Question about JBL Encounter 2.1 Computer Speakers
No power when turned on. led light does not show, changed fuse in plug, is there anouther fuse inside the system?
N450AD transistor is busted,no available!!! does anyone have any idea for "replacement/subtitutions" for this Transistor?
Please help!!!!!
Posted on Mar 17, 2010
I purchased a refurbished GE MAC 1200 EKG machine with a new battery. The first time we used it, it worked perfectly. The second time we used it however, only the standby light comes on. The screen remains...
There's several things that could be wrong. What I would do would be to try to run it off the battery, and if it works, then there is a problem either with your power cord, the power cord connection, or the power module inside the machine itself. Try completely turning off the system. Unplug it, figure out a way to let the battery be disconnected, turned off, or just simply let it die. Then re-boot the device and see if there's a change in operability. If there is, or isn't, you should consult the owners manual, and see what you can find on the issues your having. If all else fails, have a technician stop by and work on it.
Nov 25, 2014 | Medical
Emachines e350 wont turn on
sounds like your power supply is fried or the power port
Jan 19, 2014 | Computers & Internet
Led lights will not come on on my Gateway MD2614u
You should buy a new battery for your computer. Sometimes battery's
get too old.
Apr 13, 2013 | Gateway MD2614u Notebook
.won't turn on. all plugs are in properly. has
When you turn on the main power socket to the monitor, does the front LED turn come on (Green/Orange)? If not, try changing the power cord or the fuse inside the power cord.
Feb 19, 2011 | Acer X183H 18" Monitor
I have a 50fx18b and it wont power up i took the back of the set off it has a red light on but nothing happens when i turn power on
the red light = shutdown led
all the green ones indicate the voltage lines that came up
there is a diagram inside that shows all the leds plus fuse locations. you need to check the fuses with an ohm meter to figure out which one is blow or which voltage doesn't come up. with that info, i can direct you.
Jun 04, 2010 | Hitachi 50FX18B/19K 50" Rear Projection...
LG WASHER WON'T Power on
Hello. If the lid switch is defective, your washer may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 24, 2010 | LG WM1814CW Front Load Washer
Tv will not power on!!!
most likely will need a new power supply, google it
Jan 01, 2010 | LG 32LG30 32 in. LCD HDTV
43FDX15B No picture, Power light stays on
Just a thought, but check all of the pico fuses for a blown fuse. The pico fuses look like a small yellow resistor. Some Hitachi's are famous for having a blown hi-volt ceramic capacitor and a blown pico fuse.
I think the red led on is a short protect indicator, but I could be mistaken.
Sep 08, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Ps3 powers on no video.
Hey jlbrown55 , have you tried resetting the default settings? If not you just have the PS3 in standby (with red light on) and hold power till the systems turns on then 10 sec after and it will beep. Let it go right then and it should reset the defaults in about anouther 10 seconds. If that doesn't work, call Sony. It seems to be a growing problem. Good luck.
Oct 15, 2007 | Sony Playstation 3 (PS3) Console
JBL Encounter 2.1 Computer Speakers Logo
204 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
