Question about HP LaserJet 4350 Printer
How to clear Event log in HP 4350? - HP LaserJet 4350 Printer
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 73 Answers
Enter this code on service 09435004
Posted on Feb 03, 2010
My HP4530 needs disc replacement what do I do
In the event that you misplace a disc, if it is an installation disc, you can locate a software alternative on the HP site. to access it click here HP LaserJet 4350 Printer.
Apr 08, 2017 | Video Game Consoles & Games
Where is poweredge 1800 display led connector
http://www.dell.com/support/troubleshooting/us/en/19/KCS/KcsArticles/Print?he Embedded System Management (ESM) log - also called System Event Log (SEL) or hardware log - reports potential hardware problems in Dell PowerEdge servers. Sometimes, simply turning off the server and disconnecting it from the electrical outlet will remove the error message. Wait approximately 10 seconds, and then reconnect the power cable and restart the server.
Other times, you will need to clear the ESM log to remove the error message. For instance, error code SEL FULLindicates that you will need to clear the ESM log. (You will lose the server's event history.) There are different ways to clear the ESM log.
To use DSET to Clear the ESM Log
  1. Download and open the DSET utility.
  2. Click the plus (+) next to System, and then click the plus (+) next to Logs.
  3. Click ESM to highlight it.
  4. Click Clear ESM Log located in the upper-right corner of the page.
To use OpenManage Server Administrator (OMSA) to clear the ESM log
  1. Start OpenManage Server Administrator (OMSA).
  2. Log in to OMSA by entering your username and password, and then press Enter.
  3. Click the Logs tab, and then click Hardware.
  4. Click Clear Log located next to Options.
To use Dell IT Assistant to clear the ESM log
  1. Start IT Assistant.
  2. From the middle System Tree bar, select your server by clicking it.
  3. Click the Logs tab, and then click Clear Log in the upper-right corner of the page.
Find your Dell PowerEdge server model in the chart below for other ways to clear the ESM log:
PowerEdge server model How to clear the ESM log 2300, 2400, 2450, 2500, 2500SC, 2550, 4300, 4350, 4400, 6300, 6350, 6400, 6450
Use the Log2Txt.exe utility to clear the ESM log:
  1. Start your server to the Log2Txt utility.
  2. When you see the ESM Log main menu appear, press 2 on your keyboard to select Clear ESM log.
  3. When the ESM Log main menu reappears, press 5on your keyboard to exit the utility.
1650, 1850, 1800, 2600, 2650, 2800, 4600, 6600, 6650, 7150, 6800, 6850, R900
Use the DRAC or ERA to clear the ESM log:
  1. Type the IP address of the Remote Access Controller (RAC) in the web browser address bar, and then press Enter.
  2. Log in to the RAC.
  4. Click Clear Logs located in the upper-right corner of the page.
1850, 2800, 2850, 6800, 6850
Use the program BMCCFG.exe to clear the ESM logs:
  1. Download and extract the Dell OpenManage Deployment Toolkit here.
  2. Go to x:\Dell\Toolkit\Tools, where x is your primary hard disk drive.
  3. Copy the file BMCCFG.exe to a bootable floppy disk.
  4. Start the server from the bootable floppy disk.
  5. At the command prompt, type bmcc - clearsel, and then press Enter.
    The message "Clearing SEL" will display while the log clears.
1950, 2900, 2950, DP500, DP600, NF500, NF600
Use the BMC/BIOS to clear the ESM log:
  1. To open the BMC menu, press the Control + Ekeys during POST.
  2. From the list, select System Event Log, and then press Enter.
  3. Select Clear System Event Log, and then pressEnter.
=8590&doclang=EN
Jun 09, 2014 | Dell PowerEdge 1800 Server
Hp-4350 shadowing all characters
Replace toner cartridge and see if clears. If no change, order a fuser assembly and replace, its fairly easy.
Oct 15, 2012 | HP LaserJet 4350 Printer
I have an LH3 server how do i clear the event log on front panel
hi,
you will have to boot to bios and clear the logs in order for the light to go off
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Jul 18, 2011 | HP NetServer LH3
C2A2: system event log (sel) full
even tough you did not specify the generation of your server
if this is the complete error message
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS
this is the way to resolve it :
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key.
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup
Aug 18, 2010 | HP ProLiant ML110 Server
How to clear event log in HP LJ p2015 ?
Use the embedded web server.
Type the IP address of the printer into your browser.
the event log should be somewhere in there.
Aug 18, 2010 | HP LaserJet P2015dn Printer
LaserJet 4350 Printer: 49.2f02 service error on hp 4100 printer...
Turn the printer off for a few minutes and then back on. If that does not fix the problem, try to have the print queue cleared and tray again. Most of the time it's a PDF file that causes this problem. If that does not fix it, it may need a new Jetdirect card.
May 16, 2010 | HP LaserJet 4350 Printer
LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
Server error
Clear System Event Log thru CMOS setup or the management software provided with server . The SEL is full that is the reason the error message
Mar 02, 2009 | HP ProLiant ML150 G3 Server
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
HP LaserJet 4350 Printer Logo
766 people viewed this question
Seeker5211
Seeker5211
