Question about Advent Netbook
Advent 5401 left touchpad button broken
I have an advent 5401 laptop, its over 1 year old and the touchpad is a little worn, the left click button does not work and i have to tap the touchpad itself instead, is there any way i can fix the button myself?
  • Steven Neff
    Steven Neff May 11, 2010
    If you have never taken a laptop apart, you're better off taking it to a repair shop. It may just be a little dirt under the button, try some light compressed air found at any office supply before you spend the money. Use a very quick light spray, not too heavy.
Had a similar problem a couple of months ago, The left button started playing up, not working with every mouse click, it gradualy got worse till it was nearly unusable.. I suspected that the microswitch under the silver button had some dirt in it. After taking a deep breath I removed the battery and the screws that hold the case lower and upper halves together and was able to seperate the case front by about 3/4 of an inch. Then using a contact cleaner Servisol Super 10 and supplied flexible straw I squirted cleaner into both mouse click buttons. After waiting for cleaner to evaporate and resecuring case halves and replacing battery I switched on .... The button works 100%..
Posted on Sep 16, 2010
Touchpad doesn't work
Step 1:
The touchpad of any laptop is always subject to heavy use.
Most touchpads are designed for their durability to sustain the daily wear and tear for the lifespan of the laptop.
However, there may be instances or accidents that cause the touchpads to malfunction or stop working entirely.
There are ways to troubleshoot such problems and there are also remedies to salvage the touchpad's functionality without heavy repair or replacement cost.
Determine What's Wrong
A laptop's touchpad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touchpad may be damaged by excessive use or foreign substances such as water, dirt or food items. Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return." Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touchpad to become unresponsive. But if any of these steps fail to remedy the problem, then the touchpad may need to be repaired or replaced. b> Repairing/Replacing Touchpad b> A touchpad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touchpad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touchpad is deemed a necessity, such repairs are rarely worth the cost. Attempting to replace the touchpad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop. Long-Term and Better Solution b> The simplest, and best, solution to a malfunctioning touchpad is to replace its functionalities with an external mouse. Most PCs sold after 2000 come with USB ports and getting a USB mouse either a corded or a cordless one--will remedy the problem. A cordless USB mouse may be bought for as little as $10 and some of the better-designed ones allow the user to tuck the USB stick inside the mouse's belly when not in use. Even when a touchpad is working properly, a laptop user should be advised to plug in a mouse anyway whenever possible as touchpads are notoriously difficult to use and also leaves the user in an ergonomically incorrect position.
http://www.microsoft.com/ b> http://www.streetdirectory.com/travel_guide/116002/hardware/touchpad_keyboard_for_personal_computers__pc.html
Feb 19, 2013 | Computers & Internet
My Advent 5421 Touchpad Is Not Working!!!
Advent laptop computers are equipped with a touchpad and two buttons that service the function of an external mouse. The touchpad can be turned on or deactivated, depending on the user's preference. It's not difficult to either activate or deactivate it.
Power up the computer. Connect a plug-and-play computer mouse to a free USB port on the laptop. The mouse is just temporary to help you get the touchpad working again. Locate the touchpad icon, which is in the lower right-hand side of the screen. The icon will appear as a gray square or rectangle, with two rectangular buttons underneath. Use the mouse to double-click on the touchpad icon, opening a window on your laptop screen. Inside the touchpad window, click the option labeled "Enable Device". Select other options for the touchpad, such as pointer speed and shape. Click "Apply", then "OK". Disconnect the mouse from the laptop.
Feb 02, 2013 | Advent Computers & Internet
I have a Sony Vaio and though the touch pad allows the cursor to move around the page it does not allow me to click on anything. I have a Logitech mouse that I use but that is because the touch pad is not...
You may need to enable the buttons for Sony Vaio Synaptics TouchPad as follows...
1. At the bottom left of the screen on the Taskbar, left-click on start.
2. On the pop-up window, left-click on Control Panel.
3. In the Control Panel window, left-click on Sony Notebook Setup
4. On the Sony Notebook Setup pop-up, left-click on the Device tab.
5. Left-click on Pointing Devices to high-light it, then left-click the Settings button.
6. On the Mouse Properties pop-up window, left-click on the Device Settings tab.
7. On the Devices listing for Synaptics TouchPad, left-click the Settings button.
8. On the pop-up window Properties for Synaptics TouchPad on PS/2 port....
9. Left-click on Buttons item to bring up a Buttons frame with an Enable buttons check box.
10. If the check box is not checked, left-click on it to enable the buttons for the TouchPad.
11. Left-click Apply button or OK button to enable TouchPad buttons and exit the pop-up window.
Feb 01, 2011 | Sony Computers & Internet
Advent 5401 I have 6 split screens on the display advent 5401 i format the HD I removed the HD and still have the 6 split screen i think bios need to update or reflash can i get the bios for this...
I think the 'split screen is actually your wallpaper
To find out if I'm right - if you right click the desktop - choose properties, then desktop.
On the right side of the window that opens - look at the middle button, it probably says Tile. click the arrow to the right and choose Center. Now click O.K.
Your wallpaper should now be one 'screen' probably with a coloured border around it.
Cheers.
Aug 02, 2010 | Computers & Internet
My left button is loose and i dont no why
This is know to happen with this model Notebook. If its still in warranty contact your vendor. You can always tap the touchpad as a left click or use a mouse instead if it stops working.
Apr 15, 2010 | Advent Netbook
Fix left click on built in mouse
If you're talking about the touchpad, then I'm afraid that no; it's not easily replaced.  The most probable thing that's happened is the microswitch underneath the button has worn/broken.  You not only have to pretty well completely dissassemble the keyboard part of your laptop, but it's a tricky job when you get there.
The best solution is to get an external USB mouse and use that.  It's a bit late to tell you this, but using an external mouse to take most of the wear is the best thing to do anyway...save the touchpad for when you have no other choice.
Mar 07, 2010 | Gateway M-7315U Notebook
Replace worn touchpad buttons HP compaq 6820s
It's better and easier to just replace the whole touch pad assembly and top cover. It's all one piece...much easier and cost is the same.
This is the part number:
457616-001
Nov 23, 2009 | HP Compaq 6820s Business Notebook
THE LEFT BUTTON LIGHT STAYS ON ON THE TOUCHPAD
this is due to a faulty touchpad. it needs replacement. call the manufacturer.
Aug 04, 2009 | Advent Netbook
Left click button below touchpad on dv8000 not working
Sarah it might be due to Hardware malfunction i think you should replace the switches+touch pad! can i know how much old is you laptop? most of the touch pad needs to be replaced when used more than 4-5 years!
Dec 08, 2007 | Compaq Presario M2000 Notebook
Advent Netbook Logo
959 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
