Question about Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset
Instruction manual How can i stop my earpiece from falling out? where can i get a manual or instruction for it?
  • merizo Sep 02, 2008
    i can´t speak englis, i need the user manual, how i get it?
  • itsgary Oct 05, 2008
    I have a sony ericson k850i
    the wep 210 will not connect to it
  • 298 Answers
I am having trouble programing VOX to work on motorola rdu 2020 2-way radios
Here is a link to the user guide: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
Instructions for setting the VOX sensitivity are on page 33.
According to the manual you program the VOX using the CPS (software). Three things which usually cause end-user problems are:
1) Failing to set the sensitivity to a number 1, 2, or 3.
2) Failing to have the radio shut off when plugging in the audio device (headset or earpiece)
3) Failing to use a VOX capable audio device. (Not all headsets and earpieces are VOX capable. Many with inline PTTs are not.)
If these items or instructions do not help, stop by your local Motorola dealer to discuss the problem.
Best regards.
Sep 22, 2010 | Motorola RDU2020 Two Way Radio
How do i connect my motorola n136 earpiece to my laptop. Its a Toshiba Sattelite, I broke my mic port, and want to know if i can use my bluetooth earpiece for my mic instead.
Your headset may also be called a HS850 (may look different) but the instructions would be the same. Instruction manual is here:>>>>>>>>
http://www.motorola.com/mdirect/manuals/HS850_%209489A97O.pdf
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Jul 11, 2009 | Motorola Mobility HS850 Consumer Headset
Changing phones but same Bluetooth earpiece
apparently deleting the earpiece from my SE devices did fix the problem, i just hadn't realised. thanks
Dec 07, 2008 | Lands Phones
Plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Nov 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
How do i pair my earpiece for my cell phone
First check the earpiece manual for the password and also how to set the earpiece to broadcast. After that search using your bluetooth then select the earpiece then put in the password that should do it.
Jul 27, 2008 | Cell Phones
Switching earpieces
Not a very technical fix I'm afraid someone I knew had instruction manual so was able to figure it out ;-)
Apr 03, 2008 | GN Netcom GN 9120 Professional Headset
Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
Aug 07, 2007 | Motorola Mobility H350 Wireless Headset
Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset Logo
620 people viewed this question
Top Samsung Radio Communications Experts
ivan georgiev
ivan georgiev
JP Services
JP Services
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
