Question about Brother HL 5250DN Laser Printer
Printer stopped printing for no reason
Printer makes noises as if it were printing and looks like it is printing, but nothing comes out. It was printing the last time we used it and no one has altered any settings. Any suggestions?
  • kokeekay Mar 01, 2008
    Same problem. My printer stopped midway through a printing job. Now, looks and sounds like it's printing but nothing prints, not even test page. Troubleshooting didn't help. I filled the tray with paper, reset the drum - nothing
    Genius:
  • 3,587 Answers
Maybe a blown set of drivers? can happen with power glitches by the way
check here for fresh set of printer drivers
Posted on Mar 02, 2008
Nothing at all printing or copying, just blank pages
hi and welcome to fixya
Your printers ink Carthage is empty ! making noise of printing and blank pages is because of the empty cartage bring a new cartage and then printer will print the pages
Dec 07, 2012 | Epson Stylus Photo RX520/RX530
Making noise like its printing but nothing comes onto the paper
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jan 21, 2012 | Lexmark X4850 WIRELESS All-In-One InkJet...
I have a HP Photosmart C4780 all in one printer and when I turn it on, as well as before I go to print something, the printer makes a horrible, loud clicking sound. I have cleaned out the inside and...
There may be nothing you can do about it. A lot of the HP printers make a lot of noise as they start up or prepare to print. Has your printer always made this noise or did it just start?
Jul 26, 2011 | HP Photosmart C7280 Laser Printer
My machine is printing but there is nothing printed on the paper when it comes out and all ink is new
First make sure you have removed any packing tape from ink cartridge.
Second look into ink cartridge slot on printer and make sure nothing is blocking installation of ink cartridge.
Be aware that your Brother machine is designed to stop ALL printing operations when any of the ink cartridges are empty.
Mar 02, 2011 | Brother Multi-Function Center MFC-240C...
Hp 2115 - clicking noise from carriage, can`t print test page
I have an HP 6110 is always has a grinding noise.No functions work. HP just want me to buy a new machine. They are bad quality 3 in one's. That is for sure.
Jun 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Paper jams with photo paper only hp1610 all in one. will print photo on regular paper any size.machine also makes a "grinding rotating" noise
Paper can jam inside the printer for a number of reasons.
  • Open the cover to the printer and look inside to see if there are any pieces of paper or debris that may be blocking the print path.
  • Be sure to unplug the printer before touching anything internal to avoid electric shock. If there is something blocking the print path, remove it, close the printer, and try printing again.
  • You can also check inside the printer to see if any components have come loose.
May 08, 2009 | HP PSC 1610 All-In-One InkJet Printer
Thank you for your recent reply
The red light is not on or flashing, is it? You did, of course, remove the yellow plastic tape from the cartridges before installing them, didn't you?
OK - the first thing we must ensure is that you have good cartridges. The printer Status Manager (SM) does not actually measure how much ink is in them, it merely estimates it by counting the number of ink shots used and calculating what's left. There are many reasons for getting this wrong. So we must start from a known good position i.e. new cartridges. Put new ones in, but you MUST use the proper cartridge exchange procedure so that an ink charging cycle is carried out. Now try a nozzle check. Any sign of ink? Yes, but not perfect? If so, or if nothing still, do a couple of head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat the head clean etc. Patience is required here.
Still nothing? OK - let's try cleaning the nozzles. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water (available from you local car accessories store). DO NOT USE TAP WATER! Then carefully push the print head fully into its parking position by hand so that the cup full of fluid comes up over the print head. Do not turn the printer on! Leave this for at least 24 hours, then try a head clean & nozzle check again. You may get some strange colours to start with - don't worry about this. However, if still nothing, repeat the soak procedure. If still nothing after this, report back.
Dec 03, 2008 | Epson Stylus C20UX InkJet Printer
Not working on window 2003 server as a network printer
I have had a similar issue with both laserjet 3005N and 1320N machines setup as network printers on a windows 2003 print server. Both machines install correctly and print test pages but once you push to much of a print job to it (in my case it was a 12mb pdf file) the printer stops printing and never prints again for some reason. After a quick reboot a test page will print but what gives?? Buffer issues? Not enough ram? None of this makes sense since the printer displays nothing and just stops printNo test pages or anything. I tried re-installing it and rebooting it. Nothing.
Jul 12, 2008 | HP LaserJet 1320 Printer
No printing...?
Make sure after you click 'print' that the printer you are printing from is not the 'fax'. I had this happen too... just a suggestion ;)
Apr 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Grinding Noise and no printing
grinding is NOT cool...i'd say that you have a mechanism issue with this printer. How long have you know this printer?
Mar 03, 2008 | HP PSC 1315 All-In-One InkJet Printer
Brother HL 5250DN Laser Printer Logo
60 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
