Question about Samsung LN-T4061F 40 in. LCD HDTV
There are green lines across the television screen
There are green lines across my Samsung LN-T4061F television screen and they will not go away. Is there a simple fix for this or is this a big problem?
  • rwalker45 Feb 02, 2010
    The warranty has run out not to long ago. Thank you for help.
  • Samsung Master
  • 2,404 Answers
Its a big problem because whats happening is that the screen is going bad and if the TV is not under warranty the the screen is going to probably cost more then the tv is worth. Check to see if your TV is under warranty, most manufacturers give a 1 year warranty and then if by chance you bought the extended warranty from the store then you would have a longer warranty.
Posted on Feb 02, 2010
I have a Samsung LN T4061f flat screen that has developed horizontal lines that happens on every input as well as effecting the menu. i tried adjusting all the settings and it seems to get a little be
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 29, 2014 | Samsung LN-T4061F 40 in. LCD HDTV
Chromecast not working with Samsung LN-t4061F 40 in. LCD HDTV
Dear kindly note below producer for rectification of screen automatically switched to the left. As it does not have adjusted button. First adjust your display resolution 1366 X 768 and then Press on/off button till 6 sec. adjustment option will be appeared. Then again press on/off button till 6 sec, screen will set automatically.
Dec 24, 2013 | Samsung LN-T4061F 40 in. LCD HDTV
Samung LN-T4061F - Dim Picture
Does it look like a dim black swirling cloud with very faint images?
Mar 24, 2012 | Samsung LN-T4061F 40 in. LCD HDTV
As i am watching tv after awhile my tv gets this green snow.
There are 3 colour guns in every TV and if one or more goes then you have what you are looking at a beautiful green screen.
Nov 01, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
LN-T4061F turns on black screen sound is there and no menu appears
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backklight board.U will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Feb 27, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
Our 4 year old hit the front of our LN -T4061F Samsung set with a plastic ball. It now has a shattered imprint that is black with white shatter marks and ranbow stripes...any chance the repair is less...
Sadly, the screen is the most expensive part of the TV. The replacement screen would cost more than the TV is worth. Shopjimmy.com is the only affordable place to buy the replacement screen, But, they are out of stock. Usually, the screen cost around $250 to $350. Any other website will cost an arm and a leg. Buying a new TV would be best at this point.
http://www.shopjimmy.com/catalogsearch/result/?q=LN+-T4061F+screen
Nov 16, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
My samsung l n-t4061f/ln 40 inch tv has rainbow dots on the screen and when i turn it on it has vertical pinks stripes on the screen.need your help
The problem was solve my power chip or piece burnout.So iam taking it to the shop to have it fix.Thanks for all your help
Nov 15, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
I have a LN-T4061F Samsung LCD, I'm seeing vertical bars across the screen
most of the time this is the ctrl board its like a graphic card tells the screen what to show,but the cable from that goes to main board sometimes this is the cause of lines/open it get no of control board it has a 30 pin thin lead going to main board and google it easy to replace plug n play
Nov 10, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
How do I get rid of purple and green wiggly lines? The black screen that appears when switching between channels was green a couple of weeks ago, that problem stopped after I unplugged the set for a while....
You have a bad LCD control board,It overheats and causes colored lines,screen to darken,or the color go floresent. Also check the power supply for bad caps.
when you have it apart.They usualy go bad on these tv's. It will cause the tv to take longer to come on.Or you have to hit the power button several times to get it on.
Oct 26, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
LN-T4061F Goes black after a couple of minutes.
The T-Con bd is probably going bad. Also the Main bd could be bad. Have a trained samsung tech troubleshoot the set.
Jul 07, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung LN-T4061F 40 in. LCD HDTV Logo
131 people viewed this question
Jerry Greenberg
Jerry Greenberg
