Question about Dell Dimension 9100 PC Desktop
Dell dimension 9100 winxp will not detect camera on USB port or internal card reader
    Brigadier General:
  • 3,917 Answers
There are two possibilites. Either the usb port have gone bad or the drivers need to be updated. First try to connect the weeb camera in another usb. If all the usb does not detect it then first try to download the chipset drivers from the link bellow:
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R114566&SystemID=DIM_P4_9100&servicetag=&os=WW1&osl=en&deviceid=3268&devlib=0&typecnt=0&vercnt=2&catid=&impid=&formatcnt=1&libid=27&typeid=-1&dateid=-1&formatid=-1&fileid=150654
Next if it still does not work try to plug the camera in a different computer. I am sure the camera is good. Then you need to call dell to have the mother board replaced.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 02, 2010
How do I upload pictures onto my Dell d600
If your photos are stored on a SD memory card then remove the SD memory card from the camera and insert the memory card into an USB memory card reader. Connect the USB memory card reader into the USB port of your Dell computer. The Dell wiil detect the card reader as an external storage device, you can then open the folder on the memory card that contains the photos and then copy them to your computer.
Feb 11, 2012 | Dell Latitude D600: Pentium M 1.6GHz,...
Dimension 9100 PC Desktop: no sound dell dimension 9100...
Make sure physical cables are plugged in correctly from speaker to audio ports. Check audio driver if installed, if not you can download the driver from the dell website:support.dell.com.If driver is propely installed check sound/volume settings, make sure nothing is set to mute...Hope this helps...Cheers!!!
May 17, 2010 | Dell Dimension 9100 PC Desktop
How to install a sd card reader on a Dell Dimension 8200 PC Desktop? no 4 pin usb on motherboard?
I managed to install a card reader on my Dell Dimension 8200.
The main problem is that the Dell motherboard does not have the correct USB pin. This is a 9-pin MoBo USB header.
The quick answer is I installed a USB card with an internal port.
http://www.amazon.co.uk/Unbranded-USB-2-0-PCI-Card/dp/B00066LPA2/ref=sr_1_6?ie=UTF8&s=electronics&qid=1264968643&sr=1-6
Secondly I reverse mounted a powered 4-port USB hub in the spare 3.5" bay.
http://www.cablecity.co.uk/product_info.php?products_id=1149&ref=6
Third, I purchased 2 USB 5 pin male to usb leads...
http://www.amazon.co.uk/v2-0-Male-Motherboard-Header-Connector/dp/B000QC7NKM/ref=cm_cr_pr_pb_t
You cannot buy a USB card with 2 internals and do away with the 4 port powered USB hub because the card reader does need to be connected to a powered USB port.
for more info see this...
http://www.mods-n-clocks.co.uk/?p=181
Jan 23, 2010 | Dell Dimension 8200 PC Desktop
Altec Lansing ADA995 Speaker system partial speaker play
Drivers and support softwares for Dell Dimension 9100 are still very much available to Dell's website (here). Download the audio driver for your StaCruz Audio card.
Hope this helps. Please don't forget to rate.
Nov 07, 2009 | Altec Lansing ADA995 Speaker
USB Header
The only way is to purchase a USB Board to install in the PCI slot, but that would be overkill since you PC already has 4) 2.0 USB ports. I would exchange that internal reader for an external reader.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | Dell Dimension 2400 PC Desktop
Internal USB connector
You did not have to unplug the onboard USB ports.
Your OS should see the card reader and set it up, unless you are using Win98 or WinME. I would plug the onboard USB ports, then restart with the new internal card installed.
Sep 26, 2008 | Dell Dimension 4600 PC Desktop
Imstalling internal card reader
Well, installing an internal card reader without a spot on the motherboard, is a little hard to do. I would suggest buying an external card reader. They are a little cheaper, and a lot easier to setup and use, since they just connect to a USB port which all computers have.
Feb 23, 2008 | Dell Dimension 3100 PC Desktop
Installation help for dynex dx-crd12 all in one card reader
I would recomend installing the card reader this way. Shut off all programs that you don't need during the start up. When the card reader installs its kind of touchy, froze my computer a few times.
If you have blue 9 pin usb headers on your motherboard, consult your manual for this, or google it. Take the 5 pin connector, find the side with the red wire, face that side away from the side of the blue header with a missing pin. Make sure you connected to the row with 5 pins. After that you should be able to power up your computer and it will work.
If your computer doesn't reconize the card reader use the cd it came with.
Nov 10, 2007 | Electronics - Others
Dell Dimension 9100 PC Desktop problem
I'm not sure where the floppy drive comes in, but if you have usb connectors on your mobo then you can connect the 5 pin connector to half of the usb pins.  Try that and see what happens.
Oct 25, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Pics not transferring to the computer
If you have camera software installed - take it out. Now try If the Camera/Card are functioning Windows Scanner/camera wizard should sort it. If that fails take the card out and try to get the use of a card reader or another computer or processing station - you have to prove Camera/Card/Computer which is not doing the business
Aug 12, 2007 | Canon PowerShot A520 Digital Camera
Dell Dimension 9100 PC Desktop Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
