Question about Dryers
WHEN I HIT START BUTTON, IT JUST HUMS, DOESN'T START DRUM
    Brigadier General:
  • 4,088 Answers
Suspect a broken drive belt. Open the top to check. On some models, you need to push two spring clips inward--one on each front corner with a thin putty knife. On others, remove several screws from the back edge and slide the top back. To install a new belt, the front panel must come away from the cabinet to pass the belt over the drum. Remove a lower back panel to place the belt over the motor pulley and spring loaded idler pulley.
Posted on Feb 02, 2010
Dryer hit start button and it hums
sounds like a motor is going bad or you have a sock in the blower fan but if it was a sock, it wouldn't work at all
Feb 12, 2013 | LG Dryers
KEYS750LQ0 dryer doesn't start it just hums when I push start
Check the belt. You may have to open the machine up to look. if the belt is ok turn the drum by hand and see if the motor pulley is also turning. While you are in there look for foreign objects that have wedged against the drum preventing it from turning.
Oct 09, 2012 | KitchenAid KEYS850LQ Electric Dryer
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
f you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 18, 2011 | Kenmore Dryers
I have a whirlpool dryer model # LEP6848AW0 and when you hit the start button it just hums like something is binding. Open the door and hold switch in and hit start button it hums and you spin the the drum...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Whirlpool Dryers
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
Model DLE3777W - Dryer hums when I push start button.
The drive belt for the drum may be broken and should be replaced.
Jul 18, 2009 | Dryers
When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
May 01, 2009 | Dryers
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
DRYER PROBLEM
If the drum isn't jammed, you have probably lost a belt.
Remove the rear panel of the machine and look for tattered remnants of a black belt.
Sep 04, 2008 | GE Profile DPSB620ECWW Electric Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
