Kenmore Elite Oasis 27052 Top Load Washer Logo
Posted on Feb 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water leaks under washing machine
I own a Kenmore Oasis top load washer model # 110.27072600, serial # CT 1671357.
My problem is water leakage. When the washer fills there are no leaks. When it goes into wash cycle there does not seem to be any leaks. While laying on the floor with a flashlight I can see water dripping when the washer goes into rinse cycle and the spin cycle. I think the little bit of water from the spin cycle is just cast off from the major leak. The water seems to come down in a circular pattern in the middle of the machine. It is not a great deal of water, but it varies with the load size. Is there any sort of gasket around the agitator , or maybe a seal around the tub, or the motor housing ? Any suggestions would be helpful .
  • bphillips032 Feb 27, 2010
    How do I open up my top load washer to get the the drain pump?
Anonymous
Level 2:
Scholar:
  • Expert 91 Answers
  • Posted on Feb 03, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
91
Questions
0
Helped
28545
Points
215
SOUNDS LIKE YOU MIGHT HAVE A WORN OUT DRAIN PUMP, YOU WILL HAVE TO OPEN IT TO DO A VISUAL CHECK ON IT,
I have a Kenmore Elite Oasis HE top load. The machine sounds like a thunder when it spins, and also a pond of water leaks on the floor.
Check your hoses for leaks or possibly the drain it's draining in is clogged or half clogged or too clogged to accept large amounts of water all at the same time. Not to sure bout the thunder part. Lol
My kenmore elite washer model # 110.24082200 is leaking from bottom. No visible leak from back panel acces...
my kemore whasing machine model10010 .25864400is not drain all c los left sam wather in dram and sound of water pamp like cenot turne tenks Bruno
My kenmore oasis washer has started leaking out water and flooding my floor. have you had any other complaints about this problem and how to fix it.
first of, you need to find out where the water is originating from, pull washer away from wall and look for water dripping. usually water leakage starts from pump. on this washer there is a circulation pump and a drain pump on bottom left and right side. check all hoses and enure that there is no pin holes started
It leaks a bit of water every wash
Check all of your hoses and see if it is wet. Don't neglect to check the water supply hoses for your hot and cold water. 9 out of 10 the leak is directly under the washer so if you can tip it on it's side you will a good view of the underneath carriage. Good Luck
2helpful
How do i get the top off of a top load kenmore oasis washer to look at the water pump
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
KENMORE WASHING,wATER IS LEAKING FROM THE BOTTOM NOT THE HOSES
Possible circulation or drain pump leaking or associated hoses. See page 11 Oasis Tech Sheet
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3helpful
Water leaking from bottom ofoasis top loading machine
you may not be leaking out the bottom. Your stand pipe may be clogged. If the stand pipe has a slight clog in it, the stand pipe will over flow, and the water "looks" as if its leaking from the bottom... These pump faster than your old machine, so the pipe will back up faster... hope that helps
Sometimes,water leaks out from under washer. the amount is cleanable with two large bath towles. Machine is just out of warrantee. Please advise
I suggest that you check the screw holding pump motor to pump, if they get loose water will leak
or check the short hoses from pump, clamps may abe loose
Agitator ( nutator) will not function
what is a nutator?i found one time that there's a gear under the agitator that wears and the agitator doesn't move,remove the agitator and you'll see a part with 6 screws in it under that is the part you need to change part W10820039
Alexander
vince
