Question about GE Refrigerators
Model # GSS25IFRF CC My water dispenser in the
Model # GSS25IFRF CC My water dispenser in the door does not dispense water, cubed and crushed ice dispense fine.
  • markp0716 Feb 02, 2010
    All of a sudden the water dispenser stopped working, cubed and crushed ice work fine. I can hear the click when pressing the lever.
aborcass
  • 2651 Answers
SOURCE: ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
Posted on Mar 25, 2008
  • 184 Answers
SOURCE: Ice dispenser only dispenses crushed ice
THE WAY A DISPENSER CHANGES FROM CUBES TO CRUSHED ICE IS BY RAISING AN ARM THAT RUNS ALONG THE BOTTOM OF THE ICE BIN. IF IT SETS FOR A LONG TIME, IT CAN GET A BUILUP OF FROST OR ICE THAT KEEPS IT FROM MOVING. PULL THE ICE BIN OUT AND TRY TWISTING THE END OF THE ARM MANUALLY. IT SHOULD OPEN A DOOR AT THE FRONT OF THE BIN THAT WOULD ALLOW THE ICE TO BYPASS THE CUTTER ASSEMBLY.
ALSO,WITH THE ICE BIN REMOVED, PUSH THE DOOR SWITCH BUTTON CLOSED BUT KEEP THE FREEZER DOOR OPEN. WHERE THAT ARM GOES IN THROUGH THE BACK WALL, CHECK FOR MOVEMENT OF A ROD UPWARD WHEN YOU CALL FOR CUBED ICE. IF YOU HEAR A LOUD HUM BUT THE ROD DOESN'T MOVE, YOU MAY NEED TO REPLACE THE SOLENOID ASSEMBLY IN THAT MODULE.
Posted on Apr 10, 2008
ghappliances
  • 126 Answers
SOURCE: kitchenaid side by side model ksrs25ikss01
CHECK YOU SECOND VALVE IS WORKING IF THATS OK YOU MIGHT NEED YOUR ICE MAKER CHECKED AND SERVICED.GOODLUCK.MOHAMED
Posted on Sep 12, 2008
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
Water and ice cube dispenser working fine, crushed ice not crushing. 26 cuft side by side model MZD266SHES
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid. Crushed ice is the default position and the solenoid is energized to cube ice.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Feb 21, 2011 | Maytag MFI2568A Side by Side French Door...
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
Apr 17, 2009 | Refrigerators
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Nov 05, 2007 | Frigidaire FRS26KF5C Side by Side...
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Oct 23, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
143 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
