Question about Maytag PAV2300 Top Load Washer
Not washing right
I can´t find the filter
  • robert samples May 11, 2010
    thats because that model doesnt have one
    Sergeant:
  • 351 Answers
If its not washing well (lint) use less soap and wash time,but this model is known for this problem.
Posted on Mar 08, 2008
Where are the filters
as you stand in front of it look to the bottom right it is behind the flap
Jan 30, 2014 | Bosch Washing Machines
Washing machine stays on wash cycle
Insert a piece of wire into hole in filter door, and push in gently. While pushing, turn the cover clockwise, it will came off.
Click if helped.
Mar 18, 2013 | Bosch Washing Machines
Samsung SW60ASP washing machine won't spin or drain
5E is a Drain Error Code.
This can be caused by a clogged filter in the washing machine or a blocked drain line in your house. There can be a few other reasons, but these are the most likely.
If you would like to try to repair it yourself, then follow these instructions:
UNPLUG the washing machine. Repeat, UNPLUG the washing machine!!!
Check the filter in the back of the washing machine on the bottom right-hand corner. Place a shallow dish under the filter. Loosen the filter to drain out the water. Remove the filter and clean it out. Look at where you removed the filter and you will see the water pump impeller. Make sure it can move and isn't locked up. Remove any debris from the impeller.
Replace the filter, and plug in the machine. Try a short wash cycle.
Check for leaks around the filter.
Mar 11, 2013 | Washing Machines
How to clean water filter?
http://www.washerhelp.co.uk/washing-machine-parts/pumps.html#cl_q4
Most washing machines have a pump filter to protect the pump from obstructions such as coins. The pump filter should be at the front of the washing machine at the bottom left or right. It should be obvious (a square or round flap) but sometimes the filter is hidden behind the front kickstrip panel. A good washing machine filter should have retractable pipe at the side so that you can drain the water into a bowl. In any event, please go to this link above, this is all explained again, and there is even more direct information you need to know, the list is large.
Jun 06, 2010 | Hoover AAA140 Front Load Washer
Will not pump water out
My grandmother had the same problem. Lets see if it's the same one. Maybe, your water filter is clogged. Washing machines have a water filter right before the water comes out. Try cheking that out, maybe it's clogged by hair or something like that.
May 09, 2009 | Washing Machines
Does machine have a filter
The filter is to be found at the rear of the washer.
Remove lower rear panel of washer, remove large black hose fastened to bottom of tub.
Watch out for water running out.
Remove plastic`filter inside hose and clean.
Refit filter and hose.
Dirty washing can somtimes be attributed to washing at too low a temperature, so make sure you have selected right temp for washing.
Please leave a fixya rating for my solution.Thanks.
Feb 08, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Washing machine not draining therefore not spinning
You will find the filter located inside the large black hose at the lower right rear of the m/c.
Remove lower panel and you will see the hose there.
Undo the large clip and remove hose and clean filter.
Plz rate this solution
Thanks
Dec 19, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Shows 5e fault
Debree filter located at bottom right on the front of the washing machine is blocked. Power needs to be turned off, and compartment to filter opened with a coin before cleaning, there is a hidden tube again to the right and below the filter, pull out cap to this and put bowl below to catch water - there is rather a lot of water so important to do this. Don't forget to clean the filter once water empties out.
Nov 05, 2008 | Washing Machines
Washing machine problem
probably filter blocked. if memory serves me right, filter is located in pipe from sump to pump. remove bottom back panel. remove sump hose where ir is clamped to tub and filter is inside this pipe, take out and clean
Jun 18, 2008 | Indesit W 123 Front Load Washer
Maytag PAV2300 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
