On my macbook pro does one of my two LaCie not show up anymore on the screen
  • 696 Answers
There are several possible reasons for this.
The most common is a short or failure in the Lacie enclosure caused by mixing up power/AC adapters. If your two Lacie drives are different models and you accidentally used the wrong adapter you may have damaged the circuitry.
The second possiblilty is that your power adapter or USB/Firewire cables could be damaged. Try switching USB/Firewire Cables First. If this fails to work then check the Output Voltage and Amps on both adapters. Only if they are identical try switching adpaters from the working unit. If they are not proceed to the below solution.
Finally if the unit was dropped, bumped or unplugged while it was running it is quite possible that you may have damaged either the drive or the file structure on it, either of which would cause it to stop showing up.
Solution:
Try the cable swaps if able, if they work, replace the USB cable or replace the entire enclosure if the power adapter is the issue.
If neither works then you have either a failed hard drive or failed enclosure. Go to your local PC store (not a big box), have the techs there remove the drive from the Lacie enclosure and place it in a new enclosure for testing. They may not be able to see your files but they will be able to tell if the drive is working. If it is, buy the enclosure, then connect the drive back to your Mac. If it works you're done.
If the drive works but the Mac still doesn't recognize it(doesn't show up on the screen), then comment back and I will get you the link to a program you can use to retrieve the lost files.
If the drive simply fails to show up at the store in the new enclosure you will need the help of a pro to recover any importan files. If that is the case reply with your location, Country, State and City and I will recomend an appropriate facility for you.
Hope this helps FixYa,
Chris
Posted on Feb 02, 2010
I restored my computer's HD using LaCie. Now, my Macbook won't boot us using it's own HD, just LaCie
Hi SuzanneHow did you do the install? It's important that you do the correct procedure. First you should have installed the OS from the disc thaty came with your MacBook. It would have then asked you how you wanted to procede. One of the options is to restore from a back-up or from another drive.
You pick the Lacie and let it do iots stuff. As a rule, when that finishes the machine restarts from the new drive.
What you can do to check is shut the machine down. Hold down the Option key (alt key) and then press the power button to start it up again - don't let go of the option key. After one or two moments you will get a grey screen with a two icons. One will be your HD and the other will be the LaCie. You then choose which onwe to start from and that should be that. If you only get the Lacie showing up then it measn that you do not have a system on the internal HD and that it needs to be restored from the CD/DVD.
Let us know what happens.
Mar 03, 2013 | Apple MacBook Pro Laptop Computer with...
My mobile hard drive lacie rugged crashed, doesn't show on laptop or iMac and i need to recover my data stored in it
You may need to send it out to a data recovery lab. Before that try a remote access data recovery service like http://FreeDataRecovery.us
They operate an online data recovery service via the internet and also offer do-it-yourself data recovery assistance.
Oct 16, 2012 | LaCie Rugged All-Terrain (301017) Hard...
I have a MacBook Pro. How do I determine the amount of unused memory in my 2TB hard drive?
Hello I also own a Macbook Pro.
What you want to do is open up your applications folder
in the applications folder find utilities
in utilities folder run disk utility
select the drive you wish to see the info on the left
then at the bottom of the window it shows the drive details one of the details is its available space
hope this helped
djbr1ck
May 12, 2011 | LaCie (301467) 2 TB SATA Hard Drive
My Lacie hard drive worked perfectly for a period of time. I use it to make films and store all my files and final work on it. It now no longer appears on my desktop and I cannot access it in any way. ...
> it does NOT show on ... Macbook Pro running OS X 10.6.4
> it DOES mount up on older computers running older versions of OS X
> Lacie ... said there was no problem
So, the problem is "local" to ONE of your computers.
Be sure that your computer is connected to AC power, not running solely on its battery.
Try some other USB device in the USB port, to confirm that the USB port is working.
Nov 11, 2010 | LaCie Rugged All-Terrain (301017) Hard...
MacBook won't recognize my Lacie Rugged Hard Disk. Disk utility will see it but won't verify it nor will it repair it. says it needs to be reformatted yet it won't even let me initialize it. it is brand...
Is your MacBook as fast as the Lacie Rugged Hard Disk is?
Because solid state drive wasn't available on MacBook Pro at the initial time when it launched. Hard drives on all current Apple laptops are equipped with Sudden Motion Sensor technology. In fact, the Apple laptops that came with Sudden Motion Sensor are: All Intel-based Apple portables such as the MacBook, MacBook Pro, MacBook Air, PowerBook G4 computers starting with PowerBook G4 (12-inch 1.5GHz), PowerBook G4 (15-inch 1.67/1.5GHz), PowerBook G4 (17-inch 1.67GHz), and iBook G4 computers starting with iBook G4 (Mid 2005) have Sudden Motion Sensor technology. You MacBook may not have come with that technology that could be the reason you are unable to connect it.
Sorry mate... too many limitations on
Feb 24, 2010 | LaCie Rugged All-Terrain (301017) Hard...
On booting up my macbook pro I get a lot of
Do the patterns of distortion change as you are twisting and bending the laptop body? If so, you're dealing with a logic board issue. Probably your GPU is not soldered properly anymore. Go to the Genius bar first, if they can't help you can try a self repair or send it to a third party place. There is a free Macbook Air Repair guide that will show you how to do it. iPad Repair
Jan 26, 2010 | Apple MacBook Pro Notebook
Cannot detect LaCie mini hub HD.
Try a new power supply. $19.99 at Lacie. It worked for me.
Dec 20, 2009 | LaCie Computers & Internet
Hard drive will not come on screen
Usually this is caused by a bad power supply on the drive. Do you have another one that you can try? I think LaCie will send you a new one for less than $20 if it's out of warranty.
Apr 05, 2009 | LaCie Big Disk Extreme with Triple...
Lacie 250GB Drive
my only option to you is get file recover software for mac an recover data if no luck e-mail me on wareworlf2001@hotmail.com
May 30, 2007 | LaCie d2 Extreme (300790U) 250 GB Hard...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
