Question about Cyclops ® XRF Xenon Rechargeable Flashlight
I have a cyclops 2 cell witch uses the cr123a batteries.the bulb burned out . where can i get an replacement at
  • 283 Answers
The bulb may be purchased at most electronic stores such as Fry's or Radio Shack for under $2.
Posted on Jul 29, 2010
Bad blub where do i get another
These spotlights are, essentially, automotive headlights powered by small batteries. Accordingly, take your old bulb to an auto parts store and match it to one of the headlight bulbs they carry. You'll find many bulbs that look just about right; the key is to find one (or more) that has the exact same base as your bulb so that it'll just plug right into place.
Before buying a new bulb, you can also double-check your old bulb with a simple test for continuity. Properly treated, these bulbs have a reasonably long life, and I wouldn't rule out corrosion in the bulb socket or some other issue that's keeping your bulb from lighting up. Of course, if you can see the torn or burned out bulb filament, it's pretty obvious that you're going to need a replacement.
Jun 02, 2011 | Cyclops CYC-S250 Thor 2.5 Million Candle...
My cyclops flashlight suddenly quit! totally, abruptly quit. The batteries were not that old. Is this a common problem with Cyclops flashlights?
Depending on the age and type of the batteries it is possible for them to discharge quickly. If after replacing the batteries the light still doesn't work, check the bulb. If the bulb is burned out Fry's Electronics has them for under $3.00. If there isn't a Fry's near you, you may order replacement bulbs from the manufacturer for about $8.00 http://www.cyclopssolutions.com/contact_us.html
Oct 08, 2010 | Camping, Backpacking & Hiking
2003 Silhoutte, both lower brakes lights do not work. Bulbs or turn signal switch? Turn signals work okay. Cyclops works okay, fuses look good.
Bulbs are bad, most bulbs burn out around the same time withing a day or two and both of your brake lights may have gone bad. Try with the simple and inspect the bulb and replace if you see any discoloration to the glass on the bulb. Good luck and than you for using Fixya.
Mar 06, 2010 | 2003 Oldsmobile Silhouette
I need to find a replacement bulb for my cyclops flashlight
Tommy, the only apparent source for those special bulbs is from www.cyclopssolutions.com. I did not see replacement bulbs listed on their website. You can either call them at 877-269-8490
or send them an Email at: CyclopsSupport@gsmorg.com
Oct 16, 2009 | Cyclops ® XRF Xenon Rechargeable...
Stop lamp and cyclops light
If by the "cyclops light" you mean the third brake light, I went to auto zone and purchased 6 ea. part number 858352 instrument panel connectors and added number 194 bulbs to them. All you have to do is pull (gently) on the cover and it will come off. It snaps in place. Twist the bulbs 1/4 turn ccw to remove, insert new assembly and voila, you're in business. The other brake lights are behind the carpet in the trunk. Be sure to remove the correct bulb or you will replace the turn/marker lamp and still have a brake light out. Good Luck.
May 15, 2008 | 2000 Saturn Ls 4dr Sedan
LCD IS NOT WORKING WHEN CHARGEABLE BATTERIES IS PUT IN THE BP300 GRIP
ni-cad or ni-mh rechargeable batteries all have charging cycle life and will fall in effeciency. in saying that, batteries used for some time will be not be as powerful as the new ones, and over or under charged batteries also wouldn't give you expected power.
i guess the CR123A you replaced is a new one, so it has the desirable voltage and current.
LCD itself and the driver actually do not require a lot of power, but the camera does, which draws away from the battery.
pc-cook
Jan 25, 2008 | Canon EOS Elan 7 35mm SLR Camera
Cyclops ® XRF Xenon Rechargeable Flashlight Logo
248 people viewed this question
Top Cyclops Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Cyclops Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
