Question about Watches
I have a forestville wall clock with the pull down weights. when it chimes it is behind in time. example nine oclock chimes seven oclock, it is a made in germany clock but what year i do not know. there are three screws at the top which i believe are for the chime inside. it always chimes two behind the correct time
  • 2,334 Answers
Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
Posted on Feb 03, 2010
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    Not sure if first attempt went through so i will try again. We were moving a sligh grandfather clock and the brass weights fell and the weights inside came out which weights go in which brass?
    with most old clocks the weights were a means of moving the gears in the clock instead of using a spring
    If I am right , to wind up the clock you pulled one lot of weights down and the weights then slowly changed positions from one up to one down
    normally the lh weight is the wind up weight and is slightly lighter the than the rh weight
    your problem will be determining the correct weight for the rh side as too heavy and the clock will gain time and too light will loose time
    Dec 10, 2015 | Watches
    Clock Manuals
    leave it running when it gets to 12 oclock it wiil reset itself
    May 02, 2013 | Watches
    My Citizen Wall clock runs perfectly, however it does not chime the correct hour. How can I correct this, it is only 3hours off, but it it annoying
    take both hands off the clock wait till it chimes then put hands back on to the time it chimes at, then adjust to correct time.
    Sep 30, 2012 | Watches
    How to sync. an old Black Forest cuckoo clock.
    Suppose the cuckoo is calling three and the time is showing eleven, then to synchronize, simply stop the clock till the time is the same as the bird (three) and restart the clock at that time.
    If the error persisys, then pull off the hour hand, and replace it at the synchonized time.
    Jul 13, 2012 | Watches
    I just purchased a Heritage Mint Ltd Timepiece Quartz Regulator wall clock but it chimes two hours slower than the actual time. Need to know how to correct it. There is a red push button on the back of...
    I have the same clock. Here's what I did to re-set it after changing batteries: After replacing batteries, use the turn dial to set the correct time. Press the RED button 6 times, wait for it to go through that series of chimes, then press the button again to set the time.
    Example: Press RED button 6 times. Wait for it to chime. Press RED button the correct number of times for the hour to be set. For 5:00, press the button 5 times, etc.
    I lost the directions to my clock, and I am posting this from memory and also just had to re-set mine and it works OK now.
    Hope this helps!
    Feb 07, 2011 | Watches
    I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
    the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
    example: you want to change it to sat 12th 11am
    set the day and date to fri 11th
    then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
    Dec 13, 2010 | Citizen Eco-Drive watch
    Quartz president wall clock, I need to set the chime
    I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
    *Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
    *Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
    If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
    John
    Apr 21, 2010 | Watches
    Our wall clock was not wound a couple of months ago (it is a chime clock that chimes on the hour and half hour with weights) and when we rewound it, everything works fine except that the chime is out of...
    You were not very specific about you clock description, Many of the German clocks were using auto correct features.
    You may not have this function.
    Move the hour hand to the correct hour.
    Hope this tip help you.
    R/
    David
    http://antiqueclock.clockstop.com/
    Mar 13, 2010 | Watches
    Antique Forestville Mantle Clock
    Middle Key hole for the time.
    Left side is for Chime
    Right side is for the strike.
    r/
    David
    Aug 25, 2009 | Seiko Chiming Pendulum Tambour Mantel...
    Watches Logo
    317 people viewed this question
    Top Watches Experts
    Jimmy Accardi
    Are you a Watch Expert? Answer questions, earn points and help others
