Question about Stingpro ST444 1850 Watts Complete Amplifier 4 Gauge Hookup Kit Car Audio Amplifier
Well i want to hook up hifonix amp and one pioneer premier un my hyundai xg350l and i want my stock radio to stay i know i need some sort of adapter to create rca's and also where would the remote line go for the amp? please and thanks
  • 1,068 Answers
You need a (loc) line out convertor you can get at best buy or radio shack and the remote wire will need to be tap in at the fuse panel to the radio fuse. so that amp comes on when the car is turned on.
Posted on Feb 04, 2010
Put a pioneer premiere deck in my 03 chev impala. Every thing is working. But no sound what so ever. Car does have a factory amp in the trunk. Hooked up many car stereo's never had this problem.
Was the system working properly with the factory radio?
If it was working with the stock radio but not with the new one, then it probably means you didn't connect the amplifier activation wire. This is a white wire in the vehicle plug, and it's usually pinned with a blue or a blue/white wire in most adapter harnesses. This needs to be connected to the blue/white wire in your Pioneer harness.
If the factory radio wasn't producing sound either, there's a common problem with the power wiring leading to the factory amp in these vehicles. The power wire runs in a thick harness below the passenger side door sills, and at a spot below the rear door there's a junction point in the wire. This connection tends to get wet and corrode until it breaks apart. (In some of these cars, this connection is constantly immersed in water because there's a leak that leads to standing water under the carpet in front of the passenger-side rear seat).
Aug 25, 2015 | Pioneer Car Audio & Video
I took out the stock deck and know have all sorts of electrical isuses i need to know what wires i 'HAVE' to have hooked up
U should buy a wire harness for the year of the car and follow the diagram then conect to ur new deck
Sep 21, 2012 | 1985 Cadillac Eldorado
I got a premier, pioneer DEH-P200 sterio and ive hooked it up to my 92 chevy truck and my 94 camero but in both it powers on. and beeps through the cd player for volume changes and stuff like that but its...
WELL THIS RADIO CD PLAYER WILL NOT WORK WITHOUT AN AMP HOOK UP IT JUST SENDS A SIGNAL TO THE AMP AND THEN TO THE SPEAKERS. YOU MAY HAVE TO FIND THE AMP THAT DIRECTLY HOOKS TO THIS UNIT...
Jul 15, 2011 | Pioneer DEH-P200 CD Changer
I bought a sony deck to replace the bose stock deck on my 1996 nissan maxima. I purchased the wiring harness and antena adapter also. I hooked everything up right and getting power but im not getting no...
each speaker in your car runs the wiring thru an amp. So each spkear has its own amp for the bose system. You can not hook up a none bose radio If you do you will need to run new wires and replace all the speakers. Sorry.
Jul 02, 2011 | 1996 Nissan Maxima
How to integrate the pioneer deh-1300mp into a 96 Dodge 2500 Centurion diesel truck to replace a radio/cassette player.
The simplest way to swap the stock radio out for the cassette player would be to go to a radioshack or bestbuy, normally they will carry a double-din to single-din adapter so that the smaller after market radio fits into the existing location snugly. They usually also carry a wiring harness adapter that will plug right into your dodges existing harness and you can just wire nut or solder & shrink wrap the adapter to the pioneers harness, saves a lot of time and insures everything is where it needs to be.
Normally you can get both adapters for under $15, hope this is helps.
Mar 08, 2011 | Pioneer DEH-1300 CD Player
05 xg350l airbag for second time stays on i checked under seats nothing there. checked fuses and anything else i could think why does it keep happening?
Without knowing what DTC (Diagnostic Trouble Code) has been set, it could be anything. Take it into the dealership & have them scan it for codes.. Then you'll know where the problem is.
Oct 12, 2009 | 2004 Hyundai XG350
Power to pioneer deh-2000mp will not turn on
MOST OF THE TIME THE CONSTANT CAN NOT BE HOOKED UP TO THE SAME WIRE AS THE POWER WIRE, U SHOULD HAVE A WIRE IN UR HARNESS THAT IS YELLOW USE THAT WIRE, IF U DONT FIND A FUSE INSIDE UR CAB USE THE FUSE AS A CONSTANT POWER LEAD BUT PUT IT ON ONE THAT CUTS ON WITH THE KEY.
Jun 17, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Can't get my amplifier to work.
My homie had the same problem with his escalade they adapted an rca line adapter from the factory wiring to geta signal to his amplifier and it just wasnt hitting like it should so we installed a new deck and plugged the rca cords right into it and boomboom pow it was hittin like a champ-we figured that the stock premium system that was incoprporated into the truck had some sort of an onboard amp that was filtering the bass from the door speakers and which was limiting the bass output to the rca adapter and thus on down the line to the amplifier- so maybe ya might want to look into getting an aftermarket deck and see if that helps your cause-good luck
May 21, 2009 | Alpine MRP-M450 Car Audio Amplifier
Premier DEH-59 Pioneer CD reciever
If you could tell me the number of pins in the connector and how many pins per row then I think I might be able to help you. It should be something like two rows of 8 pins maybe.
Sep 10, 2007 | Kenwood Z-727 CD Player
Car Audio & Video Logo
Top Stingpro Car Audio & Video Experts
xxxxxx xxx
Are you a Stingpro Car Audio and Video Expert? Answer questions, earn points and help others
