Hello I own an mpk 49 keyboard now I'm new at this and I can't figure out if it's internal or external sound the mpk49 gives off. Long story short how do I get the sound out of the keyboard do I have to buy somethng other machine to get the sound out of it?
    Brigadier General:
  • 8,546 Answers
You could look in the manual on Page 5 for connections to external equipment...
Connect a USB cable from your computer to the MPK49. The unit will be powered through the USB connection. Alternatively, if you do not wish to use a computer in your setup or if you wish
to power the MPK49 externally, please plug in a 6V-1A DC power adapter.
2. If you would like to use an external sound module, connect a 5-pin MIDI cable from the MIDI OUT of the MPK49 to the MIDI IN of the external device.
3. If you would like to use another MIDI controller in your setup, connect a 5-pin MIDI cable from the MIDI OUT of the controller to the MIDI IN of the MPK49.
On Page 13 the first of the FAQ's is:
Question: Does the MPK49 have internal sounds?
Answer: No. The MPK49 is a MIDI-controller, which means that it does not contain any sounds inside but is instead used
to control external sound devices, such as hardware and software synthesizers, sequencers and drum machines.
If you lack the manual you can go to retrevo.com and download it for free after you register.
Posted on Feb 03, 2010
Some keys on mpk49 do not play unless hit hard
sounds like dust, if you know some one with an air compresser ask them to give it a blow through, if not then it is down to caned compressed air, if that is not enough, you need to open it, and clean the contacts (DVD cleaner is cheap and good)
Aug 29, 2014 | Akai Mpk49 Mpk 49 Midi USB Keyboard With...
How to fix usb port on keyboard controller
I am assuming that you broke the connector off the pcb board? you need a soldering iron about 30W and solder and flux, to remove and short circuit after you solder them back on, using a magnifying glass to make sure none of the 5 termnials are shorted
Akai mpk broken conector
Its a lot simplifier than that really.. all you need to do is unsolder the old one and re-solder the new one.. The pins and connectors are standard.
Dec 30, 2012 | Akai MPK mini MIDI Controller Keyboard,...
My mpk 25 does not record long notes in Reason 5 only short poping sound. it record drums sound perfectly but string and horns long sounds a sounds like short piano sounds like popping noise. not the full...
Make sure you do NOT send the notes back to the MPK25, that is echo is off. If you echo them the data will be confused. This will be a setup in the Reason SW.
Sep 21, 2011 | Akai Mpk25 Keyboard Controller, 25 Keys...
Akai MPK mini MIDI Controller Keyboard, 25-Key ... my keysare broken from were it clips on
I have the same keyboard, what do you mean from where it clips on. Do you mean the keys itself are broken? I'm not sure how you did that, but you can contact Akai and see if they will send you a new one. Those keys are supposed to be pressure sensitive and unbreakable. Please rate me for assisting you today! :-) PS I love that little thing!
May 09, 2011 | Akai MPK mini MIDI Controller Keyboard,...
I need sound please
Make sure to plug it in before you start up the application. Make sure you restarted your computer after installing device.
Did you check system preferences to see the output settings?
I have mine set to output as headphones and have some external speakers in them. If I unplug them the computers speakers turn right on automatically.
Mar 03, 2011 | Akai MPK mini MIDI Controller Keyboard,...
So, I have a controller keyboard, the MPK 49 that will not turn on via usb. the Display on the keyboard seems like it kinda gets power, but is not backlit at all.
The controller will not power from the USB. You MUST use a power adapter. The display takes far more energy than can be had from a USB port.
Dec 29, 2010 | Music
My keys have popped up on my akai mpk 49
use black electrical tape. put tape on the edge of the key and cut it at the bottom of the mpk
Feb 21, 2010 | Music
I think I am quite confused for what I want. So maybe you can help. I am non-professional player of Yamaha PSR 730 with no music knowledge I Play by ear/hearing only. What I Play: Mostly remix old songs...
You sound like you have a good grasp of what you would like to do. There are lots of videos on Youtube of people using some of the gear you mentioned. Also check each manufacturers site for forums on the gear you would like to use. The forums usually consist of members who are all friendly and have good advice and solutions for any problems you may have. Remember that even the most experienced musicians started somewhere and are all still learning and are very willing to share what they know. You might consider using a laptop with an external hard drive. I think the Akai gear is very good and has good support and expandibility. Decide first what main pieces of equipment you would like and contact as many dealers as possible to get the best price. You may be pleasantly surprised and have enough of your budget left over for something you hadn't thought of yet. Good luck and enjoy your playing. Remember to study all your manuals carefully.
Jan 21, 2010 | Music
123 people viewed this question
 Grubhead
Grubhead
