Question about Linksys WRT54G2 Wireless Router
Problems with WRT54G2 and DNS
I have a Linksys WRT54G2 router set up at my house. My computer detects it but for some reason I can't connect to the Internet. I can get on my router's page, but the wireless network just won't work. When I click "diagnose and repair," the same error message keeps coming up: "There may be a problem with DNS configuration..." In the router page under "Status" and "Router," the IP address, subnet mask, and default gateway are all zeros. There isn't even any text for DNS 1, 2, or 3. If it makes a difference, I'm running under Vista.
  • jnyhan822 Feb 03, 2010
    I tried doing that but it didn't work. Now, I have the same problem as before where I hook the router up (even my iPod detects the wireless network), but there is no internet connection. The desktop I have the router connected to has internet access, but I can't get to the router page. Under ipconfig in cmd, it says that the IP address is 24.63.15.90, and when I type it into the address bar it doesn't work. In Network and Sharing center, under manage devices, the WRT54G2 doesn't even show up.
  • 596 Answers
It sounds like your router is not getting an ip address from the modem. Try powering off both router and modem, power the modem on first, wait about 2 minutes then power on the router making sure the ethernet cable is connected to your modem. Once the router is up and going, check the router's setup page and see if you have an ip address. Post your results here when you are finished.
Good Luck
C2Solutions
Posted on Feb 03, 2010
    Genius:
  • 1,341 Answers
If there is only zero on the ip add, sub mask etc then it would never work.Make sure your router is connected to a modem and that the latter can be hooked directly to a pc with cable and test if there is an internet connection. If there is a connection go back to your pc and connect to your wireless.Then go to start>cmd, a black screen would appear and type the following : ipconfig /iprenew .Then afterward type ipconfig and see if the zeros' you mentioned earlier changes to a value to the format of x.x.x.x .This should solve your problem.
Posted on Feb 02, 2010
  • heeman mohun Feb 04, 2010
    If the desktop has internet access but cannot log into the router setting then it may be your wiring connection here.Which means that it is possible your ethernet cable is connected to the modem but not the router as else it should see its settings.As a test,remove the ethernet cable from the desktop(I assume your desktop is hard wired to the router) and plug it to the laptop and see if you have any connection.If you have then it is definitely the router.Try to reset the router and check all cable connection and allow a reset of the router and modem by turning both off for few minutes.If this does not help then you have a problem with the router itself and I will suggest ebay.com for a cheap part, may cost less than 5 usd...Hope this helps, for any question please do ask.
    Unplug ethernet cable from destop(assuming your desktop is hard wired to the modem) and plug iinto your laptop.Test for internet connection.If you have one then go back to your wiring connection from modem to router and check..Make sure they are all connected in the right place.Then try a reset of both router and modem by turning off for few minutes, the former may have a reset button key somewhere on it,so confirm this from its manual and reset.If you still do not have any connection then you may need a replacement router which could be less than 5 usd from ebay.com.Hope this helps.
The Internet connection is strong but I can't see webpages
Go to command prompt, start > run type cmd.
Execute the command ipconfig /all, see whether you get and IP or not. try to ping the gateway IP.
Login to your router console and verify that you have configured the DNS settings.
Aug 19, 2011 | Linksys WRT54G2 Wireless Router
Show me how to connect linksys wireless
Hi
The Router configuration is not that much difficult, only few thing you have sure,
1) Correct ADSL Connection User name & password,
2) Chose unique ip address in All host.
Follow the mention bellow instruction to configure and connect to Wifi Router,
  • Plug the network cable ( Mine was Blue ) which comes with the Router Box pack to your computer. The other end goes into any of the Router Ethernet Port ( 1 or 2 or 3 or 4 )
  • Now type in 192.168.1.1 in IE or Firefox or any browser. You will prompted for password which is admin. You must be logged into Linksys Router.
  • Now since your ADSL modem is also having the same IP , we will change the IP address for WRT54G2 Router to 192.168.5.1
  • Under Setup >Basic Setup look for Network Setup and Change Router IP. Change to 192.168.5.1 and Save changes.
  • Since the IP has changed you will need to close the Browser.
  • Sometimes the IP doesnt change automatically. Do a IPCONFIG / RELEASE and then IPCONFIG / Renew
Making WRT54G2 Router talk to ADSL broadband modem
  • Plugin the Ethernet cable which comes from the Modem into the port on Wrt54g2 router which says Internet.
  • Open Internet Explorer and Type in 192.168.5.1.
  • Type in same password ( admin )
  • You will be in Setup > Basic Setup
  • Take a look at Section , Internet Setup. The current selection should be Automatic Configuration DHCP. Select Static IP instead.
  • Add following details to it. In the first step we backed up All the IP configuration. Use them here
Internet IP Address: . . .
Subnet Mask: . . .
Gateway: . . .
Static DNS 1: . . .
Static DNS 2: . . .
Static DNS 3:
ADSL Modem Settings to Wrt54g2 Router
  • Once Done just save changes and you should be back at same page.
  • Now try to connect any application which talks to internet. You should be able to connect
Configuring for Wireless Connection :Now once your Router is talking with Modem, it is pretty easy to connect on Wireless. The only thing we need to setup here is Security. Lets get WIFI
  • Get to the Lynksys page again. Do all login and regualr stuff.
  • Now look for menu Wireless, click on it. You should land on Basic Wireless Settings.
  • Select wireless configuration to Manual .
  • Wireless network mode to Mixed.
  • Give a Wireless Network Name (SSID), make sure its unique.
  • Make Wireless channel selection 11 ( 11 - 2.463 GHZ)
  • Select Wireless SSID Broadcast to Enable
  • Save Settings and you will be back at the same page with changes you made.
Now Lets secure the Router :
  • Go to Wireless Security on the same page.
  • You will need to configure here Security Mode : WPA Personal, WPA Algorithms: TKIP
  • WPA Shared Key is what you will need when you connect to your router without wire. This key does the authentication and keep unwanted people away. Add 8 digit alphanumeric key.
  • As suggested in comments, there is a new mode which you can use : WPA2 with AES
  • Save changes.Just make sure you save that key to a notepad or remember it.
Wrt54g2 wireless security
  • Now last step, Move to next menu Security > Firewall .
  • Uncheck Block Anonymous Internet Requests .
  • Save Settings.
Wrt54g2 firewall settings
  • Remove the blue cable which you had connected with Router.
That's it. Now just turn on your WIFI and Search for the router. The name should be visible. Click to connect. At this stage it will ask you for the Password or Shared Key which we configures just above. It will connect and you will be able to connect to Internet.
That's all Folks. This is how you connect WRT54G2 Linksys router with Adsl Broadband Modem. If you have any questions feel free to comment.
Aug 03, 2011 | Linksys WRT54G2 Wireless Router
Wireless connection problem
hi
go to following link it will give you all your solution for wireless networking
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Jul 24, 2010 | Linksys WRT54G2 Wireless Router
WRT54G2 wired desktop fine, can't connect to wireless.
Hi Seth6025,
Try without using Wireless Encryption (password).
Try changing channels; default is 6; try 1 or 11.
Change your SSID: personalize it
SSID broadcast: Enable
Check the advanced wireless settings and make sure MAC filtering - DISABLED.
Reset the Linksys router by pressing RESET for 30 seconds should everything fails and re-configure. Firmware is another consideration BUT this is just a new release.
Regards,
Angel
Jul 08, 2010 | Linksys WRT54G2 Wireless Router
Linksys WRT54G2 Wireless router unable to connect to Internet
Try again by Disabling the WEP (or WPA), MAC Address Filtering and Firewall Setting Individually. Should be a problem with one of those. Then when you receive the Signals, try to Adjust using Bottom Up method. That means one setting at a time, Hardening the Security. Have you checked your DNS settings? Have you checked the Channels you are using? Re check them and try again.
Feel free to contact back.
Please rate the answer if it helps you to solve the issue.
Thanks for contacting Fixya!
Jun 12, 2010 | Linksys WRT54G2 Wireless Router
How to find security code for linksys WRT54G2 to
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Jan 28, 2010 | Linksys WRT54G2 Wireless Router
I have a WRT54G2 Wireless router. Works okay with
yes mke sure wep is correct code. make sure you home security level is the same as your laptop. have tried hooking up your laptop to the home with a cat 5 cable. we had to do this with 2 dell vista laptops. then disconnect lan and we hooked up wirless just fine. something in vista firewall settings.
Dec 31, 2009 | Linksys WRT54G2 Wireless Router
IP ADRESS FAILED ON XBOX 360. TRIED 2 DIFFERENT ROUTERS SAME ERROR
xbox configures the connection automatically as long as it is able to detect an internet connection(either wired or wireless). For wirless connections though, make sure xbox is using the correct security key or wep key for the wireless connection.
Mar 22, 2009 | Linksys Wireless-G WRT54G Router
Setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 27, 2008 | Linksys Wireless-G WRT54G Router
Linksys WRT54G2 Wireless Router Logo
659 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
