Question about Arris SURFboard® SB5101 Cable Modem
Random disconnects Cable company has tried everything on thier end. Below is the log for a few disconnects. Logs The Logs Page provides diagnostic messages generated by the Cable Modem. It is intended for use by a qualified technician. Status Signal Addresses Configuration Logs Help TimePriorityCodeDescription 2010-02-02 14:59:313-CriticalT001.0SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing 2010-02-02 14:52:186-NoticeI401.0TLV-11 - unrecognized OID 1970-01-01 00:00:253-CriticalD003.0DHCP FAILED - Requested Info not supported. 1970-01-01 00:00:076-NoticeM571.1Ethernet link up - ready to pass packets 2010-02-02 14:51:436-NoticeM573.0Modem Is Shutting Down and Rebooting... 2010-02-02 14:51:433-CriticalR004.0Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o 2010-02-02 14:51:423-CriticalT001.0SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing 2010-02-02 14:51:263-CriticalT004.0SYNC Timing Synchronization failure - Failed to receive MAC SYNC frame within ti 2010-02-02 14:42:546-NoticeI401.0TLV-11 - unrecognized OID 1970-01-01 00:00:533-CriticalD003.0DHCP FAILED - Requested Info not supported. 1970-01-01 00:00:353-CriticalT001.0SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing 1970-01-01 00:00:106-NoticeM572.0Ds Lock Failed - Reinitialize MAC... 1970-01-01 00:00:076-NoticeM571.1Ethernet link up - ready to pass packets 2010-02-02 14:41:506-NoticeM573.0Modem Is Shutting Down and Rebooting... 2010-02-02 14:41:503-CriticalR004.0Received Response to Broadcast Maintenance Request, But no Unicast Maintenance o 2010-02-02 14:41:423-CriticalT001.0SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing 2010-02-02 14:41:403-CriticalT002.0SYNC Timing Synchronization failure - Failed to acquire FEC framing 2010-02-02 14:41:403-CriticalT001.0SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing 2010-02-02 14:41:393-CriticalT002.0SYNC Timing Synchronization failure - Failed to acquire FEC framing 2010-02-02 14:41:383-CriticalT001.0SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing 2010-02-02 14:41:343-CriticalT002.0SYNC Timing Synchronization failure - Failed to acquire FEC framing 2010-02-02 14:41:333-CriticalT001.0SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing 2010-02-02 14:41:243-CriticalT002.0SYNC Timing Synchronization failure - Failed to acquire FEC framing 2010-02-02 14:41:243-CriticalT001.0SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing 2010-02-02 14:41:153-CriticalT002.0SYNC Timing Synchronization failure - Failed to acquire FEC framing 2010-02-02 14:41:143-CriticalT001.0SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing 2010-02-02 14:41:133-CriticalT002.0SYNC Timing Synchronization failure - Failed to acquire FEC framing 2010-02-02 14:41:123-CriticalT001.0SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing 2010-02-02 14:17:033-CriticalT004.0SYNC Timing Synchronization failure - Failed to receive MAC SYNC frame within ti 2010-02-02 14:16:553-CriticalT001.0SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing 2010-02-02 14:16:523-CriticalT002.0SYNC Timing Synchronization failure - Failed to acquire FEC framing 2010-02-02 14:16:523-CriticalT001.0SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing 2010-02-02 14:16:513-CriticalT002.0SYNC Timing Synchronization failure - Failed to acquire FEC framing 2010-02-02 14:16:483-CriticalT004.0SYNC Timing Synchronization failure - Failed to receive MAC SYNC frame within ti
  • 360 Answers
Your problem is on the Cable companies side, there is nothing you can do besides making them come out to fix it. Be warned that some ISPs are known to play the blame game and pin it all on you...I used to work for Comcast and seen this happen regularly.
In short, you are looking for a connection problem in the lines around/in your house.
The long version:
The cable wires that run around the neighborhood are the main lines. Every few houses there is what is called a "tap". The tap is a little box with a few ports to connect a regular sized cable to it(the same cable you see inside your house). Fromt he tap the cable goes to your house and "should" be connected to what is called a "ground block". A ground block should have a wire going from it to some type of ground. This is to prevent an electrical shock traveling through the lines into your house and frying anything connected to it. From the ground block it should then go into a "splitter". The splitter has 1 input port for a cable line to connect to and has anywhere from 2-10 output ports. If there are unused output ports, they should be capped off to reduce signal bleeding/loss/interference.
Okay, now the fun part. From the ground block, the next step in your line should be a 2 port splitter. So it should have a cable going into it and 2 coming out. One of the 2 coming out of it should be going "directly" to your modem. If the setup is any different than I just described, your house was wired wrong and could be the culprit to your internet problem.
There is also a possibility that your "tap" is bad, I have seen it more than a few times. A low level tech can fix this.
Also, there are boxes every so often on the main lines that run on the telephone lines. They can be misconfigured and also create internet problems. These will require a higher level technician to fix.
Next possibility is that your modem itself is bad, when you schedual a trouble shooting call with your ISP, ask them to bring an extra modem with them.
Almost forgot an important one, where the cable "screws" into any port on the tap, ground block, splitter or modem...it is not snug tight and you are not getting a full signal. This is a very very very common problem. The endings that screw into things, they are called "F-Connectors" and do periodically require to be replaced.
The tech that comes out to fix your problem, if they do not have a wave length meter on them...they do not have the proper tools to diagnose your problem. An official tech of your ISP will almost always have one on him, it is the contractors that usually do not. Ask for a real tech and not a contractor to show up.
Keep calling when you experience problems. Each time you call, ask for money to be taken off your bill for your troubles. If the person on the phone says they can not do that, ask for a supervisor.
Hope this helps.
Posted on Feb 02, 2010
I have a gas fireplace with logs that need replacing badly. I want to replace the logs with new ones. Company may have gone out of business.
Chances are you will not need to replace the logs with exact duplicates - the real concern when replacing gas logs is two-fold:
1. The electrical connection - most units use a standard 110v power source - usually connected to a single pole switch. The connection to the burner unit usually comes in the form of a small metal box with the power line from the switch connected inside, usually with 3 wires - black (hot), white (neutral), and bare or green (ground) - make sure any replacement unit is designed for 110v.
2. The gas connection - while this is something than can be done by the end consumer, the better bet is to have a HVAC professional disconnect the older unit and make the connection to the new one. The good news is that almost all gas units are designed to work with universal connectors, the bad news is that this connection needs to be completely free of defect or leaks, hence the recommendation for a HVAC pro.
Nov 20, 2014 | Home
Bt yahoo sign injohnandbarbingham@btinternet.com. unable to log into my email account
Click the "Forgotten password?" link just below the password box on the btinternet login page.
Jul 21, 2014 | Computers & Internet
Where is poweredge 1800 display led connector
http://www.dell.com/support/troubleshooting/us/en/19/KCS/KcsArticles/Print?he Embedded System Management (ESM) log - also called System Event Log (SEL) or hardware log - reports potential hardware problems in Dell PowerEdge servers. Sometimes, simply turning off the server and disconnecting it from the electrical outlet will remove the error message. Wait approximately 10 seconds, and then reconnect the power cable and restart the server.
Other times, you will need to clear the ESM log to remove the error message. For instance, error code SEL FULLindicates that you will need to clear the ESM log. (You will lose the server's event history.) There are different ways to clear the ESM log.
To use DSET to Clear the ESM Log
  1. Download and open the DSET utility.
  2. Click the plus (+) next to System, and then click the plus (+) next to Logs.
  3. Click ESM to highlight it.
  4. Click Clear ESM Log located in the upper-right corner of the page.
To use OpenManage Server Administrator (OMSA) to clear the ESM log
  1. Start OpenManage Server Administrator (OMSA).
  2. Log in to OMSA by entering your username and password, and then press Enter.
  3. Click the Logs tab, and then click Hardware.
  4. Click Clear Log located next to Options.
To use Dell IT Assistant to clear the ESM log
  1. Start IT Assistant.
  2. From the middle System Tree bar, select your server by clicking it.
  3. Click the Logs tab, and then click Clear Log in the upper-right corner of the page.
Find your Dell PowerEdge server model in the chart below for other ways to clear the ESM log:
PowerEdge server model How to clear the ESM log 2300, 2400, 2450, 2500, 2500SC, 2550, 4300, 4350, 4400, 6300, 6350, 6400, 6450
Use the Log2Txt.exe utility to clear the ESM log:
  1. Start your server to the Log2Txt utility.
  2. When you see the ESM Log main menu appear, press 2 on your keyboard to select Clear ESM log.
  3. When the ESM Log main menu reappears, press 5on your keyboard to exit the utility.
1650, 1850, 1800, 2600, 2650, 2800, 4600, 6600, 6650, 7150, 6800, 6850, R900
Use the DRAC or ERA to clear the ESM log:
  1. Type the IP address of the Remote Access Controller (RAC) in the web browser address bar, and then press Enter.
  2. Log in to the RAC.
  4. Click Clear Logs located in the upper-right corner of the page.
1850, 2800, 2850, 6800, 6850
Use the program BMCCFG.exe to clear the ESM logs:
  1. Download and extract the Dell OpenManage Deployment Toolkit here.
  2. Go to x:\Dell\Toolkit\Tools, where x is your primary hard disk drive.
  3. Copy the file BMCCFG.exe to a bootable floppy disk.
  4. Start the server from the bootable floppy disk.
  5. At the command prompt, type bmcc - clearsel, and then press Enter.
    The message "Clearing SEL" will display while the log clears.
1950, 2900, 2950, DP500, DP600, NF500, NF600
Use the BMC/BIOS to clear the ESM log:
  1. To open the BMC menu, press the Control + Ekeys during POST.
  2. From the list, select System Event Log, and then press Enter.
  3. Select Clear System Event Log, and then pressEnter.
=8590&doclang=EN
Jun 09, 2014 | Dell PowerEdge 1800 Server
On a Dell T5400 The Preboot System assessment gives a 2000-0146 error, saying that 'there are prevous errors in the log' I have run chkdesk and it did find errors and now all seems ok. But I s
Microsoft Sharepoint records its usage logs in diagnostic files.
Each of these logs can be maintained and used through the Windows graphical user interface.
Deleting a log erases its records permanently from your hard drive, but in turn frees disk space that can be used for other purposes.
Open your Start menu and type "Sharepoint" in the search programs and files box.
Click "SharePoint Portal Server Central Administration" and press "Enter."
Click "Server Name" where "Server Name" is the name of your server, then click "Configure diagnostic settings."
Click "View Diagnostic Logs," then select the log you'd like to modify.
Click "Delete" on the toolbar, then click "Yes."
Your log is now deleted.
Hope this helps.
Nov 20, 2012 | Dell Precision T5400/ T5500/ T7400/ T7500...
Problems with IBM Xseries 346 Server
Check Light Path Diagnostic which is located on the front side of server . It gives a clue of what's the issue . If you can't see any amber on Light Path Diagnostic , then its an indication of max logs logged on BIOS event logs. You may need to restart server > Get into Bios and clear all event logs . This would remove the information sympol from server .
Jul 31, 2012 | IBM xSeries 346 Server
Hi, I’m facing one issue with D-Link (DCM-202) Modem from last week. The internet connection frequently disconnecting with interval time less than 10 min. I have checked with service provider COM CAST...
Is this a new issue or a recent harware/cable change or did this use to work and now has the disconnect issues.
Ensure that your cable has NO Splitters (especialy outside) from the Drop outside to your modem.
Check all cableing between Computer and Modem to Cable Drop.
You can also look at the Modem Status Page to check your UpStream and DownStream signals. You may have to have someone come out to check out the line running from your house to the pole (or pedestal if its underground)? Many factors can cause an outside cable to deteriorate, and when that happens you can end up with alot of signal leakage and frequent disconnects. And that goes for both overhead and underground lines. Good Luck, and post back if you need more help. (try to include your Modem Status Logs)
Jan 02, 2011 | D-Link (DCM-202) Modem
Printer not responding to PCs print instruction All cable connections checked and appear firm in outlets. Will not print either new or existing files
Are you able to make copy from printer or print test page ?
If you are not able to make copy from printer or print self test page
Check if the cartridges are not empty.
If they have ink, follow the steps below
1. Disconnect the power cable from back of printer
2. While holding the # and 6 button on front panel of printer connect the power cord to printer.
* Note : This is semifull reset and this will erase fax logs and any wireless settings on the printer.
You will have to re-setup the printer on wireless network.
Or if the copy works fine from printer and you are not able to print from PC only, follow the solution below.
Click the link below to know how to resolve the print job stuck in queue issue.
Link
Oct 29, 2010 | HP OfficeJet 7140xi All-In-One InkJet...
HP 7210 Officejt is not printing
2. While holding the # and 6 button, connect the power cord to printer.
3. It will print the alignment sheet and you will have to re-align the printer and try to print/copy
*Note this is Semifull reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
Or are you not able to print from PC ?
Link
Oct 23, 2010 | HP Officejet 7210 All-In-One InkJet...
I m having the LG KM900 and I was wondering can the phone accept phone calls when I m browsing in a website?And if yes, does it logs me out the web site automatically while I m receiving the call?After the...
Hi, When browsing, when you want to make calls, the internet logs out immediately and after the calls, the internet comes back on by logging on, but it does not take you back to the same page you where before.
But some phones does that,you can try it on your phone.
Take care.
Sep 14, 2010 | LG KM900 Arena Cell Phone
Retrieving and displaying logged in users info
you had not provided complete detail that if you are having database for username or you want to fetch username from 'email providing site' in which your user created his account.if you are trying for second option,It is almost not possible coz any of the email providing site will not exchange personal detail of any of his acc holder.
if you are trying first option,session in php can help you.you can store username in a session variable n then u can access them on any page if session is not destroyed or expired.
Mar 22, 2009 | The PHP Group PHP
Arris SURFboard® SB5101 Cable Modem Logo
2,610 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
