Question about Maytag Dryers
How do you access the drum in a maytag premium PYE3300Ayn ? I need to replace the felt piece that enciircles the drum. Not sure how to get the front off.
  • 156 Answers
SOURCE: Kenmore Laundry Center #417.90802990
unplug it drop the panel between easher dryer remove the metal panel behind it remove 2 screws each side controls panel reomve control panel unplug the switch going to dryer door let panel hang down remove 2 screws bottom door panel one each side remove 4 screws on the top front panel with door will fall in your hands oyt seals on it let dry
Posted on Feb 28, 2008
SOURCE: front felt drum seal on ge came off---hard to repair?
No its not hard, just unplug first and then just take the front off and take note where the wires go to the door switch.,also check your drum to make sure you did not damage.
Posted on Nov 19, 2008
SOURCE: Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Posted on Nov 21, 2008
TheMobilian
  • 8220 Answers
SOURCE: squeaky dryer drum...felt thing came off how to replace it?
Squeaking is cause by the drum bearing worn out and telling the tale. As it get thinner and thinner it begins to rub against the metal outer casing it is embellished in. To inspect it you must rmove tyhe front and get the drum out. Start by opening the the door and removing the screws holding down the top. Then raise the top and get the screws out thathold the front on. Use the rear acces panel(if applicable) to get the idler loose or access that idler from the front.e24a4b7.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 13, 2009
Controlfrk
  • 304 Answers
SOURCE: Maytag MDG9700AWW Runs Forever
The Complete Service manual is at the link below and it describes the disassembly process and full diagnostics. Download and save it. Hit Free User and wait for the Download button to appear.Good Luck.
MDG9700
Posted on Sep 06, 2009
Very noisy bearing, can it be changed? Can the drum be removed?
All this is possible, however, I am not sure it is for the do-it-yourselfer.
I know of no book or manual telling you how to do this.
Maytag repair people often go to school or class to learn this trade.
You may also need tools and gadgets to do this job.
Perhaps you could call a Maytag repair shop and ask them how to fix it.
God bless your efforts.
Nov 06, 2015 | Maytag Washing Machines
Felt belt found inside of drum
Hi - these are used to minimize the metal to metal contact of the drum & housing.
One will need to remove the top & front panels to gain access to remove the drum, afix felt to end in question and assemble the machine again.
Jun 14, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
My maytag neptune dryer is making a scratching noise.
If the sound seems to come from the front of the drum it's probably the felt guides. The bottom one will wear first and make a grinding, rattle like sound. You can access it by removing the front panel which includes the door. It fits around the drum at the front. Here's a diagram. Some models have a two piece and some a one piece guide. Part 4 on this diagram is one. It's called a seal here. DIAGRAM
If the sound comes from the rear, there is a nylon bearing and metal socket at the rear center of the drum.
Feb 06, 2011 | Maytag Neptune MDE5500AY Electric Dryer
The dryer is majing a horrible noise. what could this be? Calvin
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-dryer-combo-Parts/Model-LSE7806ADQ/3048/0152000/M0601021/00005?blt=06&prst=&shdMod=
Dec 09, 2010 | Whirlpool LTE5243D Top Load Stacked...
Maytag Bravos dryer tearing the "felt ring" on front of drum.
Mostly likely the cause was the skid pads came off or were missed aligned. You could have also jarred the drum but it doesnt matter because you want it fixed. So take off the front of the dryer after calling your local maytag dealer and making sure they have the felt, skid pads, belt, and rear rollers (just in case you find more problems).
Once you have this apart make sure you clean it good, take out the lint catcher and vacume all of the lint. No reason to put back together a nasty dirty dryer. Make sure you check the rear felt carefully and the rollers. This is a very simple job and shouldnt take more than about an hour. Make sure you take the door off first then the front panel and you have someone to help hold your tools while you think. Have fun
Aug 03, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Access the drum to replace felt
To access the drum two screws need to be removed from the inside of the door. The screws are on top of the opening and hold the top of the dryer closed. Then you simply lift the top and slide it to the left to remove it, thus revealing full access to the top of the drum. Then two screws (left and right) need to be removed in order to remove the entire front of the dryer. Once the front is removed the drum can also be removed but for the purpose of replacing the felt removal of the drum is not neccessary. It should be noted that the felt sits only around the bottom of the drum and covers just over half of the circumferance of the drum. The felt should be position in around the opening of the inside part of the door. When replacing the front cover the drum will fit snuggly up against the felt. Replace screws, top and door screws and walla...fixed!
May 11, 2009 | Dryers
Replace the felt on a ge dryer part #we9m30?
You need to buy new felt. There is an upper and a lower piece. The upper piece has 3 glides to support the drum. When you buy the parts, make sure you have the dryer part number and there are some pictures that will help.
Make sure you uplug the dryer. Flip up the top lid of the dryer by sliding a large flat nose screw driver under the front corners of the top. Remove the front panel by taking out two phillips screws. Also remove the power cable to the front controls so you can completely remove the front panel. Strip off the old felt and clean the surface as good as you can. Glue on the felt (you should get a tube of glue with the new felt). Let is dry a bit before you put everything back together. It is a pretty easy job.
Mar 13, 2009 | GE DBSR453EBWW Electric Dryer
Maytag Dryer Mosel #MDE6700AZW
you will need to remove the front panel and the front bulk head. after that you will see that there are clips that need to be pushed down to hold the fabric (felt) down. You need to make sure that the felt isn't torn. If it isn't torn then all you need to do is take a flat head screw driver pry the clips up and put the felt back on and push the clips back down
Dec 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
I need to replace the dryer belt
The belt on a dryer is inside the body, usually accessed and changed as follows
most base dryers
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
maytag
  • remove screws from bottom bend of front panel
  • lift front panel off
  • remove doo switch cable
  • sent front panel aside
  1. drum motor felts and bearings are now accessible.
  2. lift drum and withdraw fully forwards
  3. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear, easier to replace now, if worn, than have bearings or slides cause belt to break again.
  4. loop belt loosely around drum at wear marks from prior installation
  5. reinsert drum onto rollers bearings slides felts as installed.
  6. loop belt around motor pulley
  7. pull tensioner pulley against spring to end of its travel
  8. loop belt around tensioner pulley
  9. relax tensioner pulley to tighten belt
  10. rotate drum by hand to ensure belt is aligned
reassemble case in reverse order.
Notes
There are not many belt, felt, support roller sizes the local parts guy will have a belt, felt, roller to fit,
Tensioner pulley may not be in place, breaking belts often pull them out of their mounts, the pulley and spring will be lying on the case floor, there is only one way they fit in to their mounts so they are easy to reinstall
tensioner sketch is approximate, pulley may be on top run pulling down, or bottom run pushing up
the repair is easy, it takes longer to type or read this than it does to repair the dryer
Belts ~$14 Support Rollers ~$14/pair, felts/slides upto ~$25
New dryer +$200 - its a good repair
Sep 06, 2008 | Dryers
Maytag atlantis
UNPLUG DRYER, 220v is not fun
You get in the back of the dryer, from the front.
maytag dryers have two screws in the curve of the bottom of the front panel. (Note:screws may be torx-secure screws, cut a slot in them and use a flat screwdriver or pick up a torx-secure #20 bit at a tool shop, star shape with a pin in it)
remove the screws and the front panel can be swung up from the bottom and unhooked.
unplug door switch wires
reach under drum, for belt tensioner, pull belt off tensioner. and motor pulley
lift drum up and slide out forward
under drum are 2 rubber tired rollers, check for free motion, replace both if either is seized
the drum has felt bushes on it
examine felts for wear, replace if worn.
ensure all felt and adhesive is scraped from drum before fitting new felts, if there is any left, it bumps/thumps and knocks every rotation (best adhesive is Hi temperature red silicone)
use 2-4 pairs locking pliers(visegrips) to install felt
  • put adhesive on drum edge
  • clip felt in place at one point with visegrip
  • pull felt around drum, clipping in place as you go
  • let sit in clamps till adhsive sets
reassemble drum in reverse order
38d7d07.jpg while you got it apart is a good time to clear any lint from exhaust vents and squirrel cage fan,
felts last cost $30/pair rollers $9/pair
takes 45 minutes now to change felts, I do rollers while the adhesive sets, had a lot of practice, replace the belt, cost is minimal, it has been *****ed pulling the drum against the worn felts or rollers, and will break soon, dont want to open up again
Aug 29, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
