Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Convergence I also replaced both my IC's and still have no left and right on my blue. I am starting to think maybe the IC's were not the problem, where do I go from here, Everyone mentions resistors, but how do I read them, I am not an electronic kind of guy, but I know enough to replace parts. the blue will move up and down, just not left and right, does this mean something other then the IC/resister repair. I am looking to make this repair myself, so anything more than what I have read on this board, would be helpful HI. A GOOD FRIEND JUST GAVE ME HIS PANASONIC MODEL PT-53TW53G. I HAVE A CONVERGENCE PROBLEM ON THE BLUE GUN. IT MOVES UP AND DOWN BUT NOT LEFT AND RIGHT. IVE READ THAT IT IS A RESISTOR. IF I AM LOOKING AT THE TV FROM THE BACK WITCH BOARD IS IT AND WHERE ON THE BOARD IS IT LOCATED??? PLEASE EMAIL ME AT tkspalace@netzero.com.THANKS.
  • Anonymous Feb 23, 2008
    Just replaced both IC's and have the same problem, all the resistors seem good, I did notice that the front IC ( the one on the angle) did not get nearly as warm as the one in back. My original problem was a red wave on the bottom of the screen, that is cleared up but the blue won't move left or right.
    Champion:
  • 206 Answers
Sorry about that Boxerman My Computer picked the wrong time to hang. No the reason why I tell peoplle to get the Hitachi Kit X480295 is becuse this forces them to get good parts, not only are there some spare resistors but the Ic's are a higher wattage and will last longer. When people seee that the orginal Ic's the STK392-110 go from anywhere from 5.95 to 37.00 for what they belive is the same Ic they almost always get the 5.95 cheep'Os. Then in one week or less the Ic craps out and they don't know why
So the Kit that has The higher wattage STK392-150 in it and for a good price is a bargan. , Now you said you have a Hitachi giving you trouble till it warms up, that is a whole differant problem and is most likly in what is called the 3DY comb filter and a few caps on that board have or are failing
Posted on Feb 19, 2008
    President:
  • 4,402 Answers
I would take the board out and have ptscorp.com test it.
Colored lines at top and bottom when tv comes on and seeing double vision in different colors at all times
If your tv is not a DLP the problem is in the convergence, try to adjust it using your original remote control go to the setting menu then to the convergence section. Adjust the red and blue convergence. you should move the red and the blue in up, down and left, right if this color does not move far enough your convergence IC is already defective. Replacing this convergence IC will solve the problem. In locating this convergence IC you should remove the back cover of your unit but be sure to unplug it before doing this. This convergence IC is attached to a large aluminum plate, it is the heat sink, and it has a marking of stk- ### followed by numbers. You can try to pull it out using a soldering iron and soldering pump but be careful you may damage the board and cause much problem to your unit. Or you can contact a technician to do it for you and save you from stress good day and best regards.
Aug 28, 2011 | RCA Televison & Video
The red green and blue dont line up and the pic is bowed
easy one ther should be 2 stk ic s on left or right big blak squre 99%bad goto nte semiconducter.com give stk #replce 20$ x2 always replace resitor around ic usualy bad 2$ total cost 45$max 2hrs time good luck tip buy heatsink compound 3$ radioshack
Aug 08, 2009 | RCA Televison & Video
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
Problems after new ic chip install
Did you check for open resistors in the convergence circuits? Often that is what happens when the old ICs wear out it will cause a couple resistors to burn open, and they show no outward sign of being bad. Also double check the IC pins connections for solder bridges thats another common problem, I always use a magnifying glass to double check my solder when ever I do convergence or any IC work where the pins are close. But with the streaks youre describing I would think maybe resistors.
Jun 16, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Blue Convergence Problems
You will need to replace the conversion IC that controls the blue STK392-110 or STK392-120 however these are so cheap I recommend replacing both as the red wont last much longer. As they usually wear out around the same time. Heres a link where you can buy the replacement ICs and they include step by step instructions on how to install the new ICs.
http://servicemanuals.vstore.ca/
Mar 29, 2008 | Philips 43P8341 43" Rear Projection...
Toshiba 40
Convergence amp ICs need replacing and quite possibly the resisors that power the IC as they usually burn open when the iC goes out. You will need two ICs. Let me know if you need any more info.
Feb 24, 2008 | Toshiba 40H80 40" Rear Projection...
Convergence
Next to the ICs you will see about 6 or 7 resistors with no color bands usually green in panasonic they all look identical. Check them with a ohms meter to see if any are open. The ICs usually take out one or two of these resistors when they go out.
Jan 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Right side convergence
A convergence IC has burned out. If I remember correctly, those Pioneer sets have one huge convergence IC, but that IC only has 5 channels in it so they use another smaller dual STK IC and one half of it is used for the 6th channel and the other half is the vertical output. Look on the convergence board, find the blue convergence jack, identify the blue horizontal channel, follow the traces and replace the IC handling the blue horizontal channel.
Aug 28, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
85 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
