Question about Sanyo Vacuums
Help how do i change bags on sanyo transformax 3in1 vac how do you open it, i havwen't a clue?
2 Suggested Answers
SOURCE: Where/How do the Sanyo Transformax
Use a hammer to pry it open.
Posted on Jun 28, 2008
How do we open the Sanyo Transformax 3 in 1 vacuum cleaner? The bag is full and we cannot get it open. I do not have a smartphone. Can you call me on my home phone?
besides the fact that you have not given a phone number ( very unwise on unsecured web pages) we don't make calls
you can get that information by ringing the local service agent yourself
Aug 13, 2017 | Sanyo Vacuums
I am trying to change the bag on my sanyo transformax 3in1 vac, cannot open it how do i open it?
This video may help you. Also you might find the manual at this site: http://homeappliance.manualsonline.com/manuals/mfg/sanyo/sc15m.html
Nov 16, 2016 | Sanyo Vacuums
Bag needed changing there was no burn ing smell or strange noises before i changed bag after bag was changed it wouldnt start. the cord is new no fraying and vac is about 5 years old. didn
I'm not real experienced with this model vac, but I do know that many of the newer vac's are being manufactured with a small button or lever, whatever the particular brand of vac decides would best fit on their unit, that would be located somewhere around the edge of the bag door opening and would need to be depressed by having a bag inside in order for the machine to run. I would check for something of this nature to be sure that during the bag change that you didn't just miss putting it in quite right to depress the go button. Other than that, it's entirely possible that the switch died. If that's the case you'll need to bring it in to a vac repair shop for help.
Nov 11, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Bag full indication comes on; changed bag; still wont run.
Turn the knob on the top of the vacuum all the way to the right and try it again
Jun 15, 2009 | Electrolux UltraLux 2000 Bagged Canister...
I need to know how to change my kirby into a blower?
Raise the light assessory on the front of the vac. Remove the roller assembly by rotating the square dial as indicated by the arrows. Then you must attach the accessory that sort of looks like a 4 inch square open box to the front of the vac where you removed the roller assembly and lock into place. Next you remove your bag assembly by unsnapping at the top of the handle to the vac, then at the base of the bag assembly you must unlock the plastic base from the metal vac unit by turning it counter clockwise and then pulling off. Finally you attach the hose assembly where you removed the bag assembly and lock into place by turning clockwise (reverse of taking off bag assembly base). Put vac in neutral and power on. Now you will blow from the hose assembly.
Apr 20, 2009 | Kirby G4 Bagged Upright Vacuum
Lid will not snap shut over vac bag on kenmore magic clue
You have probably closed it by now :-) but when this happened to us we found that if we opened the tool compartment on the lid, the main lid then closed on the bag with a tiny bit of jiggling around. I don't know why, but this worked.
Nov 30, 2008 | Kenmore Vacuums
I have been given a Sanyo upright vacuum cleaner. It is a Performax 10.0 amps, Model SC-A102. I cannot locate bags for it. I live in Houston, Texas
Two solutions come to mind---1) Find a local vac store, NOT a department or big box store, and bring the bag to them.Sometimes on the bag is an identifying letter or number and on many you need to remove the bag to see it. Also bring your make/model info.Many manufacturer bags are for identical machines that have been labeled for a retail chain.Panasonic product with a Kenmore label for instance.
2) Ebay has some of the best deals and widest array of harder to find bags,filters and accessories.Good Luck-Scott
Oct 09, 2008 | Sanyo Vacuums
Need to change bag
here's the link to the instruction manual; http://sanyoservice.com/pdf/images/SC-180E.PDF (it is for the sc-150 and sc-180) Check page 8 for details. Hope this helps :)
Jul 31, 2007 | Sanyo Transmax SC-150 Bagged Upright...
Vacuums Logo
260 people viewed this question
Top Sanyo Vacuums Experts
Gerry Harvey
Gerry Harvey
ray gallant
Roy May
Are you a Sanyo Vacuum Expert? Answer questions, earn points and help others
