Question about Admiral AAV7000A
Motor pulley seperated is there a replacement pulley? or is it only with the motor? AAV7000AWW washing machine, looking on various parts list and the motor part #1 and the pulley part # 12 have the same part number $130 for a plastic pulley seems kinda high. I replaced the belt did one small load and then the pully broke on a normal load I figure because the belt had stretched and was spinning on themotor pulley but still had enough tension to work the machine by the rubber dust in the area.
  • 1073 Answers
SOURCE: Admiral Model #AAV7000A Washer
replace the pump
Posted on Apr 10, 2008
ginko
  • 19396 Answers
SOURCE: admiral washing machine AAV7000AWW won't stop filling or agitate?
It is either the inlet velve or the cycle programmer faulty
Posted on May 24, 2008
SearsTechToo
  • 261 Answers
SOURCE: Top load washer Admiral # AAV7000AWW
I would replace the belt part # 21352320 which cost about 20 bucks. Tilt the machine back when off and empty and look for a glazed belt with maybe some cracking and wear.
Posted on Oct 04, 2008
duby1990
  • 370 Answers
SOURCE: I cannot get the drive belt back on my Neptune washer
Its not an easy task but you have to barely get one side to hook or touch the pulley and then roll it on. When you get it started it should roll on pretty easily
Posted on Nov 21, 2008
  • 18 Answers
SOURCE: Washer belt is loose, & seem to slip at start of spin cycle.
there are several drive belts for this model... check here to see if the one you are fitting is the correct one... also,is the tensioner siezed? causing the tension to be too slack therefore allowing the belt to shred at speed?
check here .. http://www.partselect.com/AppliancePartList.aspx?Brand=Admiral&Appliance=Washer&ModelNum=&Type=Belt&MinSize=U&MaxSize=U&Electrical=U&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Posted on Dec 08, 2008
My admiral AAV7000AWW washer makes a loud chattering noise and leaks water..An solutions?Thanks a bunch
Chattering could be a shaft bearing and if it got bad enough could have damaged the tub seal and makes it leak. attached is a price on parts if your interested
http://www.appliancepartspros.com/07-tub-parts-for-admiral-aav7000aww.html
Jan 07, 2012 | Whirlpool Cabrio Washing Machines
It does not spin - error
Hi
Open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place.
Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley.
Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness.
Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
However there are various reasons as to why a washing machine won't spin. Also check this bellow link to troubleshoot your issue:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntspin
May 03, 2011 | LG Washing Machines
Wont drain. It looks like the pulley that is at the bottom of the pump assembly fell off (the belt came off as well). Can this be re-attached? I didn't find any screw near where the pulley fell.
The pump does not have a belt driven pulley.
The motor and transmission both have pulleys. My guess it's from the transmission
Check out the diagram labeled TRANSMISSION and look at the parts listed below it.
You can order a complete bearing and pulley kits from Sears:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-PAV2300AWW/3048/0153200?searchedModel=PAV2300&blt=
Jan 21, 2011 | Maytag PAV2300 Top Load Washer
My washer fills and rinses but wont drain and spin
Hello there:
I will post both solutions so that you can clarify what is going on please check them out fully
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
I will post the rest of the solution in a seperate comment so be sure to read it
Nov 12, 2010 | Washing Machines
My Bosch WFL 2450 WASHING MACHINE MAKES NOISE BUT WON'T SPIN , IS IT THE MOTOR?
Yes its the motor fault.It can be blocked or faulty motor or short in motor connections.It has to be checked and confirmed.but if motor and its connections checked ok then other possibility is your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Washing Machines
I HAVE A ADMIRAL WASHING MACHINE THAT NEES NEW WATER PUMP MODEL NUMBER IS AAV7000AWW DOES ANYONE KNOW WHAT THE PART NUMBER WOULD BE
try looking up
21001873
this should be available through most of the dealers
its an old maytga number but should still work
try sears i think they sell it fo 50 - 60
Oct 02, 2009 | Washing Machines
AAV7000AWW washer
sounds like the thrust bearing is worn causing an imbalance on the shaft. check herehttp://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=AAV7000AWW&mfgModelNum=&fkMfgID=1:- for a schematic on this machine and parts as listed.. hope this is of some help
Oct 22, 2008 | Admiral AAV7000A
Sep 01, 2008 | Admiral AAV7000A
Admiral AAV7000A Logo
62 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
