Question about Fender& Standard J Bass Artic
How do i change the battery in my fender strat?
  • Fender Master
  • 5,603 Answers
In short, you don't! There is no battery in the Fender Strat.
If you are not getting output, you have a failure. FIRST check the cable by using a different cable.
There is internal wiring and the pickups, switches and volume/tone controls that can fail, however the jack is always the first suspect.
Posted on Feb 03, 2010
3 Suggested Answers
  • 5603 Answers
SOURCE: I have a Fender Squier Strat. The Whammy bar is
There are MANY tricks to remove a threaded piece like this:
1. With a Dremel tool and a cutoff carborumdum disc cut a shallow slot in the remaining piece and use a straight bladed screw driver to remove. This can only be done if the screw is above or flush with the surface.
2. Carefully drill a small hole in the piece fairly well centered. Use an "EasyOut" to remove the broken part.
3. Carefully drill several small shallow holes on the top of the broken part in a line so as to form a slot for a screwdriver.
4. Carefully drill a hole JUST the right size into the broken part and then drive an Allen wrench into the hole to turn the broken part. The hole has to be just the right size so the wrench can peal tiny pieces off to grab the broken part.. this is tricky to get the size just right.
5. Use a detist drill to cut a slot.
In all these use a penetrating oil or CRC226 to make it easier to turn.
Posted on Mar 09, 2010
  • 3 Answers
SOURCE: CAN I FIT A FENDER STRAT PICKUP IN THE MUD
The Fender pick up has two wires, blue and white. The Jackson has four: red, green ,black, and white.
1st. Determine the hot wire and the ground wire on the Jackson pick up and then just replace the Jackson pup with the Fender pup. White on the Fender is the hot lead and blue is for the ground. If you hook it up backwards it will be out of phase with the other pup's and will sound thin and weak when selected with either the rhythm pup or the lead pup. Of course, by itself it will sound normal because switching the wires only changes the phase of the Fender pup.
On the Jackson pup, the green and black are ground while the white and red are the hot side. Just solder the white lead of the Fender pup to the pup selector hot side and the blue lead to the ground.
Posted on Aug 01, 2010
I have a Fender Squier Strat -serial no 0070581223 Model no 0301600332 What is the year of manufacture please?
You can look up on internet I have but can't remember site look up Asian strat or squires or japan strat or fender strat identification or Korean strat indentfication just keep at it you will find tons of info
Nov 05, 2016 | Fender Music
What is my 1993 fender strat plus worth,in excellent condition.rare blue color
anything fender pre 1979 worth a lot
valuation service
http://www.guitaravenue.com/home.htm
need to look at 2016 fender strat guitar for sales
sites for a price comparison for yours ....$1000 ?
What is fair price for 1993 94 Fender Strat Plus Deluxe
Oct 31, 2016 | Fender Starcaster Strat Electric Guitar -...
Any info on strat serial no G006212 please.
This guitar is a STRAT (Gold hardware, 2 position rotary tone switch)
made at the Fullerton Plant (Fender - Pre CBS Era), USA
in the Year(s): Circa 1980
The Guitar Dater Project Fender Serial Number Decoder
Feb 05, 2015 | Fender Music
I have a starcaster strat electric guitar by fender serial number is CSS 060805532 HELP ME FIND SOME INFORMATION ABOUT IT PLEASE
although info is slim, it appears that it is of chinese origin, mid-2000's. Modest value, not a collector, but a decent guitar.
Dec 28, 2014 | Fender Starcaster by Fender Strat Electric...
How do i tell if my strat is us made
You can look it up at: guitardaterproject.org/fender.aspx
I looked it up here and it shows it was made in 1988-1989 @ Corona, California. Hope this helps..
Sep 02, 2014 | FENDER STARCASTER STRAT 3TONE SUNBURST
Fender strat serial number DZ0067060
Ok, this is going to be a lot of information. Let's start with the "D"; this usually means that the instrument is a "Deluxe" version. This would suggest it is an American Deluxe Strat. But Fender, themselves even admit that this letter ended up on some American Standard instruments. The second letter is EXTREMELY complicated and hard to explain. From the 1970's through recent years, Fender has used an "S", "E", "N", "Z", or "X". Here is the complicated part; "S"eventies, "E"ighties, "N"ineties, "Z" = 2000-2009, "X" = 2010 - present ;). The zero following the number suggests that this is a 2000 American Deluxe Strat. Keeping all of this in mind, there is another slim possibility. Fender has always used bolt on necks. Leo Fender decided to do this for a couple of reasons. They were cheaper to assemble, easier to work on, and easy to replace. Fender produces many replacement necks and they all have serial numbers on them. The previous owner could have potentially replaced the neck on a standard or even a made in Mexico Strat with an American Deluxe neck with a different serial number. I know this is a lot of info and the serial numbers do go more in Depth than just this, but more than likely you have an American Deluxe Strat. Good find!
Sep 01, 2014 | Music
Have a fender strat serial V019217
It is a US strat! Congrats! Guitar Info This guitar is from the U.S. Vintage Series
made at the Corona Plant (Fender), USA
in the Year(s): Cannot be determined from serial number,
however you can consult this chart showing the
corelation between serial numbers and dates found on the neck
Fender MIA RI Serial Number vs. Neck Date
Fender: Corona Corona factory was opened in 1985, Corona California, with major guitar production starting in 1987. With the addition of a custom shop in 1987 the plant currently employs about 700 workers. Apart from general and Custom Shop Fender instruments and amplifiers, it also encompasses Guild acoustic & electric guitars.
May 19, 2014 | Fender Starcaster Strat Electric Guitar -...
Fender serial number search N9422449
The guitar is indeed a 2002 fender stratocaster. Many prefer older strats because they believe them to be of higher quality. It also depends on where it was produced. Mexican strats are okay, Chinese are usually the least liked.
N seems to denote American Made Strats though, American made are superb.
Oct 21, 2013 | Music
IS MY FENDER STRAT Z2228815 REAL
Open the back and look in a see if it is made of plywood, you can tell by the layers in the wood. A strat would always be a SOLID body without layers. If it says Fender and not Squire by fender, that is. The neck should answer your question but it could have been put on a plywood body by someone if you bought it used.
Feb 28, 2013 | Fender Music
Can i put my fender strat mexican guitar into number two jack on the ampI got it today not sure
The Fender Stratocaster (in common with all Fender guitars) has passive pick-ups so should be plugged into the no 1 socket.
Whilst it will work in the No 2 input socket this has lower sensitivity and is intended for use with guitars that have active (battery powered) pick-ups.
Feb 10, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
Fender& Standard J Bass Artic Logo
885 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
