Question about Refrigerators
Freezer door very hard to open new fridge freezer
  • 52 Answers
Either you have placed them in incorrectly, out of alignment, or you may have over-loaded the bin with food items. The rails have to be placed in a certain way to move freely.
Posted on Feb 04, 2010
My fridge temprature constantly keeps going up even after turning on the supper.
Something new is blocking the airway from the freezer to the fridge. Check the freezer, look for vents that have been blocked. If it has been blocked too long, ice can build up in passageways in the freezer that are hard to get to. Maybe the fan got jammed, you should hear it when the freezer door is closed. It usually stops when the freezer door is open, but if you push the switch it should run.
Nov 21, 2013 | Refrigerators
GE refrigerator model #LTC19340ST freezer door not sealing
That is a common problem with over-under units. You can clean or replace the door seal or, tilt the unit back a TINY bit. The door pops open because there is a common airway from the freezer to the fridge. When the fridge door shuts too fast, it pushes a lot of air into the unit. It needs to go somewhere so, it pops the freezer door open. If you shut the freezer hard enough, you will be able to pop the fridge door open.
Jan 20, 2013 | LG LTC19340ST 19.0 cu. ft. Top Freezer...
Maytag GC2225PEKW american fridge freezer stops working if you open fridge or freezer.
it sounds like you have a bad jazz board part 12868513,go here to see it
http://www.repairclinic.com/PartDetail/Main-Control-Board/12868513/1472681?replacedManufacturerPartNumber=67004453%20.
unplug the machine,open the fridge door,remove the plastic cover behind the control panel,then feel behind the control panel,you'll feel a slot,one on each side,you stick a screw driver into the slot and push,one at a time and it releases the cover on the control panel, you have to push hard so don't worry the plastic is strong,you'll see the jazz board and a sensor on the right side,just remove the wires and sensor install the new board and reconnect the wires and sensor,then read the instructions that came with the new board and it will tell you how to program it,hope this helps and good luck
Jul 16, 2012 | Maytag Refrigerators
Left the freezer door open all night and morning noticed it in the afternoon. Thawed it and now the freezer works fine but the fridge doesn't cool
these fridge freezers have a damper flap which means your fridge will not cool until everything in the freezer is frozen hard again this may take up to two days depending how much you have in your freezer
Regards
Ian
Apr 19, 2011 | Hotpoint Refrigerators
Whenever fridge door is shut hard/ quickly it causes the freezer door to pop open a little...and meltdown the frozen stuff. The fridge door has dropped a bit but I don't think that is it. It seems there...
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Nov 30, 2010 | Fisher and Paykel Active Smart E522B...
Freezer is working but refrigerator is not
My Maytag (side by side) had a similar problem, turns out to be the damper door. The freezer does the cooling, there's a damper door between the fridge and freezer that opens and closes to control fridge temp. Find the damper door and prop it open. If the fridge temp drops overnight, you'll need a new damper ***'y.
Oct 01, 2009 | Frigidaire Refrigerators
SIDE BY SIDE FRIDGE DOORS VERY HARD TO OPEN
its because the door seals are new and are working correctly. The pressure difference between the warm outside and the cold inside cause a sort of vaccum and so makes it hard to open. It is usually only after the door has been closed a while that it will be hard to open. put your finger around the edge of the door and shift the seal slightly, this will release the vaccum and let the door open normally. It will get better after a few weeks. I have had 2 whirlpools also and this has been the same on both of mine.
Mar 18, 2008 | Refrigerators
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
