Question about Sharp AL 1631 Copier
Hi There, Our copier is making a horrible
Hi There, Our copier is making a horrible clicking noise. Its coming from where the toner is. Somewhere inside there. Is there anything I can check on it.
  • Sharp Expert
  • 1,326 Answers
Have you resently added toner? If so, try to reinstall the toner. Odds are that you will need the fuser rachet driver gear. Also, on the toner cartride, did you remove the cover for the waste toner??? You may have a packed waste toner feed screw... Good Luck
Posted on Feb 03, 2010
Clicking noises coming from konica minolta di2010f copier after changing toner cartridge
Using the correct toner bottle not a EP2010 bottle or biz hub toner bottle, make sure using the correct bottle, if correct bottle turn the machine off remove the toner bottle turn the machine on without the bottle in it. let the machine do its thing when it ask for toner install the bottle correctly. if the nub on the bottle is damaged then get a new one that is what the toner bottle motor uses to turn the bottle if it is damaged its clicking because its trying to turn the bottle.
Sep 17, 2012 | Minolta DI-2010F Copier
Samsung clx-3160fn won't print
Usually I've seen that happen when you use generic toners. There are 4 toner clutches down the right side, with the right cover off you can see which clutch is doing the grinding. Many of the generics are overfilled and hard to turn and will make the noise until you loosen them by hand turning them til they loosen up, or just replacing.
Dec 28, 2009 | Samsung CLX 3160fn All-In-One Printer
Copier making loud noise
Remove the drum/toner unit and close the top,...does it still make the noise? If so, there is a paper jam in the fuser section (left side)
I also have a Canon PC900 series copier....mine does not have the automatic document feeder, however the machine is the same....If the noise persists, you will probably need to replace the Fixing (fuser) Unit drive gears (worst case senerio) perhaps you can locate the jam in the fuser and "carefully" remove without damaging the Fixing Belt....good luck
Jul 02, 2009 | Canon Office Equipment & Supplies
HP Color Laserjet 2840 now makes ear-splitting whine every time
Did the noise start right after you replaced a toner? If so it must be a bad toner which is causing the gears to grind. If this noise happened out of the blue then it might be a bad fuser drive gear which is the gears that connect the fuser to the machine.
Jun 25, 2009 | HP LaserJet 2840 All-In-One Printer
My HP laserjet 1200 is making a terrible noise when printing - do you have to oil the rollers?
No Please don't oil any part of the printer, oiling may damage the complete printer first check if the nopise is coming from rear, Top, Front or side.
If noise is coming from Top than possibly top outbin roller are making noise.
If side tham may be toner cartridge or cartridge motor is making.
If noise is coming from rear than either fuser or the gear which rotates the fuser are making noise.
If noise is coming from from than Tray 2 pickup assembly or faulty tray is making noise possibly faulty registration assembly can also mak noise none of the part should be oiled only the faulty part should be replaced.
May 11, 2009 | HP LaserJet 1200 Printer
Grinding noise at startup and printing, AL-1655CS
is there some paper or something inside
just a thought
Feb 04, 2009 | Sharp AL-1655CS Copier
Lexmark C510 Laser Printer- Grinding Sound on startup and while printing
Thank you Krissy! I had the same problem with the horrible grinding noise.
I took out all of the toners and the photo developer and noticed that my Blue toner was leaking all over. After reading your post, I tried replacing the toner. It worked!!! No more noise - and no more mess!
Jan 30, 2008 | Lexmark C510 Laser Printer
Loud groaning noise when copier is turned on.
sounds to me like the laser unit is going bad. common problem on this model.
razors
Nov 28, 2007 | Copystar CS-1510 Copier
Sharp AL 1631 Copier Logo
103 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
