Question about Amana ABB1927DE Bottom Freezer Refrigerator
How do you tighten up the handle on the bottom drawer for the freezer?
  • 52 Answers
Look under the handle where it meets the fridge itself, there should be a small hole, you will need a allen wrench to tighten.
Posted on Feb 04, 2010
The handle on the bottom freezer drawer is loose and i caqnnot tighten it by using an allen wrench in the 2 bottom holes - - is there a trick to this???
Sometimes the studs that the handle mounts to become loose themselves. If you remove the handle entirely and look at the studs, they will have either a phillips head or they will be hex-headed so you can tighten them. Carefully snug the studs down (do not over-tighten) and re-install the handle. This should solve your problem.
Let me know if you need more help
good luck
Aug 11, 2010 | Jenn-Air JBL2086HES Bottom Freezer...
Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Apr 08, 2010 | Samsung RF265AA Bottom Freezer French Door...
Freezer handle falls off on one side , kenmore elite - pull drawer freezer
Mine does that too. I've simply accepted the fact the the screw holding the handle on just loosens over time. Periodically, when I feel the handle becoming loose, I tighten it with an allen wrench and go on.
Feb 21, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Handle on bottom freezer drawer is loose.
Take the handle and slide to the left as far as it could go to tighten handle. This worked for me.
Jun 26, 2009 | Maytag MFI2568AE Side by Side French Door...
Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
Feb 12, 2009 | Amana AFD2535DES French Door Refrigerator
Bottom freezer door handle loose
There is a plastic card that you are supposed to slide under the right side of the handle. Once you have done this correctly the whole handle should slide off to the left.
Nov 14, 2008 | Amana ABB1927DE Bottom Freezer...
Freezer drawer handle loose...how do I tighten screws?
With a screwdriver?
Screws in plastic will wear with constant use , take the screw right out and wrap it with aluminium foil, then replace
Jan 24, 2008 | Jenn-Air JCB2059G Bottom Freezer...
Bottom Freezer door handle
I had the same problem. It took me an hour to figure out that the bottom freezer handles clips onto the door using butterfly clips. To tighten the clips you have to remove the handle by sliding it to the right (or left??) It snaps right out with a quick **** exposing the clips underneath. A quick tightening of the clips and the handle snaps back in.
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Loose freezer door handle
Maytag uses two types of door handle mounts. first look at the bottom side of door handle to see if there are tiny set screws. If there is you might just have to tighten them with an allen wrench. If it doesn't you need to grasp the handle firmly and pull it towards your left, sometimes they can be a little stubburn and require a light wrap with a rubber mallet. This will remove the handle. In this case there will be a clip inside the handle end, check to see if it is bent or if the handle itself is cracked, although I have seen some where the handle mount has become loose and that can be tighted by turning clockwise.
Jul 04, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
165 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
