Question about RCA D52W135D 52 in. TV/DVD Combo
Color on the screen
When i turn the tv on it shows three color lines across the top one being red,another blue and another one green. and when im watching tv the color is all distorted
  • RCA Master
  • 8,457 Answers
Convergence is dead.Know how to solders?Replaced 2 convergence ICS and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost U $300 for parts and labors.
Posted on Mar 08, 2010
The color was off on the tv i took the bottom back off and there was a box with three screws on top and three screws on bottom that adjusted the colors when i turned the top left screw a little the three...
turn the center dial ( for green) down slightly then turn the other two the red and the blue up slightly to get the best screen without a dominate color screen.
Sep 02, 2011 | Philips 50P8341 50" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
I have some distored blue color across the screen
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Colors off. blue and yellow not lined up
try to set the convergance if you cant you can adjust the color tubes from inside the tv but have to be very careful to do this. There is actually only 3 colors in the tv red, blue green so I would say your blue and green need lined up
Sep 30, 2008 | Televison & Video
Phillips rear projection tv model #60pp9202/17f
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 25, 2008 | Philips 60PP9202 60" Rear Projection...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
My apex pf2725 tv screen is green
Your posted/describe symptom seems to be that the green color drive is defective. The "lines going across" are flyback retrace lines brought about by the safe problem.
The corrective procedure would be to replace. In most TV units, color drive are three (3) identical transistors: for the blue, green and red. They are normally located at a small squarish PCB attached to pins of the CRT right at the rear end of the neck. More often, they are heatsinked. Repair should be a straightforward desoldering the defective component and replacing with a new one.
In some versions, color drive is a single IC power pack.
Still, it is also possible that the problem may be due to cold solder on any or all of the pins of the above describe transistor (or IC).
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Apex Digital PF2725 27" TV
RCA D52W135D 52 in. TV/DVD Combo Logo
275 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
