Back to:
Tags:
ASUS P4SGX-MX Motherboard
Motherboard doesn't wake up the monitor (by 2 users)
posted by eshimshi on Feb 19, 2008
When I trun on the computer the fans go on but
it doesn't beep, the keyboard doesn't blink
hd light is on for a few seconds and the monitor doesn't wake up.
Please, help needed!!!!
Comment by eshimshi, posted on Feb 19, 2008
The super i/o chip is hot. Is this the end of this motherboard?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on May 02, 2008
sis p4sgx_mx motherboard
Best Solution
Helpful (85)
F1forHelp
Rank:Guru Guru
Rating: 87%, 116 votes
Place your finger on the heatsink for the chipset. Feel around for any extremely hot chips. If you find this, your Bios is shot. If you cannot locate the bios chip, just feel all the chips. The Bios chip should be mildly warm but never HOT!
Comment by F1forHelp, posted on Feb 19, 2008
Yes, if a programmed IC (bios chip) is fryed, then that is the end of the road for that motherboard. Everything else should be ok though (HDD, CD-ROM, Processor, etc).
Rating Locked! (?) eshimshi has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on motherboard doesn't wake up the monitor:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
sis p4sgx_mx
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these Motherboards problems?
Motherboards
pcchips m810 rev 7.1a ¨q8-overheats then gets...
Motherboards
i have msi p45 platinum MB,two graphics cards xfx 9600GT...
Motherboards
I took apart my sister's computer an XP and I'm having a...
Motherboards
hey i need help with my problem that im haveing with my...
Loading problems.
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
