Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Printhead status is fine. Have a solid black line on right hand side of paper when copying or scanning
    Problem Solver:
  • 18 Answers
  • 3 Answers
Check & clean your scanner- glass
Posted on Feb 10, 2010
Black line scan
Open the scanner lid and clean the narrow glass in the left-hand part of the scanning area. Look for remains from ink or corrector at the far end and wipe them out. The narrow glass should be entirely clear to make good copies from the feeder.
Jan 09, 2014 | Canon Pixma MX410 All-In-One Printer
Copies nothing but solid black paper
Printing from system is OK? Do scan and check.not proper ? check CCD unit & cable..
Suspecting 80% CCD unit(Unit under flat bed glass moves while scan or copy with lamp)
20% cable(flat ribbon cable connected between CCD unit & Formatter) see the snap shot for easy recognition of CCD7_15_2012_3_12_34_am.jpg
Jul 13, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Canon Pixma ip1500 is printing but very wierdly. random lines will not show up in black. If i change the color everything is fine but black will skip lines and such. Please help! Can't turn in job...
Your printhead is plugged and needs cleaning. If you remove the inks and then the printhead, you can wet and fold a paper towel and just dab the printhead gently on the wet towel. When you see a solid black line on the paper towel your printing should be improved.
Jun 23, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
HP Photosmart C3180 prints a solid black line left side of paper ONLY when you COPY. When you print from computer, it prints just fine. It is only from COPY mode that the solid black line appears.Already...
Unfortunately, your C3180 printer needs some repairs done to it or you . A section of the printing arm that does the printing is faulty. This happened to me and apart from replacing the arm (at considerable cost) I purchased a new printer at a much cheaper cost. You can use your faulty printer for printing from the computer but not for copying or scanning. MG
Jun 08, 2009 | HP Photosmart C3180 All-In-One InkJet...
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
razors
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
Canon D860 - I get a solid black line when I use paper feeder.
I'm pretty sure you might have solved this problem already, but this might help others.
Make sure that the platen glass is clean near the right side of the machine, where the document is scanned when going through the document scanner. Remember, when placing a document on the glass to copy it that way, you would place it on the glass on the left side of the machine. When scanning through the ADF, the scanning unit itself moves to the right side of glass and scans the document as it moves through.
We had the same issue and found out that there was a little spec of dirt on the glass. After cleaning it, the problem was solved.
Feb 03, 2009 | Canon ImageRUNNER 1670F Copier
Kodak Easyshare all-in-one-printer
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Aug 02, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
112 people viewed this question
Seeker5211
Seeker5211
