Question about MSI MS-1034 (1034B039) Barebone
When i power on my laptop, cpu fan will just spin for a second or two but will not boot, no video, my laptop is msi q2 design 10342-b
    Brigadier General:
  • 4,088 Answers
Either the battery is at end-of-life, or the charger is not doing it's job. The machine should run with the charger plugged in. If so, the battery is suspect.
Posted on Feb 02, 2010
    Sergeant:
  • 295 Answers
Either one of two things.
1) Either your hardrive has crashed or:
2) Your system board has gone bad.
Do you have a trusted PC shop around to take it to and get an estimate of repair. They maybe able to fully pinpoint the main reason of what's wrong!
When i boot my thinkpad laptop, the fan spins and stops and the screen doen't appear
this could be four things, firstly the cpu heats up above a comfortable heat ands its internal safety shuts it down, that is what i would put my money one, the second could be faulty ram, the third would be blown bios and lastly a faulty power supply. but its normaly 1,4,2. in that order
Apr 08, 2013 | Computers & Internet
My msi u230 keeps shutting off
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Feb 05, 2013 | MSI U230 Light087 Netbook
Msi windpad suddenly shutdown
Jan 31, 2013 | MSI WindPad 110W 10Inch Tablet Computer PC...
Cooler Master 1000w Silent Pro M not compatible with MSI MS-7548 (Aspen) motherboard?
http://www.coolermaster-usa.com/product.php?product_id=2949
So you're using the same CPU 4+4 Pin x2 power cable on both rigs?
(One of them)
Yes, I see it's a modular cable design, and the CPU 4+4 Pin x2 power cable, can be used as a single 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps4plus4
ALL Yellow wires are 12 Volt (DC) wires.
ALL Black wires are Ground wires.
ALL 12 Volt wires go to ONE single 12 Volt power rail, in the Power Supply, BUT; there is nothing saying an individual Yellow wire may be bad.
This is why I wondered if you are using the SAME power cable CONNECTOR. Same power cable.
Yes?
Then suggest it has something to do with the Active PFC circuit.
http://www.hardwaresecrets.com/article/Anatomy-of-Switching-Power-Supplies/327/6
Not aware of any setting to change in BIOS Setup utility - Power.
BUT, I do not know everything! lol!
IMHO there is no reason it will not work, unless as said; something to do with the Active PFC circuit.
From here let's hope someone who really knows what is going on, will post.
Regards,
joecoolvette
Dec 10, 2012 | Computers & Internet
I have a msi a6000 laptop and it keeps shutting off itself and wont boot windows when windows stars booting it shuts off and i clean the fan so thats not it can someone tell me what it's hapening
try replacing the thermal grease on your cpu.
the BIOS have a protection that restart or shut down the computer/laptop when the cpu get to hot.
You can also check if the power suply is working in parameters
Dec 06, 2012 | MSI A6000-226US Core 2 Duo T6600 2.2GHz...
Msi computer turns of while playing
Oct 28, 2012 | MSI GX630-028US Notebook
When I turn my laptop on, it starts to boot up and then after about 30 to 40 seconds a get what looks like a small thermometer icon with Warning at the top of it...the computer will show this a couple of...
If your laptop won't boot up again until it has cooled down, then the problem is a faulty fan and or dust clogging the fan and heatsink fins. The CPU overheats and shuts down (thermal overload) and if this problem is not then eventually the CPU will fail.
Check the fan and if it does not spin freely then it needs replacing.
If the fan and heatsink assembly is clogged with dust, then remove the dust.
Aug 25, 2010 | KDS Valiant 6380iPTD-01 Notebook
When I turn on the power, the fans start to turn but then quit after a couple seconds.
hi,
i,d suggest CPU/Memory or motherboard Fault.
try removing 1 stick of memory, then re-boot. ( if theres 2 In )
remove the cpu fan, Check for Dust Blockage, remove CPU. And re-seat-seal-replace Fan. ( re-boot )
remove power from Case ( mains power ) remove side panel, locate CMOS Battery ( Silver coin-Cell ) On motherboard for 10 Seconds, then replace, repower and boot up.
Any of these could resolve your problems.
Mike @ Compurepair.
Nov 03, 2009 | MSI MS-6523 Motherboard
Laptop fails to boot. no post beeps no video Power light comes on Hard Drive light comes on briefly and the Drive can be heard spinning up then stopping. Laptop was originally purchased in North Korea
Clean first its ram module edge connector with soft eraser. But disengaged first its battery, power source and completely shutdown.
Then put it back and try to boot. If this doesn't help let me know . Leave a comment.
Apr 23, 2009 | Computers & Internet
MSI MS-1034 (1034B039) Barebone Logo
110 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
