems if it is from multiple faxes. If so have your provider check the line (you probably hear static on the line).
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Open Questions:
See all HP 640 Inkjet Fax Machine Questions
HP 640 Inkjet Fax Machine Logo
Seeker5211
Seeker5211
