Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Wont turn on , or light up does have power going to dishwasher.
  • 619 Answers
Bad thermal fuse located in the control panel area. Easy to change and inexpensive also. Hope this helps. This will be a part kind of setting alone and has 2 wires going to it.
Posted on Feb 03, 2010
Light panel fully lit stopping program selection and start does a electronic part need replacing
I would suspect the user interface panel.
Most dishwashers can be tested thusly:
Turn off power to the dishwasher at the circuit breaker box. Take apart the Dishwasher door and unhook the cable from the User Interface panel to the main control board. Then, turn the power back on and close the dishwasher door so it latches. The drain pump should go on. If it doesn't the main board is bad. If it does, it's the user interface panel.
Oct 15, 2014 | Beko DW602 600 mm Silver Built-In...
Dishwasher won t turn off
As long as you have wired up correctly, your new board is faulty.
If you mean wont power down, as in the lights on the front wont turn off, these lights and the power switch itself are all part of the board.
Take it back for a warranty swap. Occasionally there is the odd faulty new part, there has be some unfortunate person to get them.
Jun 01, 2013 | LG Dishwashers
I have a whirlpool quiet partner 2 that wont turn on
call chas&son,s at 570-379-0993 and they will come out the same day no less okay
Jan 19, 2013 | Dishwashers
Red door light is on (red) so there is power to the dishwasher but the dishwasher will not turn on.
Hello what is the make and model number of your dishwasher? I will await your reply before posting a solution. Also if there are any other lights blinking or staying lit that wont go off please specify those as well in your post as well. I await your reply.
Thank you
Rick
Oct 28, 2011 | Dishwashers
DDW1802W ran fine yesterday. Panel light os, no start. Door seems to latch okay. It's not an overflow switch issue. No burnt smell.
dishwasher wont turn on. power is ok. when you turn the dial with the power switch on it clicks motor turn on pumps do not turn on wont fill or empty power light does nnot light up latch seems to be fastening proper is there a reset switch
Apr 09, 2011 | Danby 17 in. DDW1802W Designer Series...
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Led wont light up. no power to dishwasher
Measure for 115 volts AC at the junction box behind the front lower panel where the incoming power connects to the washer wiring. If ok, you will need a wiring diagram of the washer to go further.
Aug 17, 2009 | Maytag MDB9600A Jetclean II Built-in...
Wont go through cycles or drain the 3inches of water.Is getting power
turn on the dishwasher then go to your circuit breaker and, switch off the power to your dishwasher next: reach in to your dishwasher and remove the cover on your pump then remove any broken glass etc. that has fallen into the pump then put the cover back on and, close the dishwasher turn it on and, turn on the breaker you turned off earlier your machine should work again let me know how it goes...
May 02, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Midea dishwasher WQP12-924OA wont go alarm sounds when turned on and than the second light flashes
I had the exact same problem with the exact same model. It sounds unlikely, but I couldn't get it to work until I clipped the drain hose into one of the clips 2/3rds of the way up the back.
There was a sticker there that said "the drain hose must be attached to the left or the right clip"
Jan 29, 2008 | Dishwashers
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
100 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
