Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Water coming out w/out trigger being pressed
As soon as I turn it on the water comes out weather the trigger is pressed or not. The trigger dosen't seem stuck. Is this a mech. problem or elect. thanks for any help!
  • Geterdun Feb 22, 2008
    reddevil6 Thanks I had a feeling thats what it might be so I already ordered the part. I'll let you know if it worked out.
    President:
  • 1,673 Answers
You may have a problem with the valve at the bottom of the tank, or a water line has come loose. How old is this, there is a 1 year warranty, so if less then a year, take it in for repair.
Posted on Feb 21, 2008
Trigger pin is stuck or something else is wrong. why is it constantly leaking water as soon as I plug it in?
You will need to provide more information as in the model AquaMate you are using as I can't determine which one by your information. You can also call and speak with a tech. at 800-640-2033.
Rainbow Vacuum Cleaner Systems Repair Center
Mar 28, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Vax match won't discharge solution or water
please see the videos for troubleshooting and help:
http://support.vax.co.uk/help-videos
God bless you
Jul 24, 2012 | Vacuums
No water sprays when I press lever on handle
proheat 9300
assuming the water works for the tools
Remove the water tank. You will see 2 red tabbed plastic spray tubes.(where the spray comes out if not clogged) Pinch the clips to remove from the machine. Then you will need to pinch the hose clips to remove the red tabs from the hose. Clean out those red spray nozzles. Next step: have a towel ready and fill the solution tank with water. Put the solution (not water) tank on to where the water tank would go. Place the machine selection knob to rinse/wet only. Now with towel under the hoses that you removed the red tabs. Turn on the machine and pull the trigger to activate the water. You should see water flow out of the hoses that had the red tabs on them. If not, release and pull again the trigger several times. If only 1 hose has water coming out of it then block the one that works and try the process above again to de clog the one that isn't working. Good luck.
Apr 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Not putting out water
Here's some trouble shooting tips that will help you figure out what's wrong with your Bissell Little Green Machine, and why the water won't spray out. You didn't mention how old the machine was, but if the machine is brand new, and you've never used this before, then you'll need to prime the machine for the first time.
To prime the Little Green Machine, remove the hose after filling the clean water tank, and press and hold the trigger on the hose for approximately 45 seconds. This will prime the pump, and get the water flowing.
If the machine is older, and you've already been using it, here's some other troubleshooting tips that you can do to try and fix the machine:
Step 1. Fill the clean water solution tank with water, and remove it from the machine. With the tank removed, press the piston at the end of the tank that fits into the machine. The piston is the spring loaded part in the top of the water tank that is pressed upwards when the trigger is squeezed, which in turn releases water into the machine. Press the piston inwards with your finger and see if water comes out.
Step 2. If water is released from the tank when you push the piston inwards, then your piston and cap assembly are fine. Next unscrew the cap to the clean water tank and make sure that the o-ring is present. This is the rubber ring that rests in between the cap and the tank.
Step 3. If your o-ring is not there, you'll need to purchase a new a new o-ring and replace it. If the o-ring is present, screw the cap back onto the tank. Inspect the receiver to make sure there is no debris blocking it. The receiver is the part on the machine that the tank sits on top of. If you see debris here, remove any debris that could be obstructing the tanks piston.
Step 4. After checking these three things, refill the tank with water, reinsert back into the machine and test to see if the water now comes out. If the water does not come out, move on to step 5.
Step 5. Unscrew the two screws on the handle of the hose, and remove the cover that the two screws secure.
Step 6. After removing the hose cover, inspect the hose that connects to the trigger assembly for blockages:
Step 7. If blockages are found, remove the tube from the trigger, and blow through the hose to remove any blockages, and reinstall the tube back onto the trigger.
Step 8. Reinstall the trigger assembly so that the metal spring's curved side is facing down so that it touches the trigger valve:
Step 8. After reassembling the hose, turn the machine on again and try spraying the hose again.
If none of these solutions fixed your machine, this most likely indicates that you need to replace your pump. The pump is the internal part that takes the water from the tank, through the hose, and finally sprays it out. The pump replacement is a moderately difficult repair, but if you'd like me to walk you through it, I'd be more then happy to do so.
Please feel free to ask any follow up questions, or let me know if you'd like for me to show you how to replace the pump. I'm always more then happy to answer any question that you may have.
If you found this helpful, please kindly rate my repair helpful so that other Fixya users with the same problem can easily find this solution. By rating the repair you are also encouraging repair professionals to continue posting free repairs. Thanks in advance,
Chris J.
GoVacuum.com
Apr 09, 2010 | Bissell 1400 Little Green Pro Canister...
Water/chemical not releasing
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
op
Oct 21, 2009 | Bissell 1699 ProHeat Clear View Upright...
No water comes out when you press the trigger only solution comes out when you turn it on its side
Check the belts. Most models have two belts. The first one from the motor runs both the brushes and the water pump.
Oct 02, 2009 | Bissell 1699 ProHeat Clear View Upright...
The unit will not release water.
The water release probably has the hose pinched shut. Storing it with the trigger depressed will eliminate this. You'll have to find the spot, where the hose gets pinched, to shut off the flow and turn it 90°.
Jul 03, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Plugged water line?
The trigger in the handle is clipped into two plastic snaps. When the trigger is pressed, the trigger pivots in these snaps and the pressure is transmitted through a rod connected to the trigger down to a valve located under the water tank. If the machine has been carried by the top handle insead of the carry handle that is incorporated into the water tank, the extra stress on the trigger will break off the snaps and the trigger will not function properly. Take the water tank off the machine and press the trigger. Observe the valve below the tank support and see if the rod is pressing down on it.
You might also check the hoses that come down the handle where they turn at the bottom of the tank. Sometimes they kink there and this will restrict water flow.
If you have been using the wrong shampoo, that is shampoo not designed for hot water extractors, it is possible for it to congeal in the lines and plug them.
Jan 27, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
Too much water coming out.
When you press the trigger an angled piece on the end of the plastic rod attached to the trigger pushes valve button in that then releases fluid. On releasing the trigger, the valve button is supposed to be pushed back out by an internal spring. The button gets sticky with evaporated cleaning fluid and does not come back out, causing fluid to continuously run. Try taking the machine outside, fill the tank with very hot water, pull the trigger, and let the clean, hot water flow through the valve. Perhaps it will free up. If not, the valvle will have to be replace. Either way, once it is working, ALWAYS flush the entire system with hot, clean, clear water to remove any cleaning solution in the system or it will only clog again
Jan 01, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Polti Vaporetto 2400: Water out light comes on when tank is full
Hi you need to put 5ml of Kal Stop fo Polti machines into 1000/1500ml of water into the tank, The stronger solution is better (1000ml) Let it heat up and this should break down the limescale on the solenoid. I tried this today and it has worked saving ££££'s in repair by Polti.
Nov 04, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
250 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
