Question about EliteGroup 945G-M3 Motherboard
Problem in usb,netwrk port but ps\2 mouse and
Problem in usb,netwrk port but ps mouse and keyboard work corectly in different operating system xp,vista and w7
  • 585 Answers
The mobo probably has a fuse soldered down near the USB ports. The typical fuse is flat, about 1/8 x 1/4 inch, may be green in color, and may have a number on it. A simple continuity test will check the fuse, If the fuse is blown, check with an electronics supply house for the replacement fuse. If unable to repair, you might try a USB PCI card.
Another possibility would be a problem with BIOS. Make sure the USB is enabled in BIOS.
Posted on Feb 03, 2010
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
Plz help me i want connect wire less keybroad and mouse thnksvjtawale2gmail.com
There are 4 possible ways in my awareness...
Method 1: Resynchronize your device with the receiver To resynchronize the mouse or the keyboard with the receiver, follow these steps. Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put any other wireless keyboards and mouse at least 6 feet away.
  1. Press the button on the receiver, and then verify that the light on the receiver starts to blink.
    Note Some newer Microsoft devices are permanently bound to their receiver and cannot be reset. If your device does not have a button, skip to Method 2.
  2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen. Otherwise, go to the next step.
  3. Press and release the Connect Channel button on the bottom of the mouse or the keyboard.
  4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
  5. For the Wireless Notebook mouse: This issue can occur if the micro-switch on the bottom of the mouse is not released. Use a pin or a pen to try to release the button if it is depressed.
The following example shows the buttons to push to synchronize a wireless hardware device:
Receiver Bottom of the mouse: The connect channel button Different kind of receiver Collapse this imageExpand this image 838398_receiver.jpg Collapse this imageExpand this image 838398_mouse_bottom.jpg Collapse this imageExpand this image 838398_portable_receiver.jpg Method 2: Try different portsTo determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse. USB keyboard and USB mouseIf the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer. PS/2 devices Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device into the PS/2 port while the computer is running.If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations:
  • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that was included with the computer.
  • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that was included with the computer.
If you have to change your configuration, shut down the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection. PS/2 keyboard and USB mouseIf you are using a wireless mouse with a USB connector and a PS/2 keyboard, verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer. Method 3: Reinsert the batteries or install fresh batteriesBoth the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. Remove the batteries, and then insert them again. If the problem persists, install a fresh set of batteries in the device that you are having problems with. Method 4: Check for interferenceItems such as wireless routers, radios, cell phones, desktop fans, fluorescent lights, and large metal objects like computer cases and metal furniture may interfere with the signal of the keyboard. Try to keep such items away from the keyboard, and check the behavior of the keyboard.
Do not put the mouse or the receiver near any electrical devices, especially transmitters such as cordless or cellular telephones or other wireless mouse devices or receivers. A distance of at least 8 to 12 inches is recommended. Do not put the mouse or the receiver on metallic surfaces or objects, especially long metallic rails or cables. We recommend that you keep the mouse and the keyboard a minimum of 3 feet from metallic objects.
Nov 21, 2010 | Computers & Internet
I replaced my hard drive in my hp pavilion desktop a1520n windows loads and then reads that i will have to register my copy of windows But my keyboard and usb ports dont have power so i cant do a...
A lot depends on where the keyboard and mouse are plugged in. I have seen in the past that the USB in the back works better than the front. Are these the original keyboard and mouse? If not, use the original until after Windows loads the desktop.
Mar 21, 2010 | HP P2360AA Keyboard/Mouse
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
Feb 23, 2010 | D-Link (DUB-H4) 4-Port USB Hub
Dell Dimension 3100 e10 ...usb won't work
Does the system respond to boot keys (F2, F12) when the DELL logo appears? If so the problem is with Windows drivers and probably can be resolved by reinstalling or rolling back the drivers, but how? Do you have access to another keyboard? Does the system have PS/2 ports? Do you have access to a PS/2 keyboard or adapter? If boot keys work, you could also choose F8 for Last Known Good Config (XP) or System Restore (Vista).
Have you tried different ports (front if using back or visa-versa)?
Try using just keyboard or mouse to see if one has somehow shorted. Also check the ports for any sign of damage.
Jan 10, 2009 | Dell Dimension 3100 PC Desktop
Mouse Doesn't Work in PS/2 port
CHECK BIOS TO MAKE SURE IT DID NOT TURN ITSELF OFF WHEN YOU PLUGGED IT INTO THE USB.BIOS MAY HAVE TURNED IT OFF TO PREVENT A CONFLICT.RICHARDM69
Dec 07, 2008 | Foxconn 6100K8MA-RS Motherboard
Keyboard want light up but mouse works
The buttons on the top (silver) are linked to your "Favorites" folder in Internet Explorer.
The buttons to the right of that are used for your media player (To skip tracks and adjust volumes, play pause etc)
The buttons on the left (from top to bottom) are:
1) My documents folder will open
2) MSN or Windows Live! Messenger will open
3) Your E-Mail will open (whatever your default email program is)
4) Calculator Opens
5) Windows Update will open
Now... In order for these you HAVE to have the drivers installed. If you didn't get a CD with your keyboard, you can download the drivers directly from Microsoft here:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Just fill in the drop-downs and press "Go", it should show you a link the the exact driver you need to install. Once it's been installed you can set up your favorites with the software that it installs.
Oct 24, 2008 | Microsoft Wireless Optical Desktop Comfort...
MS optical desktop 700
try one of the method below:
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
uparrow.gifBack to the top
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Method 4: Install the latest software loadTOCNode(2, 'moreinformation'); If you are troubleshooting a wireless mouse, download and install the latest Microsoft IntelliPoint software. For more information about IntelliPoint software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) If you are troubleshooting a wireless keyboard, download and install the latest Microsoft IntelliType software. For more information about IntelliType software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) uparrow.gifBack to the top
Method 5: Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Sep 18, 2008 | Microsoft Wireless Optical Desktop Comfort...
Wireless keyboard
wireless keyboards and in wireless mouse devices, use the following methods in the order that they appear in.
Mar 02, 2008 | Sakar 62150 Keyboard
EliteGroup 945G-M3 Motherboard Logo
129 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
