Info on Zip Disk completely over ridden. Lotus 123 being used.
Due to the destruction of files by previous management I have been using a program I am familiar with, Lotus 123. I have 2 years of bookkeeping record on a Zip Disk, print through Excel. Last week I had worked on files saved to a disk for one portion of the business, removed the disk, inserted another disk with different files and the information on the second disk is the same as the prev one I had been working on. How can this happen. Disk 2 info is competely over ridden by the infoo on disk 1. I have worked with Lotus 123 for 20 years and know that you can only save one file at a time and to completely copy and paste the data would not over ride info only add to it, which I did not do. Please help.
Thankfully I have a hard copy of the info but it will take hours and hours to restore this info for them as they ahve requested.
    Genius:
  • 1,752 Answers
It's called a disk cache, the cache wasn't flushed before you swapped the disks. I remember Lotus 1-2-3, I first used it in 1987 on a Compaq portable. But I haven't used a Zip disk in 10 years, that's totally obsolete technology.
Good thing you have hard copies.
Posted on Feb 03, 2010
Testimonial: "Thank you. I now know to leave the disk in the zip drive even after I have saved the file and allow time for the cache to be completed. "
Is there lotus 123 software that is compatible with Windows 10? I have lotus files on my computer but cannot access it.
right click on lotus 123 and and in properties click on the compatible tab
click in the square and high light the win 10 operating system
If win 10 is not there , it is not compatible
Aug 04, 2017 | Lotus Computers & Internet
Our laptop got stolen who had the lotus 123 and 4 installed on it.
BAK is a backup file. WK4 is a wordperfect file.
Open Office should open them.
Lotus 123 is available as a download.
http://en.softonic.com/s/lotus-1-2-3-download
Feb 26, 2016 | Computers & Internet
Can I restore corrupted nsf file?
Wow it's been a while since I've used Lotus Notes. Under default programs, does it show Lotus Notes as the default mail program? Is there a setting in Lotus Notes itself you might check to see if it can set itself as default?
http://www.nsf.viewertool.com/
Looks like quite a few people are having issues with this version. Might want to try updating to Notes 8.5.2 per IBM's Technote SPR# JZJZ84WDMA
http://www.overclock.net/t/1568554/how-to-repair-corrupted-nsf-file-in-lotus-notes
Oct 21, 2015 | IBM Lotus Notes (d53t7ll-bl) for PC, Mac
A disk utility to recover nsf-file
put it on the new computer and from the Notes File menu switch to that ID when you need to open the old mail file. You can also use the ID to unencrypt the database so that you can read it using any ID file. (Under File-Database Properties-Encryption Settings) I had read about it here: https://recoverytoolbox.com/lotusnotes.html
Sep 15, 2015 | Stellar Information Systems Ltd Stellar...
The problem is that I need to recover a zipped file from a corrupted hard drive. The hard drive is NOT physically damaged, only inaccessible due to the current state: I accidentally, began ghost imaging...
There are plenty of file recovery tools to deal with your problem. But whatever tool you use, I would still make an image of the damaged drive just in case that revovery tools makes more damage than necessary. Use Zip Restore Toolbox from http://www.zip.restoretools.com/
Jun 03, 2015 | WinZip Computers & Internet
Lotus 123 problems
Microsoft Excel should open your old Lotus files.
Go to File > Open > Select Files of type: Lotus (*.wk?) and select your Lotus file.
Alternatively you could install and use OpenOffice spreadsheet or LibreOffice Calc and open your Lotus files.
Jul 24, 2014 | IBM Lotus 123 Millennium Edition 9.5...
Will lotus 123 load from a cd on windows 8
you have to create a batch file to run Lotus 1-2-3, and (so far as I can tell) you have to run the program from your root drive, because the program makes its calls TO the root drive. Here's the batch program you create in Notepad or other plain-text editor:
cd\
cd\lotus
123.exe
cd\
exit
* Delete the 'exit' if you want the window to stay open as a DOS window, after you're done with the program. Save the file with a '.bat' extension. (Note: unlike XP, you can close the window with your mouse, afterwards.)
* After creating that file, you have to right click on the file name, select 'Properties (in Win8, Vista, XP) and do some more tweaking. The Properties dialogue box SHOULD show the following tabs: General, Shortcut, Options, Font, Layout, Colors, Compatibility. Each of these needs editing.
GENERAL tab: select Normal Window or even Maximized (though it won't actually maximize). Also in Win8, click on Advanced, and 'Run as administrator'.
OPTIONS tab: select Large cursor. You can always change it, but since the program really won't run fullscreen, you'll want the cursor to be oversized, since the window will be smaller and will shrink everything in it.
FONT tab: this is what Windows uses to select the screen size, despite all the other settings (which you also still need to set). In Win7, you have three types of fonts to set. Click on the 'Bold' option, as that makes the text easier to read.
For True Type 'Consolas' font (which results in a more square window), pick a font size between 18 and 24. More than that will be bigger than your entire monitor screen, when you actually run the program (looks are deceiving, you have to test the results with trial and error).
For True Type Lucida Console font, use the same 18-24 font size range, but the screen will be much shallower and wider, so you can afford to decrease font size to 18-20. 28 is really too wide, on a widescreen monitor (1366x768 pixels). But maybe you'll like it, or your monitor will accommodate that size. Mine wouldn't.
For Raster fonts, 12 x 16 is the optimal setting. ON some (i.e., Dell Ultrasharp) monitors, Raster fonts look best. On my Toshiba 19L4200U TV monitor, the Lucida Consule setting is clearest.
LAYOUT tab: Pick a window size width no greater than 85, and height no greater than 38. Then test to see if it's too big. If yes, you'll also need to decrease font size, as well as the Layout size, here. Experiment, because you can't gauge the right mix of window and font size, just by the diagrams in the dialogue box.
COLORS tab: Lotus 1-2-3 makes hardware calls on the screen, so whatever you put in this tab, it will ignore. But other DOS programs might 'obey' the colors you set here. If you remember the old Norton Utilities days of setting Mode, etc., that's what this is.
COMPATIBILITY tab: You can't set resolution to override at 640x480. The setting is either ignored, or your monitor will freak out. For Lotus 1-2-3, in Win 8 I didn't need to turn on the 'compatibility mode'. It made no difference in the results. (You don't need it in XP, either.)
* Finally, you have to find the program itself, then right-click on the program name and edit its Properties. Here, that program is 123.exe, and it has to be in your root directory. (All the program files Lotus will use, must be there; at least one wk1 file must be in C:\123 at startup. I'm sure this can be tweaked, but I'm using the default Lotus program settings for a typical installation.)
Jan 04, 2013 | Dell Optiplex GX270
Problems opening lotus 123 files, very slow
I have all my Lotus files on a server and am not experiencing this problem. Did you install the desktop version or the network version. Mine is desktop and I get my files off the server. Works well.
Feb 11, 2010 | IBM Lotus 123 Millennium Edition 9.5...
Can't see the folders after restarting SS400-e
If you check their website, you will find:
Upgrading from a previous version of the firmware (to version 1.4) is a “data destructive” process.
it is strongly recommended that you first backup your existing data to another system in your environment. It is also recommended that you understand your current configuration of users, groups and shares to be able to recreate this under the 1.4 firmware.
Apr 05, 2008 | Intel SS4000-E (SS4000ENA)
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
