Modelmdg9206aww- flame goes on for 10 seconds than shuts off for about 45 to 60 seconds than goes on again for about 6-8 seconds and repeats this for the duration of timed cycle.Hope you can help, Thanks
  • hmannwi Feb 03, 2010
    maytag dryer flame goes on for about 10 seconds than goes out then after about 45 to 60 seconds flame goes on for about 6-8 seconds and continues this for the duration of the cycle. The igniter does not stay on after flame goes out. maytag model mdg9206aww. hope you can help, Thanks John
  • 1,531 Answers
This might be a problem with one of the hi limit thermal fuses tha detect the amount of heat passed through the system.the electric igniter could also be failing by not drawing the correct amount of voltage through to keep the gas valve open
Posted on Feb 03, 2010
  • 10,515 Answers
You need to replace the small black coils on the gas valve.The troubleshooting chart says it could also be the radiant sensor.
Does the igniter glow after the first flame goes out?
If NO, then you need to replace BOTH the parts. If YES, then replace Black Coils.
Both the parts are Cheap and easy to Replace.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 02, 2010
Burner comes on for about 30 seconds then goes off. after a little while it lights again. then goes off again. this repeats 4 or 5 times then furnace shuts down completely. gas supply problem?
That's usually your flame sensor. If the board doesn't detect a flame after burner is running it will shut your gas valve down. You can usually fix this by cleaning the flame sensor with some extra fine steel wool.
Dec 26, 2016 | Heating & Cooling
LG dlg0332W gas lights up for 4 seconds and goes out for 5 minutes and repeats
It sounds like a plugged or restricted exhaust vent or blower wheel might not b spinning, check blower and belt:)
Nov 30, 2013 | Dryers
Burners kick on for 10 seconds then kicks off will keep repeating this
Hello, sounds like the flame sensor needs to be cleaned with steel wool. The flame sensor is a metal rod located on the opposite side of the igniter that senses the burner flame and will keep the Furnace running, what happens is the rod builds up oxidation and then cannot sense the burner flame and will shut the burners down and keep repeating. Just remove the sensor and clean with steel wool and reinstall.
Dec 08, 2011 | Weather King 10AJA3001AH Air Conditioner
Igniter goes on blower runs for 30 seconds main heater flame ignites and burns for approx 30 seconds then it shuts down for approx 10 seconds and repeats the same sequence 3 times, then shuts down...
there should be a flame detector sensor. it is in the flame. this will need to be cleaned with a wire brush or scrapped with something to get the carbon build up off of it.
you will see something that in in the flame area that is kind of charred and black with a wire coming out of it.
this is designed to tell the unit that there is a flame present and if that flame is not there after serveral attempts it will shut it down. because it there was no flame there you would get gas fumes pumped into you house.
you could change it out or usually you can just clean it and it will work fine.
hope this helps
rick
Jul 15, 2011 | Kitchen Ranges
Ignitor stops working gas shuts off within 10 seconds
The gas turns on and off repeatedly all during the drying process. You could have a weak flame sensor. Sometimes these dudes take longer to cool down and regain continuity with age. Seen it.
Mar 07, 2010 | Dryers
Hvac
dirty flame sensor
Oct 28, 2008 | Goodman Heating & Cooling
KENMORE gas dryer
Hi .No The Solenoids Are Turning The Gas On . I would Check The Venting . Remove The Venting Clean All Venting. Thanks The Appliance Doc
Oct 03, 2008 | Kenmore 73952 Gas Dryer
Gas dryer
hi. no not now. i would check the venting. clean the venting. thanks the appliance doc
Oct 03, 2008 | Kenmore 73932 Gas Dryer
Washing Machines Logo
Top Washing Machines Experts
