Question about Dell 1110 Laser Printer
Dell printer will not print. Receiving message: fuser error
My Dell Laser printer will not print. It tells me there is a fuser error.
  • Anonymous Mar 19, 2014
    Receiving error code 016-302.
  • 231 Answers
Fuser error usually means that the heater element has blown, or is not functioning properly.
The device will usually lock itself out to prevent any risk of overheating and causing a fire
You will need a technician to fix this
Posted on Feb 02, 2010
Just put all new image drums and toner in my Okidata C5300n, checked the IP address, the computer sees it and shows the pending print job, but the printer in not receiving the print job. I have tried...
In most laser printers, when you replace the drum, you need to reset your drum in your printer's menu options. This is to reset the page count for your printer to tell you when it will need to be replace again.
May 09, 2012 | OKI C5300n Led Printer
My Dell 3110 Colour Laser Printer comes up with the following message - Reseat Fuser Contact Support 010 - 390 Restart printer
There's not much on the web about this error message, but it does say to reseat the fuser. I found a writeup (with a picture) on how to do this.
http://en.community.dell.com/support-forums/peripherals/f/3528/p/19309114/19606748.aspx
Make sure that your printer is unplugged while you do this, also be aware that the fuser gets quite hot while it's printing and stays hot for a few minutes afterwards. Don't burn yourself! While the fuser is out you may want to blow out the dust from the printer with a can of compressed air.
If reseating the fuser doesn't get rid of the error message call Dell technical support at 1-877-293-1197.
Hope this helps
Please rate this solution, thanks!
Mar 09, 2011 | Dell 3110cn Laser Printer
Dell 1110 Laser Printer Fuser Error after
I would if it will print I would try a laser printer cleaning kit canbe found at any office supply like office max or staples
Jan 09, 2010 | Dell 1110 Laser Printer
Error message 0500h
Your fuser is not warming up. You will need a technician to look at it.
Mar 16, 2009 | Konica Minolta magicolor 5430 DL Laser...
Problem printing with Dell 3010cn Laser
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
Feb 10, 2009 | Dell 3110cn Laser Printer
Low voltage power supply
What is the error message you are getting with the new fuser. Is this the same error you were getting before changing the fuser? If you changed the fuser because the old one was just at EOL ( end of life) but did not give you an error, have you tried to reinstall the old fuser.
It is possible that the new fuser was damaged in shipping, or not properly seated.
If both the new and old fuser give the same error message, then yes, I would agree that the LVPS would be the next part to replace, however, if they have different errors, then you probably have 2 bad fusers ( or one that is EOL, and one that was received damaged).
Before changing the LVPS, make sure you follow the steps below prior to the LVPS steps.
as far as where to purchase it if you do in fact need one, you can always do a google and ebay search for "Dell 5100cn LVPS".
I can provide you with replacement instructions if it comes to that.
See below for the actual troubleshooting needed for the fuser.
The following steps are the troubleshooting steps that should be followed for error code 010 397.
First, the definition of the failure is <IOT Fuser Failure>, and means a Fuser Error is detected.
1) With power off, reseat the fuser by physically removing it from the printer, then reinstalling it and locking it in place. Turn the power back on. ( if the error is still present, proceed to step 2 ).
2) If reseating the fuser did not resolve the problem, Replace the fuser with a known good fuser.
( if problem is not resolved, proceed to step 3)
3) Replace the LVPS ( low voltage power supply ). ( if problem not resolved, proceed to step 4 ).
4) Replace the PWBA MCU ( printed wiring board assembly - machine control unit ).
END of troubleshooting.........
Oct 23, 2008 | Dell 5100cn Laser Printer
Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Jun 26, 2008 | Lexmark E342n Laser Printer
Dell 1110 Laser Printer Logo
774 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
