Wont turn on power button flashes as just keeps flashin
  • 3 more comments
  • stevehayes92 Feb 02, 2010
    i have a montior thats a gateway fpd2185w and a SAMSUNG LN40A450C1D the tv is just flashing red and thats pretty much the same thing the montior is doing
    SAMSUNG LN40A450C1D
    never tried is that a common problem because i seen a few things on here saying that there a 4 caps that need to be replaced how do i know if a cap is bad?
    could you walk me though this??
    oh i need to get the caps first and i work tonght are you usually on here
  • 566 Answers
Hi steve
I`m gonna try to help you but first;
Could i have your tv`s brand name and model number?
Posted on Feb 02, 2010
  • 2 more comments
  • Jacques Marin
    Jacques Marin Feb 02, 2010
    Hi again steve
    The problem for your tv is the power supply.
    There are two capacitors that need to be replaced ;
    Parts location CM852 and CM853 , they are 1000mfds at 10 volts and you can replace them with 1000mfds at 16 volts.
    How good are you with a soldering iron?
  • Jacques Marin
    the two caps i listed are the main problem in this case.
    Look at them and you will see that they have a rounded top or appear swollen and might even leak(at the top)
    If you see any other caps that looks the same in that area , then they need to be replaced as well.
  • Jacques Marin
    No problem
    First you`ll have to take the back cover off and follow the power cord up to the power supply.
    Let me know when you`re there
  • Jacques Marin
    Contact me through email when you are ready.
    And also you may want to wait to see if there might be other caps that need to be replaced.
    my email; marinjacques@hotmail.com
Ss-700 keeps flashin Not Ready
I had the flashing not ready problem with my SS-700 Cuisinart as well. I pressed and held the rinse and Hot Water buttons at the same time for about 10 seconds while the Not Ready was flashing. After 10 sec or so the display went off completely. I then powered up with the power switch on the side and the coffee maker came and is working fine so far.
May 13, 2012 | Cuisinart SS-700 5-Cup Coffee Maker
Xbox 360 power button light keeps flashing and disc tray does not open
Hi when the power button flashes red if you hold down the little round white button under the dvd tray and keep holding it down then press the open button for dvd then it will flash a number of lights write this down.
it will be flashing 1 2 3 or 4 lights so write it down then hold down the white button again and press the draw open button again and write down how many again.
do this 4 times all together and tell me what code it has given you then i can tell you exactly what the problem is
so for instance
you hold down the little white wireless button and keep holding it down then press the open button for the dvd tray and say 4 lights are flashin
so write down 4
then hold white button down again and press open button again
it may flash 4 again
then do it again and it may flash 2 lights
then again and it may flash 2 again
when you have gotten these 4 codes post me a message and tell me exactly what they tell you and in the correct order so it may look like this
4 lights flashing
2 lights flashing
1 light flashing
2 lights flashing
if you look at where the button is where you turn it on well you have the green light in the middle well around this is four outer lights that light up red their are 4 of these 2 at the top and 2 at the bottom either side of the green light, their the ones that flash green when its spinning rounf with green lights so write this code down then ill be able to tell you exactly what the fault is ok
let me know then i can assist you further ok
Oct 05, 2010 | Microsoft Xbox 360 Console
Lg vu is stuck on re-flashin screen
Remove your battery for a few minutes. If you use a SIM card in your phone. Remove it also.
Replace all & then attempt to power back on. If this continues; try a new battery.
Jun 21, 2010 | LG Vu CU920 Cellular Phone
My wii remote keeps flashin but wont trun on
You have to sync the Wii remote to the console.
To sync the Wii remote, turn on your Wii. Then open the back of the remote and press the "SYNC" button. Then open the SD Card Slot cover on the front of your Wii and press the "SYNC" button. Your remote should be turned on if you do this.
If this problem still occurs even when the Wii remote is synced, your Wii remote might not be working properly. Return it for a new one.
Feb 21, 2010 | Nintendo Wii Remote Controller
The green button will flash so its got power but tv wont turn on
your lamp has gone bad your going to have to buy a new lamp for it
Mar 29, 2009 | RCA P52926 52" Rear Projection Television
KDC-MP443U - flashes protect
I had the same Prob on my KDC 237. I hit the small reset Button on the front and it fixed it. Hope this helps.
Mar 03, 2009 | Kenwood KDC-135 CD Player
Satellite R10 Wont turn on
clean off the heatsink and CPU fan.
Feb 23, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Is my v360v dead??
can not send picts from my phone from South Africa to Greece please can u help
Feb 11, 2008 | Motorola Mobility V360 Cellular Phone
Flashin power light - wont come on
The "green light flashing to the chirping" circuit may be defective.
Not a basic diagnosis--service literature and/or knowledge of each green light circuit will be needed.Possible shop repair.
Oct 05, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
