I am wanting to set the watchdog timer in bios than feed the dog via a process from user space so that when the system hangs the wdrt will rst the machine
  • johnfkav Feb 21, 2010
    Ok, thanks for the response. Thats OK, however the duration the bios provides to countdown is so short it doesnt seem to be of any real use. if you could set the time to be around 12 hours or so that may be useful. Thanks for comming back to me, sorry for the delay.
  • Computers & ... Master
  • 17,115 Answers
You have a misunderstanding about how the bios operates. You cannot program a call to it that is interactive with the functions that it performs. In otherwords it performs a task in a cycle. You get a certain output from the cycle that it performs. You cannot break into that cycle with a program call and vari the output. With watchdog enabled you should have the results that you are desiring.
Posted on Feb 03, 2010
I have machine MX3123 New Home - I lowered the dog feet - but it won't allow me to free hand quilt - what pressure foot do I need
You need a darning foot or free motion foot. They are shorter than standard presser feet, so they do not set on the feed dogs but hover just above. The additional space allows you to manipulate the fabric without interference from the feed dogs. (Be sure to drop the feed dogs or cover them with the supplied cover plate--whichever your machine uses.)
Feb 16, 2017 | New Home Sewing Machines
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
Could mis aligned feed dogs cause the machine to slow down as you sew? My machine slows down as I'm sewing.
This can be a problem and can be detected by simply removing the open arm cover and run the machine again to see if the machine runs free. Occasionally, the feed dog is misaligned but generally not by itself. The problem will generally be from an applied force where the open arm cover has been removed as in careless cleaning, some sort of repair attempt, or the actual removal of, and failure to align the feed dog properly. The feed dog can be aligned parallel with equidistance spacing between the outside feed dog bars and the slots in the needle plate. Further adjustments can also be made to the lateral spacing on the X axis as well as the position of the center bar on the Y axis, but I won't go there this time around.
Sep 09, 2014 | Bernina 1008
What does watchdog fault on siemens ems trolly means?
A watchdog fault generally indicates that something has taken too long, and something else (the "watchdog" timer) has giving up waiting for it.
Aug 12, 2014 | Siemens Computers & Internet
Save not cmos on mainboard asus p4p800s-x chek batry&clear cmos but not resolv save not cmose
ASUS CrashFree BIOS2
The CrashFree BIOS 2 feature now includes the BIOS auto-recovery function in a support CD.
Users can reboot their system through the support CD when a bootable disk is not available, and go through the simple BIOS auto-recovery process. ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional R
C.P.R.(CPU Parameter Recall)
When the system hangs due to overclocking failure, there is no need to open the case to clear CMOS data. Just simply restart the system, the BIOS would show the previous setting and then users can amend the CPU setting again.
ASUS EZ Flash
With ASUS EZ Flash, you can update BIOS before entering operating system. No more DOS-based flash utility and bootable diskette required.
hope this helps you
Mar 03, 2011 | ASUS P4P800S-X (610839118175) Motherboard
How to connect from jsp login page to database
hey try this code......just found it on the net... Put the code in tomcat and test the application through browser. The browser should display the display the data stored in the table.
Here is the code of our JSP file
<%@ page language="java" import="java.sql.*"%>
<html>
<head><title>Read from mySQL Database</title>
</head>
<body>
<p align="center"><b>Following records are selected from the 'jakartaproject' table.</b><br>&nbsp;</p>
<div align="center" width="85%">
<center>
<table border="1" borderColor="#ffe9bf" cellPadding="0" cellSpacing="0" width="658" height="63">
<tbody>
<td bgColor="#008080" width="47" align="center" height="19"><font color="#ffffff"><b>Sr.
No.</b></font></td>
<td bgColor="#008080" width="107" height="19"><font color="#ffffff"><b>Project</b></font></td>
<td bgColor="#008080" width="224" height="19"><font color="#ffffff"><b>Url
Address</b></font></td>
<td bgColor="#008080" width="270" height="19"><font color="#ffffff"><b>Description
of the project</b></font></td>
String DRIVER = "org.gjt.mm.mysql.Driver";
Class.forName(DRIVER).newInstance();
Connection con=null;
ResultSet rst=null;
Statement stmt=null;
try{
String url="jdbc:mysql://192.168.10.2/tutorial?user=tutorial&password=tutorial";
int i=1;
con=DriverManager.getConnection(url);
stmt=con.createStatement();
rst=stmt.executeQuery("select * from jakartaproject ");
while(rst.next()){
if (i==(i/2)*2){
<tr>
<td bgColor="#ffff98" vAlign="top" width="47" align="center" height="19"><%=i%>.</td>
<td bgColor="#ffff98" vAlign="top" width="107" height="19"><%=rst.getString(2)%></td>
<td bgColor="#ffff98" vAlign="top" width="224" height="19"><a href="<%=rst.getString(3)%>"><%=rst.getString(3)%></a>&nbsp;</td>
<td bgColor="#ffff98" vAlign="top" width="270" height="19"><%=rst.getString(4)%></td>
</tr>
}else{
<tr>
<td bgColor="#ffcc68" vAlign="top" width="47" align="center" height="19"><%=i%>.</td>
<td bgColor="#ffcc68" vAlign="top" width="107" height="19"><%=rst.getString(2)%></td>
<td bgColor="#ffcc68" vAlign="top" width="224" height="19"><a href="<%=rst.getString(3)%>"><%=rst.getString(3)%></a>&nbsp;</td>
<td bgColor="#ffcc68" vAlign="top" width="270" height="19"><%=rst.getString(4)%></td>
</tr>
i++;
rst.close();
stmt.close();
con.close();
}catch(Exception e){
System.out.println(e.getMessage());
</tbody>
</table>
</center>
</div>
</body>
</html>
Feb 27, 2009 | Compaq Computers & Internet
How can we turn off the automatic start of Radio or CD setting?
The activating and deactivating of the 24 hour timer is via a toggle button, labeled "TIMER" on towards the right side of the top console. When the TIMER is activated, you will see a small clock symbol on the LCD display. While the unit is on, tap the TIMER button once. The clock symbol will disappear and the timer is now off.
Reactivating the timer is the same process (remember, the button is a toggle). Tap the TIMER button and you'll see the timer settings show up on the display (time on, time off, source, and volume). The little clock symbol appears again.
If you have lost your manual, you can download another one for free from this location:
http://www.retrevo.com/s/JVC+SD1000
Nov 17, 2008 | JVC FS-SD1000 CD Shelf System
Feed dogs don't want to feed.
Sounds like the feed dog height is not set correctly. You could fix it yourself but you would need a dealers service manual and there is a height gauge that should be used although I have set them by eye...and experience.
Bernina's are fantastic machines and I have yet to find even one that is a lemon. Just like finding a good auto mechanic, you need to find someone that actually knows more than how to blow off lint and apply oil.
Your problem should be a low cost quick fix/adjustment that can be accomplished by a knowledgeable and skilled technician.
Good luck finding one!! Bill
Aug 15, 2008 | Bernina Artista 180
Frezes at verifying DMI settings. Already changed MB and Power supply. Lan connection only flashes green once in a while should be constant. Tried on a working terminal and does the same.
The Desktop Management Interface (DMI) is a new
method of managing computers in an enterprise. The
main component of DMI is the Management Information
Format Database, or MIFD (the DMI Pool Data). This
database contains all the information about the
computing system and its components.
At times, some systems may experience hang
conditions after partitioning, formatting and initial
bootup of a hard drive. The message, "Verifying DMI
Pool Data" appears and the system hangs. This
condition may continue after the drive has been
removed.
! WARNING ! ALL SUGGESTIONS LISTED IN THIS
INFORMATION BULLETIN ARE BIOS RELATED. FOR
A PERMANENT SOLUTION, MAXTOR RECOMMENDS
THAT USERS CONSULT THEIR SYSTEM OR
MOTHERBOARD MANUFACTURER FOR BIOS
UPGRADES.
Suggestions to Resolve the Condition:
1.Apply power to the computer.
2.Access the system BIOS.
Set the drive type as None or Not Installed.
Load BIOS Defaults
Load SETUP Defaults
3.Save the BIOS changes and reboot the PC to a
System Boot Diskette.
4.Shut down the PC after the memory count is
displayed.
5.Reconnect the power and interface cables to the
hard drive.
6.Access the System BIOS.
7.Auto-Detect the hard drive. Ensure that the LBA
Mode option is enabled.
8.Save the BIOS changes and boot the PC with a
System Diskette.
9.Partition and format the hard drive via the
operating system.
10.Reboot the system. On bootup, the screen should
read:
Verifying DMI Pool Data
Update Successful
The system should continue booting normally.
Other Possible Solutions:
2.Access the System BIOS.
3.Disable both the Internal and External CPU Cache.
These features are located in either the "BIOS
Features" or "Advanced Settings" options of the
BIOS Setup.
NOTE: Consult the System or Motherboard User's
Manual for exact location of the Internal and
External CPU Cache settings.
4.Save the BIOS changes and reboot the PC to a
System Boot Diskette. On bootup, the screen
should read:
Update Successful
5.After the system successfully boots, re-start the
PC and access the system BIOS.
6.Enable the External CPU Cache. This feature is
located in the "BIOS Features" or "Advanced
Settings".
Manual for exact location of the External CPU
Cache setting.
! WARNING ! User's MUST re-enable this feature
for optimal system performance.
7.Save the BIOS changes and reboot the PC to a
should read:
Update Successful
NOTE: If the aforementioned suggestions fail to
resolve the issue, contact the system or motherboard
manufacturer to:
Remove the "Clear CMOS" Jumper and reset the
system BIOS
Obtain a Flash BIOS Upgrade
from pc help;
SYSTEM HANGS AT MESSAGE: "VERIFYING DMA POOL DATA":
You did not say what operating system you are running but I assume Windows 95 or 98. It is possible some Windows
system files are corrupted or perhaps the system doesn't like your ram (if you added or installed ram recently). There
is also a possibility that there is something wrong with your BIOS and you *may* have to update it, but I would avoid
doing that if at all possible.
A quick fix - if the problem is software related - is to:
1. boot to a Windows startup disk (one that matches your operating system). this step assumes that your PC is setup
to boot to the A: drive before the C: drive (via the BIOS SETUP program). If you don't have a Windows startup disk,
you will have to make one on another person's computer that has the same version of Windows. You make one via:
my_computer/control_panel/add_remove_programs/startup_disk
2. run "scandisk c:" to make sure that any file corruption is fixed before going to next step
3. do a "sys c:" from the "a:" prompt to transfer a good copy of Windows system files to c: drive
4. remove the boot floppy, reboot the system and see if all is well.
If that does not solve the problem you may have to reinstall Windows 95/98. Ouch!
I recently had someone bring me a computer that had this DMI error message problem and I tried the "sys c:" method
(with the startup disk) without success and had to entirely reinstall windows 95 (and almost all applications except for
some programs that did not need to be placed in any Program Files directory or other special location) to cure the
problem. However nasty a job that is, it did cure the problem.
Jun 23, 2008 | Computers & Internet
Setting the date
If not in the time mode, press mode to get to the time mode.
While in the time mode, press and holdlap/rst for two seconds.
The seconds will begin to blink.
Press st/stop to reset seconds to zero
Press mode and the minutes will begin to blink.
Press st/stop to advance the minutes
Press mode and the hour will begin to blink.
Press st/stop to advance the hour
Press mode and the day and date will appear. The day will blink.
Press st/stop to advance the day.
Press mode and the month will begin to blink.
Press st/stop to month the minutes.
Press lap/rst to return to normal state with you new settings. You can hit lap/rst to return to normal state at any time in the process, for example if you only want to set the minutes, just hit lap/rst after you set the minutes.
Apr 28, 2007 | Timex 1440 Nylon watch
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
