Question about Zebra QL 320 Thermal Printer
Cleaning ql320 printer w/ cleaning pen - Zebra QL 320 Thermal Printer
How do I clean a sheaffer fountain pen, it's plunger type ie you push and pull the plunger to load the pen with ink.
methylated spirits is the best cleaner to use ( alcohol based cleaners )
sometimes if you load the pen and it is not full, tip the pen vertical active the plunger again the dip it back in the ink and do it again
That will ensure that a second go fills the pen properly
May 01, 2016 | Office Equipment & Supplies
The black ink does not work even with a new one.
Dear friend., This is tricky model printer.. U re just replaced the ink tank, not print head. Seems Print head was clogged..
For example 1. suppose you filled ink in fountain pen, if nib is faulty pen wont write.. 2. If you are using ball point pen, replacing the refill again it will work. We can say your printer as same as fountain pen. Only way is go to the nearest service center ask them to clean the print head nozzles, there is no other alter because, to reach print head lot of mechanical parts has to be removed which i can't suggest you to do so & there is no replaceable print head in side., sorry no help from my side..
Mar 13, 2014 | HP Photosmart 3110 All-In-One InkJet...
How do i reset the printer to factory defaults?
Send a command to the print
^default should do the trick
use hypertherminal or a windows driver to send this command
May 16, 2011 | Zebra QL320 Printer
How ot change the font size, printed on QL320 plus Zebra printer
Contact Zebra Technical Support Phone: +1 877 275 9327
Fax: +1 847 913 2578
Kiosk Only: +1 866 322 5202
**Best Option will be to call them since it is a mobile printer**
Mar 10, 2011 | Zebra QL 320 Thermal Printer
How to calibrate the label in QL320 plus zebra printer?How to make it only feed 1 label per print?
create a text file called Calibrate.txt and in the text file type this:
~JC
^XA
^JUS
^XZ
then send the file to the printer using label vista.
this will then print 3 - 4 labels and stop.
once u press the feed button it will only feed one label.
Dec 10, 2010 | Zebra QL 320 Thermal Printer
How can we change from black bar sensor printing to using the gap between labels on a Zebra QL320 plus?
First you need to send below file to the printer via Vista Label
Printer >> 1 Send File
Save this file as gapsen.txt:
! DF CONFIG.SYS
! UTILITIES
GAP-SENSE
PRINT
To save this as default setting, send below script (save as setting.txt)
^XA ^JUS ^XZ
Nov 03, 2010 | Zebra QL 320 Thermal Printer
Zebra QL320 plus no bluetooth discovery
Turn the printer up side down and remove the battery. Undo the philips screw and remove the module from the top. re-seat it back on the main PCB and replace the screw and battery. if the module still doesn't work then it is more than likely it has failed.
Feb 12, 2010 | Zebra QL 320 Plus Thermal Printer
Powers down after every print
There is a setting in the all CPCL based Zebra mobile printers called "DTR Power Off". You will need to turn disable this. It sounds like you are printing through the serial connection based on your brief issue description.
Connect to the printer with serial cable and run the Label Vista application, free from Zebra.com. If your printer is a Q3C or Q3D configuration, you can connect with a mini USB cable, but you will have to install the driver. If you have a Q3A or Q3B configuration, you must to use the serial cable (PN: BL11757-001) to connect to your PC.
Once in Lavel Vista, click on the Printer drop down and choose the COMM Port Settings option. Select the correct value for your connection type. Next, select Printer Settings from the Printer drop down. Go over to the Port tab and click the disable button under the DTR Power Off section. Click apply. If this does not work, also check your inactivity timeout setting as well as your battery level setting in the batery tab od the same screen. I set mine to "0" because I dont want my printer turing itself off for any reason.
Apr 04, 2009 | Zebra QL320-Plus Mobile Printers QL320...
Zebra QL 320 Thermal Printer Logo
178 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
