Question about Thermaltake Liquid Cooling System Water Level Indicator Reservoir - CL-W0009
Reservoir my car keeps over heating so i went 2 auto zone and i baught a cheap lil galon dat supousably would work the cap keeps popin of cause of da presure i dont if its a reservoir tank or a regular galon dat holds water my car is a 98 eclipse.
  • w33d Feb 22, 2008
    o i got your meseg im lookin for da lil tank da thermaltake my old one has a big hole dats why it over heats im lookin 4 a new one right away
Do not overfill your reservoir tank!
Scheck see if your fan is running regularly and strong. If it's not, then cooling won't happen and it will shoot water every time.
Water pumps can also cause such problems in when they fail.
Posted on Feb 20, 2008
I got a 2000 Chrysler Sebring n da ABS light is On. I drove it like dat 4 like 1*day n 2*times da ABS light turn off but da 2*times dat it turn off I experience a ugly feeling noise wen eva I push on da...
He told you what sensor to replace. Replace it. You don't have to replace any of the other ones. Plus , you can drive your car like that. It will still stop with out ABS...
Nov 11, 2014 | Cars & Trucks
Over heat n due to non circulation of coolant into radeator
You may have a leaking engine head gasket or a clogged radiator. Do not drive this until the problem is repaired or you will do serious damage to the engine.
Nov 08, 2012 | Cars & Trucks
2004 gmc yukon is overheating and air conditioning blows cold air. i cracked open coolent reservoir and it gurgled so i shut it. then the heat started working and the engine temp went down, but not...
bleed the air from cooling system. and make sure its full of coolant. replace thermostat if need be. good-day ! if above fails replace coolant reservoir cap, it may not be releasing pressure as need be. and its over heating. just remove cap and start car to see if it over heats. if it still does, repair as above. and be sure the cooling fans are working. but an improper seal of the radiator cap or pressure malfunction of the cap is an easy (and cheap) source to check first. If the pressure in the radiator is not high enough, the fluid will boil at a lower point and the resulting steam cannot flow through the cooling system.
Nov 21, 2011 | 2004 GMC Yukon
My 2008 Mercedes 350 is having heat problems ,,the engine heat meter is above the middle but not in the red zone though is that ok? the car is currently running 44000 miles
Check and make sure that the coolant reservoir cap is not leaking, this cause the cooling system pressure lost. Most european cars uses closed coolant system. Have the cap tested and it should hold the required pressure of around 16psi. Also be sure that all air pockets are dispelled.
Aug 30, 2011 | 1995 Mercedes-Benz C-Class
Heyyy..... i bought a 2007 model ford ikon flair 1.3 rocam, 2 weeks ago. Now its giving me heating problem... i have to fill in water daily. Water vanishes very quickly in about 2 days... and the fan...
Sounds like a head gasket to me. if you go thru that much water in two days you should be seeing white smoke out the exhaust system.
Good luck
Nov 10, 2010 | Ford F Cars & Trucks
The cars running really ruff, and the toxic fumes light appered
WISH I CUD HELP. IVE GOT D SAME PROBLM. MINES BEEN STOOD 4 6 YEARS THOUGH. sMOKING REALLY HEAVY AND THE CAR SOUND A LOT LOUDER THAN IT SHOULD IT ALSO SHAKES A LOT ESPIECIALLY WEN I TOUCH THE THROTTLE. TRY CHANGING THE FUEL AND A OIL CHANGE. DID DAT TOO MINE. STOPPED SMOKING AND RUNS A LITTLE BIT SMOOTHER.ITS ALSO QUITEN DOWN A LIL BIT. KEEP IT RUNNING FOR LONG THOUGH AND GET ALL DA CRP OUTTA D SYSTEM HOPE IT HELPS . SABZ
Oct 22, 2009 | Renault Sport Cars & Trucks
Coolent light and check engine light
Your thermostat will not affect the heat in your car. This is controlled by the heater core which is pulled from coolant from the engine where the coolant will be the hottest. Your thermostat opens and allows the coolant from the engine to circulate into the radiator and the coolant from the radiator flow into the engine. A thermostat is cheap and easy to replace. The sensor should be a fairly inexpensive and easy replacement as well. I would change out the sensor first because bad thermostat would create an overheating problem.
Nov 20, 2008 | 2000 Pontiac Grand Prix
Coolant problems with 1997 Chrysler LHS
Your waterpump belt is broken.... or your radiator is block Check thermostat is working. If this 3 things is Okay your headgasket is blown or one of the heads is crack.
Sep 28, 2008 | 1996 Chrysler LHS
Lost charger
Please call Jazz at 732-572-7050
Jun 09, 2008 | Jazz DV-179 Digital Camera
Thermaltake Liquid Cooling System Water Level Indicator Reservoir - CL-W0009 Logo
112 people viewed this question
Top Thermaltake Computers & Internet Experts
Martin Clarke
Martin Clarke
Lawrence Oravetz
Are you a Thermaltake Computer and Internet Expert? Answer questions, earn points and help others
