Question about Ovens
Display is flashing0.00 and auto. oven won't work, took out circut breaker still doesn't work. when trying to reset the clock high pitch sound comes on and have to turn oven off at wall to stop
  • Ovens Master
  • 3,463 Answers
It will not work if it is flashing, the timer needs to be reset to manual
If it will not reset, then It sounds like the timer is faulty, try a different combination of buttons when trying to reset it.
Hope this helps.
Posted on Feb 03, 2010
Multi purpose oven won't work after power cut have reset clock, light won't work. Is making all the right sounds just won work
power supply from clock damaged not by power cut but voltage spike when power resumed the oven thinks its in auto mode permanentley thats why it wont come on ,new clock or power board needed.
Feb 03, 2017 | Neff Ovens
Did I damage electronics after using auto clean feature?
Sounds like there may have been a power failure or problem with the voltage when you were using this or before you did. Try shutting off the breaker for 5 minutes, turn it back on. This will reset the board in the oven. Then see if it works. If it still is defective, the voltage 'surge' may have destroyed the board. You may be able to turn it in to your insurance if that is the case, as from a storm that took out the oven when it hit and the power went out and then came back on. A clue is the keypad lights go dim and brighter then dim again.
Mar 04, 2014 | Whirlpool RBS275PD Electric Single Oven
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Jul 06, 2011 | New World Ovens
The oven won't turn on. We are unable to set the clock either. The display flickers but doesn't display.
There are lots of different timers on fisher and paykal The last one I reset was a few weeks ago it involves pressing 2 buttons at the same time I think it was the oven on and oven off buttons but I am not sure You will know when you have pressed the right 2 buttons the display will stop flickering set the clock time using the up down arrow buttons The auto light should not be on if it is press the manual button Regards Geoff Stove Recyclers
May 29, 2011 | Fisher Ovens
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
The controls aren't working. the digital display
Turn off the circuit breaker that controls the oven.
Wait for a minute and then turn the breaker back on.
If the display comes back, reset the clock.
If it doedn't come back, and is still scrambled, you will need to call a service tech.
Nov 24, 2009 | GE Ovens
Try turning the oven circuit breaker off for a minute then back on. Reset the clock and see what happens.
Nov 22, 2009 | Fisher and Paykel AeroTech - OS302M...
Display doesn't work, but oven works
First turn the electricity off by locating the breaker to the oven and turn it off. Now wait for an hour or so and turn the breaker back on, if the display turned back on, you need a control board (other manufatures call it a clock, PCB or ECC but it's the main elctronic board with the diaplay built in). If it didn't come back on, turn the power off again and make sure all the wire harness's going to the board are connected good. Turn the power back on and it the display still doesn;t come back on you need to replace the main electronic control board. By the way double check the model number and brand because it might be wrong. Please post back.
Oct 04, 2006 | Whirlpool RBD275PD Electric Double Oven
Ovens Logo
193 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
