Question about Epson Perfection 4870 PHOTO Scanner
When I try to scan one 4x5 positive sheet film it gives me 6 thumbnail pieces rather then one image?
  • 63 Answers
Open Epson Scan and select Professional Mode. Turn off the Auto Thumbnail option which if it is not on the main page then check the small drop down menus next to the Scan/Preview options. Once that is off do a preview and the in the preview window manually draw a marquee around the area you need.
Posted on Feb 09, 2010
Can I scan a negative 4X5 black\white to make a photo
In general, yes, you can scan a negative and make a photo from it. I don't really know your model scanner, my Canon 8400f has a film adapter and a light in the cover, but would have to scan a 4x5 in sections and I would have to piece it together after scanning.
The results I get from scanning negs are very good, as good as I ever got in my darkroom.
Oct 31, 2014 | Canon CanoScan 8800F Flatbed Scanner
How to scan x ray film
scanning xray film is not possible in this model. you need a negative scanner to do that.
normally in software you have an option called negative. this option convert the positive image into negative. but it will not give exact output what we need. you can try this option also.
Oct 09, 2013 | HP PSC 1210 All-In-One InkJet Printer
When scanning old photo, scanner stretches the image. how do i get it to scan image to same proportion as original?
Open Epson Scan and select Professional mode. Turn off the Auto Thumbnail option. Leave the target size As Original and then do a preview. Once the preveiw is complete in the preview windows draw a marquee around the area you want to scan and select scan.
Dec 24, 2009 | Epson Perfection 4490 Film / Flatbed...
No thumbnail preview
Sorry , I don't know the answer to your problem , But I am experiencing sort of the same problem. When I place an image in the scanner , I do not see any preview thumbnails at all. I also do not see any of the preliminary questions as to the film format size or single or batch scanning. Nothing like that at all. I have called the tech's at Nikon and the scanner passes their over the phone examination. It appears my scanner is not been recognized by my computer ( I have tried both ) . Nikon suggested replacing the firewire cable which I did and still no preview thumbnails. I believe the problem is in the firewire interface panel ( where you plug the scanner in ) and I think this is where your problem lies also. It is a simple fix 5 maybe 6 screws. Getting the part number has been my problem. Nikon wants you to send in the entire scanner and have a flat $400 service charge . I'm sure the part is less than $400. Any ideas as to where to get the parts catologue ?? Let me know.
Sep 11, 2008 | Nikon LS-9000 Film Scanner
Scanning neg
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Jan 22, 2008 | Epson Perfection 3200 Photo Flatbed...
Epson 3490 does not find the slide I put in the correctly positioned provided frame
Dec 28, 2007 | Epson Perfection 3490 PHOTO Flatbed...
Scanner incorrectly reads frame position on film
Yes there is
Dec 10, 2007 | Epson Perfection V350 Flatbed Scanner
Epson perfection 4990 photo scanner
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
Unable to use film adaptor
1) In the program you are working from, begin the scanning process. If working in full auto mode, as the scan begins you will see a message that reads TO CANCEL SCANNING IN FULL AUTO MODE AND SWITCH TO MANUAL MODE, CLICK CANCEL. At this point, click CANCEL, then MANUAL MODE.
2) You will now see all Epson Twain settings displayed. If the scanner has not previewed automatically, click the full page preview button (icon of a paper with one corner folded down).
3) Ensure the settings on the right hand side of the Twain are correct. For example, the DOCUMENT SOURCE for transparencies must be either TPU: COLOR NEGATIVE FILM, TPU: MONOCHROME NEG or TPU: POSITIVE FILM.
FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes. (If you are scanning a black and white slide in true colors, choose TPU: POSITIVE FILM as the DOCUMENT SOURCE and BLACK AND WHITE PHOTO as the IMAGE TYPE.)
If the DOCUMENT SOURCE is flatbed, the scanner will not activate the backlight in the transparency unit. If the DOCUMENT SOURCE is greyed out and you cannot select a TPU option, close the twain, reseat the power/communication cable connecting flatbed to TPU, then re-open the twain and try again.
4) Ensure the other twain settings are correct for the type of scan you are doing.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no guidelines on this; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing an AUTOMATIC THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, click the CONFIGURATION button and uncheck AUTOMATIC THUMBNAIL PREVIEW FOR FILM, then OK, and try the PREVIEW button (page with corner folded down) again.
In this mode, you will have to manually marquee or crop the slides you wish to scan. Use the left mouse button to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process (manually crop then scan) for as many slides or filmstrips are on the bed.
Aug 16, 2007 | Epson Perfection 1200 Photo Flatbed...
Epson Perfection 4870 PHOTO Scanner Logo
104 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
