Question about Zanussi Washing Machines
Anussi ZWD 1271W stops at beginning of program
My Zanussi ZWD 1271W when on any wash program will fill with a bit of water as normal, spin one way then the other as normal the puts more water as normal but then stops, the timer goes back to the total wash time and the Start/Pause button light flashes and does no more. When trying to drain down the drum by moving to drain mode with the Skip button the machine stops again a minute before end of draining. Rapid reading of error codes shows E36. During running diagnostic mode after a few minutes an error code E35 is indicated. The same problem occurred previously a year ago. At that time engineers sent by an insurance company exchanged progressively a pressure switch and a control panel. They gave up after a few visits when kicking the machine failed as well. Although the last engineer tried to push randomly various buttons at the control panel and after this the problem disappeared up to now. Both problems current and a year ago started soon after cleaning the drain trap. Could you please advise the possible solution to this problem? Would resetting the control panel help and how to perform this?
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Posted on Jul 11, 2010
I have a Zanussi Washer/Dryer Model ZWD 1270W. When I set the machine to wash (any cycle), it fills with water, the water jet starts, it takes the soap powder then it immediately skips to the 'drain'...
http://laundry.manualsonline.com/manuals/mfg/zanussi/zwd_1270_w_zwd_1270_s_zwd_1470_w.html
If you go to this website, they have manuals and you can ask questions also.
Just one thought. Have you unplugged the washer for a few seconds then plugged it back in? It's possible the "brain" needs to be reset.
Nov 02, 2013 | Zanussi Washing Machines
When switched on the door locks and the pump runs for a few seconds then stops and the door opens zwd 16270w
an earth fault on the motor or heater can cause this. try the heater first disconnecting it and seeing if the machine can get past the fill stage .
Jul 31, 2010 | Zanussi Washing Machines
My Zanussi ZWD 1470W won't fill up with water. I
Story could be lengthly so in brief, check to see if drain pump is not blocked and if door latch is functioning correctly.(use a multimeter if you can). If it all measures out as good, then your control is faulty. Does the water fill up to the correct level when you start the cycle? Does the motor hum when trying to run. If so check the capacitor.
May 20, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
Cant get the back off a anussi fl1082
They normally use a torx screw with a pin in side the hollow so the tool you need has a hole in it to match this pin.If you cant get one sometimes if you get a small strong screwdriver you can snap yhis pin off then a normal torx. bit will do.
Hope this helps.
May 11, 2010 | Washing Machines
I am getting a Code E20 on Zanussi Washer Dryer ZWD 1271W
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 17, 2009 | Washing Machines
I am getting a Code E21 on Zanussi Washer Dryer ZWD 1271W. This is on the Dryer cycle everything else seems to work. Thanks
E21 Problems with water drain in wash phase
Check the drain hose and pipe for blockages.Replace the component if necessary.Good luck with the machine.Please do post comments and results.
Apr 15, 2009 | Washing Machines
Washing Machines Logo
799 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
