Will not download to computer. I recently had my computer repaired because of a virus. I tried to download printer back on with instruction disk and I get a message of , communication not available. This happened once before and we searched this on the dell website. This printer number V305 comes up as a printer #926. We located a patch to download and install printer, but now that is gone. Help!!
  • 7 Answers
SOURCE: Communication Error DELL 926 AIO Printer
Follow these steps in order to resolve the issue:
Stop the Print Spooler Service: 1) Click Start. 2) Type ‘cmd’ in the Start Search box.Search results should appear. 3) Right-click on ‘cmd’ in the search results, and select Run as Administrator.The command window will appear.4) Type ‘net stop spooler’ into the command window and press <ENTER>.The Print Spooler service should now be stopped.
Delete the Printer Drivers: .
1) Click Start.
2) In the Start Search box, type ‘C:WindowsSystem32SpoolDriversw32x86’ and press <ENTER>.
3) Delete all the files and folders in this directory.
NOTE: If the folder will not delete, rename folder to w32x86.old.
Remove the Dell printer software:
1) Click Start.
2) Click Control Panel.
3) Click Programs.
4) Click Programs and Features.
5) Click the software related to the attached Dell printer to highlight it.
6) Click Uninstall/Change.
7) Follow through the prompts in order to remove the software.
8) Restart the computer.
At this point, the user should install the latest printer software from http://support.dell.com and be able to print successfully.
Posted on Dec 24, 2008
abhishek0404
  • 81 Answers
SOURCE: Communication Errors with DELL AIO 926
Well just try another cable for the connection between the printer & the computer... your can also check print spooler service under the services of the system....
Posted on Jan 26, 2009
Found on another forum. For 926 this worked great.
1. Go to Control Panel - Printers : Delete 926 printer
2. Go to Control Panel - Programs and Features : Uninstall All Dell 926 related software. There should be 3 programs. (When prompted to restart, respond to wait.
3. Rename Folder C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32x86 to W32X86OLD
4. Now restart your computer
5. Reinstall 926 Software.
This worked terrific for me.
Posted on Feb 05, 2009
john_yap
  • 51 Answers
SOURCE: printer aio 926 communication error
hi aweintra,
you can do the following steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software, then unplug the usb cable of the printer.
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
just send me an update if the issue won't be fixed. have a great day.
Posted on Oct 19, 2009
  • 163 Answers
SOURCE: My Dell V305 only prints occassionally. An error
I used to have a Dell all-in-one and had same problem.
I asked Dell for new installation disc and re-installed it and that seemed to to solve the problem.
Posted on Feb 07, 2010
Message on screen: Windows failed to start. A recent hardware... It then cuts to startup repair and attempting repairs. Have gone through this a dozen times only to end up where I started. What do I...
I assume you've already tried pressing F8 on startup to get into the start-up options screen (from there you can attempt "Restore System to a previous date.").
If you can't get anywhere with the F8 options, try starting up your system from a Windows Install disk. (Unfortunately, few computers come with this. Some have a Restore mode using either a special startup hot key or a set of optical disks, but this usually involves formatting C: and wiping out everything before setting it back to factory original state.) Once you have the Windows Install disk going, watch for the Automatic System Repair option to come up. This is different for each version of Windows, so I can't give you more than that other than to follow the on-screen instructions.
Note: virus infections can disrupt the hardware registry and produce the symptoms you have. By now, your backup registry is corrupted (that is why the automatic repair fails). I've found the easiest virus fix for a desktop computer is to remove the hard drive and install it as a second drive in a known-good computer, then have that system scan the problem drive for virus infections and file system corruption. If you have a 2.5" - 3.5" drive adapter and can remove the drive easily, you can also use this tactic on laptop hard drives. You will probably still need to repair the operating system damage.
Nov 14, 2011 | Computers & Internet
Computer recently had a virus. Now when instructed to print it tells me the computer is not communicating to the printer. Will this virus cause this to be happening can someone please help me
Have you tried removing and reinstalling the driver?
Download here:
http://support.lexmark.com/perl/support/support.cgi
Please let me know if this helps ;)
Apr 12, 2009 | Lexmark Z2320 InkJet Printer
Whole computor is in Wingdings.
Well you made it online. The very first thing you should do is go to
Avira and download there antivir rescue system.
This is the second best anti-virus software company on the planet.
This disk will scan your pc for virus,trojan,rootkits.
Download this and burn it to a disk. Then boot from this disk just like you were going to install windows. If you can't do this or you feel that this problem in no way is a virus or other think, then use system restore. If you are running vista the use the vista disk to run system restore.
Mar 22, 2009 | Microsoft Windows XP Professional
Having trouble reconnecting my printer
go into contorl panel install hardware let it look for hardware when it is plugged in and turned on. then follow instructions until it says select printer or have disk if you have disk use it or select nearest match. HP or go to download from HP on the internet and download the right disk.
Mar 20, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP All in One printer causing problems with my computer.
Yes, It is possible that the setup disk is corrupt/virus infected. First try to update your antivirus. Then use Revo unistaller to uninstall the software. Now download fresh setup files from HP site. That will solve your porblem
Dec 16, 2008 | HP Computers & Internet
Lost software.. download available?
Click software and driver downloads on the page below and follow instructions:
HP PSC 1510 All-in-One Printer
Dec 11, 2008 | HP PSC 1510 All-In-One InkJet Printer
I bought a lexmark x5495 printer I have a compaq pc with vista and norton anti-virus, The pc will not recognise the printer, Lexmark have been no help at all, they keep giving me things to try and nothing...
You need to install teh software from disk before connecting the printer.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Dec 03, 2008 | Computers & Internet
We purchased a Lexmark X5495 several months ago and I have missplaced my installation disk, we just recently ad a wipe and reload done to our computer, is there any way to install my printer back onto my...
To download the driver directly from Lexmark's web site, go here: http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
Search for your printer model (X5495), select your operating system, select your language, then download the driver. After it downloads, double-click the file to launch it and follow the instructions on your screen.
Oct 01, 2008 | Office Equipment & Supplies
How to add my printer back on to my computer
try going to Canon website to find drivers, download drivers and follow instructions for install. You can also Google search for "drivers for canon ( insert printer model her ). Good luck
May 09, 2008 | Office Equipment & Supplies
13 people viewed this question
k24674
jasbo
jasbo
